Upgrading to 0.93 frontend not loading correctly
So I just upgraded from something like version .67ish to the latest (0.93.1) and after upgrading (and updating all of my configuration to accommodate the changes) the frontend no longer loads fully. All I get is the blue bar and nothing else
When I downgrade to 0.92.0 everything works correctly, and I can see everything. I even went so far as to start with a blank config file, only containing the bare minimum to get home assistant up and running, but still nothing but that blue bar. I tried in multiple browsers, clearing cache, incognito mode, nothing changed. I read that there was a breaking change with the frontend component.
Convert frontend to do client-side modern JS detection (@balloob - #23618) (frontend docs) (breaking change)
However, no matter how I set the frontend: component, nothing works. I tried every combination of frontend outlined in the link above
frontend:
  javascript_version: auto\es5\latest (tried all 3)
and no change, still just the blue bar up on top. I’m probably missing something dumb, so if anyone has any ideas, I’m all ears.
SystemInfo: Windows Server 2016
PythonVersion: 3.7.3
Chrome: 74.0.3729.157
Here is my bare bones configuration.yml that I tested, just to see if my full blown config file had issues
homeassistant:
  latitude: [redacted]
  longitude: [redacted]
  elevation: 376
  unit_system: imperial
  time_zone: [redacted]
http:
  api_password: !secret http_password
  base_url: [redacted]
  server_port: 443
  ssl_certificate: [redacted]
  ssl_key: [redacted]
  login_attempts_threshold: 5
frontend:
input_number:
  weekday_off_peak_number:
    name: Weekday Off Peak
    initial: 70
    min: 50
    max: 90
    step: 1
    mode: box
and here’s the log
2019-05-21 16:32:58 WARNING (MainThread) [homeassistant.components.http] Configuring api_password via the http component has been deprecated. Use the legacy api password auth provider instead. For instructions, see https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password
2019-05-21 16:32:58 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
