I added the following to my configuration.yml:
http:
api_password: xxxxx
server_port: 443
ssl_certificate: /etc/letsencrypt/live/xx.duckdns.org/fullchain.pem
ssl_key: /etc/letsencrypt/live/xx.duckdns.org/privkey.pem
From there I manually start HA as follows:
(homeassistant_venv) pi@raspberrypi:/etc/letsencrypt $ sudo /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/bin/hass -c /home/homeassistant/.homeassistant
The system appears to start up but then when I point my browser at it I get:
ERROR:homeassistant.core:Error doing job: Fatal read error on SSL transport
File "/usr/lib/python3.4/asyncio/selector_events.py", line 825, in _read_ready
data = self._sock.recv(self.max_size)
File "/usr/lib/python3.4/ssl.py", line 730, in recv
return self.read(buflen)
File "/usr/lib/python3.4/ssl.py", line 619, in read
v = self._sslobj.read(len or 1024)
ssl.SSLError: [SSL: SSLV3_ALERT_BAD_CERTIFICATE] sslv3 alert bad certificate (_ssl.c:1769)
And the browser returns 404: Not Found
OpenZwaveControlpanel also seems to not work:
pi@raspberrypi:/srv/homeassistant/src/open-zwave-control-panel $ sudo ./ozwcp -p 8888
2017-03-24 20:09:01.754 Error, Cannot find a path to the configuration files at ./config/. Exiting...
2017-03-24 20:09:01.761 Error, Exception: Options.cpp:91 - 1 - Cannot Find Configuration Files
Error: Options.cpp:91 - Cannot Find Configuration Files
There is possibly one error in the log but it looks like the install was not interrupted:
[localhost] out: Searching for gevent-socketio>=0.3.6
[localhost] out: Reading https://pypi.python.org/simple/gevent-socketio/
[localhost] out: Downloading https://pypi.python.org/packages/57/8f/16b508f602cff2dd506636b8d415e39cacb3400d49e885f002bf6436a777/gevent-socketio-0.3.6.tar.gz#md5=33f745d74885366a07da516c000854b6
[localhost] out: Best match: gevent-socketio 0.3.6
[localhost] out: Processing gevent-socketio-0.3.6.tar.gz
[localhost] out: Writing /tmp/easy_install-mt4m1toa/gevent-socketio-0.3.6/setup.cfg
[localhost] out: Running gevent-socketio-0.3.6/setup.py -q bdist_egg --dist-dir /tmp/easy_install-mt4m1toa/gevent-socketio-0.3.6/egg-dist-tmp-tu4sqjfz
[localhost] out: /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/setuptools/dist.py:342: UserWarning: The version specified (':versiontools:versiontools') is an invalid version, this may not work as expected with newer versions of setuptools, pip, and PyPI. Please see PEP 440 for more details.
[localhost] out: "details." % self.metadata.version
[localhost] out:
[localhost] out: Installed /tmp/easy_install-mt4m1toa/gevent-socketio-0.3.6/.eggs/versiontools-1.9.1-py3.4.egg
[localhost] out: warning: no previously-included files found matching 'socketio/.ropeproject/*'
[localhost] out: warning: no previously-included files found matching 'socketio/sample_protocol_for_doc.py'
[localhost] out: File "build/bdist.linux-armv7l/egg/socketio/namespace.py", line 170
[localhost] out: print "ERROR: No such callback for ackId %s" % packet['ackId']
[localhost] out: ^
[localhost] out: SyntaxError: Missing parentheses in call to 'print'
[localhost] out:
[localhost] out: File "build/bdist.linux-armv7l/egg/socketio/server.py", line 108
[localhost] out: except error, ex:
[localhost] out: ^
[localhost] out: SyntaxError: invalid syntax
[localhost] out:
[localhost] out: File "build/bdist.linux-armv7l/egg/socketio/virtsocket.py", line 365
[localhost] out: except (ValueError, KeyError, Exception), e:
[localhost] out: ^
[localhost] out:
[localhost] out: File "build/bdist.linux-armv7l/egg/socketio/packet.py", line 156
[localhost] out: except ValueError, e:
[localhost] out: ^
[localhost] out:
[localhost] out: zip_safe flag not set; analyzing archive contents...
[localhost] out: socketio.__pycache__.sdjango.cpython-34: module references __path__
[localhost] out: creating /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/gevent_socketio-0.3.6-py3.4.egg
[localhost] out: Extracting gevent_socketio-0.3.6-py3.4.egg to /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages
[localhost] out: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/gevent_socketio-0.3.6-py3.4.egg/socketio/namespace.py", line 170
[localhost] out: ^
[localhost] out:
[localhost] out: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/gevent_socketio-0.3.6-py3.4.egg/socketio/server.py", line 108
[localhost] out: ^
[localhost] out:
[localhost] out: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/gevent_socketio-0.3.6-py3.4.egg/socketio/virtsocket.py", line 365
[localhost] out: ^
[localhost] out:
[localhost] out: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/gevent_socketio-0.3.6-py3.4.egg/socketio/packet.py", line 156
[localhost] out: ^
[localhost] out:
[localhost] out: Adding gevent-socketio 0.3.6 to easy-install.pth file
[localhost] out:
[localhost] out: Installed /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/gevent_socketio-0.3.6-py3.4.egg
Is this expected?
