Frontend just gives blue banner
My frontend is not working, I just get a blue banner and nothing else, tried different browsers and clients, deleted cookies, deleted cache, opened in incognito windows google chrome, tried to disable (commented out) custom_components, z-wave, and hdmi-cec, also tried to disable https/ssl by commenting out the certs, there are no errors in the log, Latest homeassistant is running on raspberry pi.
System Health
arch armv7l
dev false
docker false
hassio false
os_name Linux
os_version 4.19.97-v7+
python_version 3.7.3
timezone Europe/Amsterdam
version 0.107.7
virtualenv true
Lovelace
mode storage
resources 0
views 5
configuration.yaml
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
  server_port: 8123
  ssl_certificate: /etc/ssl/private/cupboard-domotica.crt
  ssl_key: /etc/ssl/private/cupboard-domotica.key
  base_url: cupboard-domotica.flissinger.local:8123
  use_x_forwarded_for: true
  trusted_proxies:
    - 10.0.0.1
    - 10.0.0.2
  ip_ban_enabled: true
  login_attempts_threshold: 5
#  ssl_profile: intermediate
Also tried with just http: in configuration.yaml
homeassistant.log
root@cupboard-domotica:/home/homeassistant # cat /var/log/homeassistant.log
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setting up http
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setting up script
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setting up zwave
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.0 seconds.
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.components.zwave] Z-Wave USB path is /dev/ttyACM0
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2020-03-29 12:55:56 INFO (MainThread) [homeassistant.setup] Setting up hdmi_cec
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up updater
2020-03-29 12:55:57 INFO (SyncWorker_10) [homeassistant.loader] Loaded rpi_gpio from homeassistant.components.rpi_gpio
2020-03-29 12:55:57 INFO (SyncWorker_18) [homeassistant.loader] Loaded template from homeassistant.components.template
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up person
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up switch
2020-03-29 12:55:57 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for rpi_gpio2 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.loader] Loaded rpi_gpio2 from custom_components.rpi_gpio2
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up webhook
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up config
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up api
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up system_health
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up lock
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up rpi_gpio
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.8 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain hdmi_cec took 0.8 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.components.lock] Setting up lock.template
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setting up search
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.5 seconds.
2020-03-29 12:55:57 INFO (MainThread) [homeassistant.helpers.storage] Migrating person storage from 1 to 2
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.4 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain rpi_gpio took 0.9 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.components.switch] Setting up switch.rpi_gpio
2020-03-29 12:55:58 INFO (SyncWorker_13) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2020-03-29 12:55:58 INFO (SyncWorker_10) [homeassistant.loader] Loaded fan from homeassistant.components.fan
2020-03-29 12:55:58 INFO (SyncWorker_0) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2020-03-29 12:55:58 INFO (SyncWorker_6) [homeassistant.loader] Loaded light from homeassistant.components.light
2020-03-29 12:55:58 INFO (SyncWorker_1) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain script took 2.2 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up climate
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up fan
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain fan took 0.0 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up cover
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up light
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up sensor
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds.
2020-03-29 12:55:58 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.climate] Setting up climate.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.fan] Setting up fan.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.cover] Setting up cover.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.mqtt
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setting up mqtt_statestream
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt_statestream took 0.0 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.1 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setting up rpi_gpio2
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain lock took 1.7 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.light] Setting up light.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.lock] Setting up lock.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 1.9 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.switch] Setting up switch.zwave
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain rpi_gpio2 took 0.0 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.rpi_gpio2
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain person took 1.9 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.helpers.storage] Migrating onboarding storage from 1 to 3
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2020-03-29 12:55:59 INFO (SyncWorker_19) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2020-03-29 12:55:59 INFO (SyncWorker_11) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2020-03-29 12:55:59 INFO (SyncWorker_19) [homeassistant.loader] Loaded group from homeassistant.components.group
2020-03-29 12:55:59 INFO (SyncWorker_7) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2020-03-29 12:55:59 INFO (SyncWorker_14) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2020-03-29 12:55:59 INFO (SyncWorker_13) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setting up frontend
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setting up panel_iframe
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain panel_iframe took 0.0 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.7 seconds.
2020-03-29 12:55:59 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.zwave
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.components.updater] Submitted analytics to Home Assistant servers. Information submitted includes {}
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 5.5 seconds.
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.setup] Setting up automation
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds.
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 6.60s
2020-03-29 12:56:02 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-03-29 12:56:03 INFO (SyncWorker_8) [homeassistant.components.zwave] Starting Z-Wave network...
2020-03-29 12:56:03 INFO (SyncWorker_8) [openzwave] Start Openzwave network.
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Unlock Frontdoor when Shed Domotica Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Unlock Backdoor when Shed Domotica Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Cupboard Domotica Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Toggle Livingroom Light Table when Domotica Shed Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Toggle Frontdoor Light when Domotica Shed Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Toggle Livingroom Light Wall when Domotica Shed Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Toggle Hallway Light when Domotica Shed Offline
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.core] Timer:starting
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Wall 4
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Amplifier Off
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Refrigerator
2020-03-29 12:56:03 INFO (SyncWorker_1) [pycec] HDMI network starting...
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Shed Fan
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Freezer
2020-03-29 12:56:03 WARNING (ThreadPoolExecutor-1_0) [pycec] Not initialized. Waiting for init.
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Microwave
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Cooker
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Coffee Maker
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Frontdoor Lock
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Central Heater
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Dish Washer
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Washing Machine
2020-03-29 12:56:03 INFO (Dummy-3) [openzwave] Driver ready using library Static Controller version Z-Wave 3.95
2020-03-29 12:56:03 INFO (Dummy-3) [openzwave] home_id 0xf2c06195, controller node id is 1
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Hallway Light
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Tumble Dryer
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Frontdoor Light
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Backdoor Lock
2020-03-29 12:56:03 INFO (ThreadPoolExecutor-0_0) [pycec.cec] found a CEC adapter:
2020-03-29 12:56:03 INFO (ThreadPoolExecutor-0_0) [pycec.cec] port:     RPI
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Plasmadisc
2020-03-29 12:56:03 INFO (ThreadPoolExecutor-0_0) [pycec.cec] vendor:   0x2708
2020-03-29 12:56:03 INFO (ThreadPoolExecutor-0_0) [pycec.cec] product:  0x1001
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Reserve 1
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Plasmaball Left
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Reserve 2
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Plasmaball Right
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Frontdoor Nameplate
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Cinema Virtual Reality Video Transmitter
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Frontdoor Reader
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Wall 3
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Cinema Virtual Reality Lighthouse Front
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Backdoor Reader
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Cinema Virtual Reality Lighthouse Back
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Stairway Light
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Frontdoor Phone
2020-03-29 12:56:03 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Guestroom Light
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Frontdoor Pushbutton
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Cinema Light
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Backdoor Pushbutton
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Clock
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Television On
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Cupboard Ups
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Television Off
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Kitchen Light
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Streambox On
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Bar 1
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Streambox Off
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Bar 2
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Bar 3
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Bar 4
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Bluray Player On
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Wall 1
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Bluray Player Off
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Wall 2
2020-03-29 12:56:04 WARNING (ThreadPoolExecutor-1_0) [pycec] Not initialized. Waiting for init.
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Amplifier On
2020-03-29 12:56:04 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Livingroom Light Table
2020-03-29 12:56:04 INFO (ThreadPoolExecutor-0_0) [pycec.cec] connection opened
2020-03-29 12:56:05 INFO (ThreadPoolExecutor-1_0) [pycec] Looking for new devices...
2020-03-29 12:56:05 INFO (MainThread) [homeassistant.components.switch] Setting up switch.hdmi_cec
2020-03-29 12:56:05 INFO (SyncWorker_2) [homeassistant.components.hdmi_cec.switch] Setting up HDMI devices ['hdmi_cec.hdmi_0']
2020-03-29 12:56:06 INFO (MainThread) [homeassistant.components.switch] Setting up switch.hdmi_cec
2020-03-29 12:56:06 INFO (SyncWorker_11) [homeassistant.components.hdmi_cec.switch] Setting up HDMI devices ['hdmi_cec.hdmi_5']
2020-03-29 12:56:06 INFO (SyncWorker_17) [homeassistant.components.hdmi_cec.switch] Setting up HDMI devices ['hdmi_cec.hdmi_8']
2020-03-29 12:56:35 INFO (ThreadPoolExecutor-1_0) [pycec] Looking for new devices...
In the browser I just see:
Also tried to start with minimal configuration as in:
configuration.yaml
homeassistant:
frontend:
config:
http:
  server_port: 8123
and started manually as root with:
root@cupboard-domotica:/home/homeassistant # /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass --config=/home/homeassistant/.homeassistant --log-file=/var/log/homeassistant.log --pid-file=/home/homeassistant/.homeassistant/homeassistant.pid
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.bootstrap] Config directory: /home/homeassistant/.homeassistant
2020-03-29 17:57:11 INFO (SyncWorker_6) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2020-03-29 17:57:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2020-03-29 17:57:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded http from homeassistant.components.http
2020-03-29 17:57:11 INFO (SyncWorker_4) [homeassistant.loader] Loaded config from homeassistant.components.config
2020-03-29 17:57:11 INFO (SyncWorker_6) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2020-03-29 17:57:11 INFO (SyncWorker_8) [homeassistant.loader] Loaded zwave from homeassistant.components.zwave
2020-03-29 17:57:11 INFO (SyncWorker_5) [homeassistant.loader] Loaded api from homeassistant.components.api
2020-03-29 17:57:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2020-03-29 17:57:11 INFO (SyncWorker_10) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation
2020-03-29 17:57:11 INFO (SyncWorker_16) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2020-03-29 17:57:11 INFO (SyncWorker_11) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2020-03-29 17:57:11 INFO (SyncWorker_18) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2020-03-29 17:57:11 INFO (SyncWorker_19) [homeassistant.loader] Loaded person from homeassistant.components.person
2020-03-29 17:57:11 INFO (SyncWorker_8) [homeassistant.loader] Loaded search from homeassistant.components.search
2020-03-29 17:57:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2020-03-29 17:57:11 INFO (SyncWorker_13) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up http
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up zwave
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.0 seconds.
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.components.zwave] Z-Wave USB path is /dev/ttyACM0
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up person
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up config
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up webhook
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up api
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2020-03-29 17:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.5 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.helpers.storage] Migrating person storage from 1 to 2
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.4 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.4 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up search
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds.
2020-03-29 17:57:12 INFO (SyncWorker_19) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2020-03-29 17:57:12 INFO (SyncWorker_8) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2020-03-29 17:57:12 INFO (SyncWorker_19) [homeassistant.loader] Loaded lock from homeassistant.components.lock
2020-03-29 17:57:12 INFO (SyncWorker_8) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2020-03-29 17:57:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded light from homeassistant.components.light
2020-03-29 17:57:12 INFO (SyncWorker_12) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2020-03-29 17:57:12 INFO (SyncWorker_5) [homeassistant.loader] Loaded fan from homeassistant.components.fan
2020-03-29 17:57:12 INFO (SyncWorker_9) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up climate
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up lock
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain lock took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up switch
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up light
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up cover
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up fan
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain fan took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up sensor
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.climate] Setting up climate.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.lock] Setting up lock.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.switch] Setting up switch.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.cover] Setting up cover.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.fan] Setting up fan.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.1 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.components.light] Setting up light.zwave
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.6 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.helpers.storage] Migrating onboarding storage from 1 to 3
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2020-03-29 17:57:12 INFO (SyncWorker_17) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2020-03-29 17:57:12 INFO (SyncWorker_16) [homeassistant.loader] Loaded group from homeassistant.components.group
2020-03-29 17:57:12 INFO (SyncWorker_17) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2020-03-29 17:57:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded script from homeassistant.components.script
2020-03-29 17:57:12 INFO (SyncWorker_0) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2020-03-29 17:57:12 INFO (SyncWorker_16) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2020-03-29 17:57:12 INFO (SyncWorker_18) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2020-03-29 17:57:12 INFO (SyncWorker_8) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setting up frontend
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 1.35s
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-03-29 17:57:12 INFO (SyncWorker_19) [homeassistant.components.zwave] Starting Z-Wave network...
2020-03-29 17:57:12 INFO (SyncWorker_19) [openzwave] Start Openzwave network.
2020-03-29 17:57:12 INFO (MainThread) [homeassistant.core] Timer:starting
But still only a blue banner without login or frontend.
I’m clueless…
Looks like the same problem as Upgrading to 0.93 frontend not loading correctly but there’s no solution.
How to debug?
Any help will be appreciated.
Is lovelace in yaml mode?
I don’t know, where can I check it?
your not the only one…
these updates sucks
1st my squeelite didnt start anymore because “someone” uses pulse on my system guess who
2nd my floorplan doesnt run anymore
3rd same blue "screen2 like you
4th i
d open my drawer got my backup ssd and get the 0.103.4 System back again
hopefully you got a backup
DONT fix it - if its not broken
After hours of trying to figure this out, I finally found a solution, somehow homeassistant or the frontend was corrupted.
Maybe you can try these too.
The steps I did to resolve are:
root@cupboard-domotica:/home/donald # systemctl stop homeassistant.service
root@cupboard-domotica:/home/donald # sudo su -s /bin/bash homeassistant
homeassistant@cupboard-domotica:/home/donald $ cd /srv/homeassistant
homeassistant@cupboard-domotica:/srv/homeassistant $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@cupboard-domotica:/srv/homeassistant $ pip3 install home-assistant-frontend homeassistant --force-reinstall --no-dependencies --no-cache-dir
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting home-assistant-frontend
  Downloading https://www.piwheels.org/simple/home-assistant-frontend/home_assistant_frontend-20200318.1-py3-none-any.whl (38.0 MB)
     |████████████████████████████████| 38.0 MB 8.6 MB/s
Collecting homeassistant
  Downloading homeassistant-0.107.7-py3-none-any.whl (6.7 MB)
     |████████████████████████████████| 6.7 MB 3.0 MB/s
Installing collected packages: home-assistant-frontend, homeassistant
  Attempting uninstall: home-assistant-frontend
    Found existing installation: home-assistant-frontend 20200318.1
    Uninstalling home-assistant-frontend-20200318.1:
      Successfully uninstalled home-assistant-frontend-20200318.1
  Attempting uninstall: homeassistant
    Found existing installation: homeassistant 0.107.7
    Uninstalling homeassistant-0.107.7:
      Successfully uninstalled homeassistant-0.107.7
Successfully installed home-assistant-frontend-20200318.1 homeassistant-0.107.7
(homeassistant) homeassistant@cupboard-domotica:/srv/homeassistant $ deactivate
homeassistant@cupboard-domotica:/srv/homeassistant $ exit
root@cupboard-domotica:/home/donald # service homeassistant start
Regards,
Donald.
