It was my first attempt to create a KiCAD Project (just watched a YouTube Video to design this one).
Please (to the gods of PCB Designing) help if this PCB is “ok” to go. If yes I’ll order this one via PCB
Way. Also feel free to contribute if you want to - just let me know!
It’s one resistor per FSR. Not sure why you need a custom PCB for it, but sure your design will work. The only recommendation I’d make would be to exclude the ground plane from the area under the ESP antenna as per the ESP hardware guidelines pdf, section 3.1.2
Or you may find you have poor wifi signal strength.
You are very generous with your time and I’m starting to feel encouraged to try this! If you don’t mind I have a few follow up questions:
When I purchase any tools I learned to not cheap out and get the good stuff right away. That being said do you have a suggestion for s soldering iron/setup that will make my life easier and last?
It seems people around here keep mentioning the Wemos D1 Mini. Would that be a good choice? (Also the one I linked is from a company called ACEIRMC. Is Wemos not a brand name?)
I own this multimeter. Would that work? Which of the settings would I need to set it to to measure the FSR resistance?
*What range of resistor pack should I be looking for so I’m all set for this project?
*Would you recommend the FSR linked in the first post or did you use some cheap one from Aliexpress?
Even if I solder it all together it will still be a mess of wires and rather fragile, right? Do you put it all in some sort of case? I have done a breadboard WLED project once but it all fell apart because it was all so fragile. What kind of case would you recommend for a setup like this? I just don’t want things to come apart.
I think I will actually document this build with step by step video instructions so that other N00bs can follow it and learn from it. Would be super cool to have a step by step video tutorial for this amazing project.
The soldering iron I have probably costed about $10-15.
It was probably among the cheapest soldering irons at the time.
You probably get a better tool if you spend more money, but it works fine for me.
Sure WeMos is fine, I have a few of those.
I have not noticed much difference between different normal ESPs, when you get those with displays or other accessories added then they can be harder to use.
I haven’t used that multimeter myself but reading the header and looking at the picture, seems good.
Something like this?
It has all the values that you will ever need.
If you do need a larger value for any reason then you can add two in series.
I haven’t used a FSR as a bed sensor.
I use a pressure mat.
But I have used FSRs and they generally work fine. Not this particular though.
As I said, I don’t recommend a breadboard, possibly a perfboard as above.
But no I don’t have a case for mine. It’s not fragile when you solder it.
You can glue it to the bottom of the bed or tie it.
It will work fine, it’s not that much movements down there.
Hi @tom_i,
It’s not a question of “need.” It’s just a question of “I want to have it”. And besides, I’ve always wanted to play around with KiCAD and see if I can get it to work. . Although this area of clearance (as I can see) is needed for the ESP Baseboard only. Since my design is for a ESP32-Mini which will be installed on 10pin headers (just for beeing flexible if the esp-board will break) I think this is not needed.
Thx for your info. I’ve updated the design toe keep-out the copper area from the ESP32-mini antenna.
Also updated the github-project with new files (schematic, pcb and gerber files). Also post it here just for reference
Could someone help me please. I have build this pressure sensor. But the values are all over the place. I have 2 sensors, but only 1 connected. But it picks up values on both sensors. But constantly fluctuating.
This is the left sensor that is connected:
So I got it working in the end. Probably my Wemos D1 was broken, after experimenting it died on me (wifi gives constantly a brownout - even if there is nothing else in the esphome script/firmware).
When I calculated it as the reading was averaging 880 in bed and overload out of bed (meter goes till 20M), I had to assume a value for R2. I assumed just a little bit above 20M. When I did the formula - it came up with a value for R1 as 47000 (47K). I found a site explaining the Voltage Divider and it had a small tool where you could enter different values so calculate the voltage on the divider.
When I entered 3.3 volt, R1 = 47000, R2 = 880, it would generate a voltage of 0.3 volt. I thought his was a little too low. On the site you play around with the figures and with a R1 = 4.7K it would drop to 0.52 volt. This seemed a little bit safer (don’t know if there is a danger in dropping to 0, a short circuit?).
As the bed has two sides, two the same mattrasses, and the same FSR, I assumed I could take the same values. That didn’t turn out to be the case. I have installed now for the second FSR an R1 = 100K. Before with R1 = 4.7k the in bed voltage would fluctuate from 2.6 to 2.9, now with the R1 = 100K it drops to 0.3 volts. Perhaps still to low but the difference is now larger. Even though the out of bed voltage is now fluctuating between 3.14 (which seems to be the maximum) and 3.0.
Is it bad that the out of bed voltage is fluctuating? And is there a danger in reaching in bed values of 0 volt?
Still the tool works great to test possible voltage out comes and one can adjust accordingly. This is the script in ESPhome that I am using:
Touch sensors work on the same principal. I think with the voltage and the resistors you have more control over sensitivity. But I connected the FSR as a touch sensor, and it worked. However the in bed voltage that the touch sensor read (as the touch sensor registers voltage) would drop to 0 volt. Out of bed it was 3.3 volt. It was too extreme for me.
It looks like the touch sensors work kind of like what we are doing: it can measure the voltage going through the sensor and gnd.
