Yes your question is totally off topic in this thread.
Can I ask a silly question?
How do you get to the /www folder. “/local/“
Do I use Studio Code server?
Yes you could use studio code server, or the commandline, or possibly the easies it the Samba Share Addon. The directory under your configuration directory called www is mapped to http://yourhomeassistant:8123/local
The configuration directory is called /config in home assistant operating system (HAOS), and other directories for other install methods.
This is my home assistant samba addon in windows file explorer
When its on a http://yourhomeassistant:8123/local it stops working outside my Home Network, I’m using Cloudflare. Is it this directory?
Samba Addon is new to me! where is this installed from? Home Assistant or windows?
thanks
.local is only accessible on your home network.
Samba Addon is a Home Assistant add-on. Go to Settings, Add0ns and click on the Addon Store.
Thanks, yes I know local in only on the home network, I was wondering how to get to Samba I did not fully understand the Answer given. And I already have Samba installed, but Ive never used it. Do we Ftp to the files on my server? I’m also not using Yellow, Green, or a Raspberry Pi to run a Home Assistant it’s on an Ikoolcore R2 so I’m not fully sure about the www that is mentioned.
Why won’t you read the damn docs addons/samba/DOCS.md at de30123a5c930830590ae2db0c946f4d4273968d · home-assistant/addons · GitHub
How do I find out my servers address to log in to Samba as this information is not in the Docs it just says go to your router, and like I have said many times to you I have got Dyslexia so please be patient and not get Dammed at me
According to my Router, this is the IP address into Home Assistant but its not logging in!
Obfuscating a local IP address is a complete waste of time. Almost everyone’s Home Assistant is on 192.168.1.x
On a PC, ping homeasstsiant.local /4
This will give you something like 192.168.1.57
Enter this on the address bar of your file explorer: \192.168.1.57\
Just correcting a few typos: it’s ping homeassistant.local /4 and \\192.168.1.57\ (notice the two \)
Thanks! this is doing nothing at all! I know the IP address of home Assistant but I just cannot get to it! I’m using a Ikoolcore will this make any difference?
ok great I got in now finely, but the ping never worked at all! I had to go to the router to find the IP address and also supervisor to see the ip address. then I added it to Explorer with \\ Ip address
which then gave me the folders.
Looking at it just the same as in Studio Code Server so why Im I getting told to go here?
But at least I know now thanks!
I have now started a new topic for the
Dwains Dashboard Dexcom position!
Hope its spelt correctly enough for you! x fingers it is ![]()
Because…
And …
Thanks for the reminder, so how do I get lights now to go red when low Blood levels and Blue when normal levels. I’ve tried to do it but the lights go red when Im low with the sensor but when back to Normal the light still stops red! Im not sure what I’m doing wrong on this automation or how to use the helpers I made instead.
I’m also not sure what code to post to give you some clues what I’m trying to do! Can you help on thid in here? As its Dexcom CGM I’m trying to do it with.
I thought it might be better or easier to use the Config.yaml file but I know this can mess HA up so I have to be careful on doign so.
This what I have at moment and also now made two Threshold Helpers but not added or attempted to add yet, as Im not sure how too or where too.
alias: Turn Lights on if low - colour
description: Turns light on if low with colour change to red
- platform: numeric_state
entity_id:
- sensor.blood_sugar
above: 0
below: 70
entity_id:
above: 75
entity_id:
for:
hours: 0
minutes: 2
seconds: 0
id: Normal-readings-turn off light
above: 76
condition: []
- choose:
- conditions:
- condition: time
after: "22:00:00"
before: "08:00:00"
weekday:
- sun
- mon
- tue
- wed
- thu
- fri
- sat
sequence: []
- conditions:
- condition: trigger
id:
- Low-readings
sequence:
- action: light.turn_on
entity_id: light.bedroom_led
data: {}
entity_id: light.bed_side_lamp
rgb_color:
- 255
- 0
- 0
- conditions:
id:
- normal-readings
sequence:
- action: light.toggle
entity_id:
- light.bed_side_lamp
- light.bedroom_led
rgb_color:
- 5
- 159
- 255
- action: light.turn_off
entity_id:
- light.bedroom_led
data: {}
mode: single
Low Blood Reading Helper:
High Blood Reading Helper:
Normal Blood Range:
I am far, far from a YAML expert, but I suspect that it is because you are trying to put two triggers in one automation. I do something similar to this, but I use two automations. One for when the glucose goes low and another when it goes up.
Keep it simple.
Yes, I normally do it like you say but got used to doing more triggers! But this trigger needs 3 now has one for Low one for High and one for Normal
The Normal one wants to be Between 72 and 162 and be Blue light:
The Low needs to be 72 and anything below that: For red Light:
And High needs to be 162 and anything after for Red colour again.
They are helpers I have made but not added them to the Automation as I do not know how to add helpers yet!
But I will try to see if doing two Automation might help!
I know the red light comes on ok and goes off ok but it just does not go back to blue colour.
The helper is simply an entity. You use its state in an automation like any other entity. Do you mean how to create helpers? You just go to settings → devices → helpers and click on “Add a helper”. For this you probably want a number helper.
I mean to add it to here!
Or will it be at the trigger part when I add them?
I know how to Make a helper!
e.g
I made 3 helpers!
I have made a new Topic here to ask how to do it!
How do i add a threshold helper to an automation
I think I have figured how to get the Helper into a Automation with getting the entity of the helper!
Helper
Entity:
binary_sensor.normal_blood_reading
And add the name I gave the Helper to the Entity State then give it a Id name
The add an
