You measure the FSR resistance without it connected to anything except your meter.
Now that Iāve built a couple of these, Iām thinking about putting them in the guest room which would massively help a handful of automations. But of course, I canāt statically measure for an individual, so I was thinking about the trim pot route, so that itās easily adjustable.
Curious if anybody has done this and what your experience has been?
I use a pot. My reason is that itās in our babyās cot and I want to adjust it over time as she grows.
Iāve used pots on mine, simply for adjustment should it be required. Hereās pic of my unit, it also has a RGB strip for under the bed.
Iāve not had to adjust them yet. but it did make setting up easier.
And this is what it looks like in HA.
Never seen a trimpot look like that. Is that double pot?
Nope, I just got them from aliexpress.
Hmmm, if itās not a double why are there two knobs on it? Never seen one like that.
EDIT: lol just dawned on me. Thatās actually 2 trimpots inside a 3d printed box??
Gotcha thanks. Just for my own learning, wouldnāt the resistance change if the FSR were connected to, say, 4 foot leads to the ESP32? Why is okay to ignore that ā because itās immaterial?
Again, Iām not doubting you. Just trying to understand. TIA.
The loop resistance of your cables will be measured in hundredths of Omhs at most. Compared to the Kilo-Ohms of the FSR that is for all intents and purposes equivalent to zero Ohms.
Sorry, I was out for a couple of days.
Yes, Iām using the filters:
## FSR input voltage
- platform: adc
pin: ${gpio}
attenuation: 11db
unit_of_measurement: "V"
device_class: "voltage"
state_class: "measurement"
icon: mdi:sine-wave
update_interval: 0.5s
filters:
- sliding_window_moving_average:
window_size: 10
send_every: 1
- or:
- throttle: 180s
- delta: 0.02
Iām using these FSR and the cables are about 1m long.
I use a classic phone charger with a USB cable for both the ESP32 and D1 Mini
Your product link is broken. My cables are longer than that. ![]()
Really? Hereās a picture then. I guess itās basically the same as everyone.
Iām doing some tests and so far, it seems that my connections between the cable and the FSR that might be the problem (maybe Iām just no good at crimping
). Iāll keep you posted!
EDIT: it turns out that the tape was incorrectly positioned to avoid contact between the 2 connectors whereas it was precisely to avoid that. Problem solved and thanks for your feedback!!
Final got mine all up and running - Thanks!
I have a single ESP32 configured to run x2 sensors (each side of bed).
Any ideas what could be causing the very slow response on my side?
Is there likely anything obvious that Iām missing or likely worth trying to re-do the resistor sizing?
Feel like I got the R value pretty good as there is a nice large range between min and max volt.
I used the same steps for setting up my partners side and that is fantastic, very responsive - fast enough to se when she got up for the toilet.
My side however takes a hours to get the voltage back up to max when out of the bed.
Definitely not fast enough to catch my toilet breaks.
While my side works in general, it reacting so slowly make it externally hard to create automation that react quickly to it.
I can lower the trigger point so it triggers me āout of bedā sooner but, that will delay the āin bed triggerā and vice versa.
I know it can and should be much better as I can have the desired result with my partners side.
How is it mounted? Can it be that whatever it is attached to remains deformed for a longer time compared to your partnerās?
Itās under a foam mattress on a rigid wood slate.
Everything in terms of bed/mounting is exactly the same for both sides.
(R value was set for her wight but, still works perfectly fine for me on her side too).
Iāll try re-taping the end down (on the very tip and looser). See what that does for my R value calculations and see how it goes over night.
The end of the FSR needs to be un-taped. It has to be able to ābreatheā through it.
I had heat-shrink around each terminal and a larger bit over the end as a āstrain reliefā (same as the photos in your instructions at the top) but, removed the larger bit in order to ensure the end is not covered.
The other end has a bit of painters tape lightly sitting over the very end to hold it in place.
(same as the photos in your instructions at the top).
The side thatās working perfectly on my partners side looks exactly as yours did in your initial instruction photos too.
Iām already on the second strip for my side of the bed and while this one is better (slow to go min-max volt), it is still not as good as my partners sideā¦
I have done the above changes on my side and after doing so, the new R value is 76k (30k previously) so, hopefully thatās a sign that the changes may have a positive effect.
Will see how it goes tonight!
Giving this a try, I understand thereās a formula, I just donāt understand the formula, lol.
If I have 16.5k ohms (in) and .75k ohms (out)
Do I then go 16500x750 = 12375000
Square root of the is 3517.811
So does that mean I need a 3.5k resistor.
Or have I botched the formula, lol.
That is correct. Nearest value will do. 3k3, 3k6 or 3k9.
Thereās something wrong with your measurements though. The value should be higher resistance out of bed. Did you get them back to front?
Makes no difference to the calculation.
