FSR - the best bed occupancy sensor
Ah perfect, thank you for clarifying.
I assume a 3k3, 3k6 is also just a 3.3k, 3.6k?
Yes sorry I got them back the front .75 In bed
Correct again. Writing 3k6 instead of 3.6k makes it a lot harder to make mistakes. Especially when schematics were printed in the “olden days”, the decimal point could often go missing.
Ah yes that’s a good point. Thank you
I assume I can connect two FSR’s to the one esp board for bigger bed?
Yeah someone has done that in a post above.
For those who have two FSRs connected to a single ESP board…
I had a single bed occ sensor working great, so I just added a second FSR for the other side of the bed to the same ESP32. BTW, I’m using trim pots, which is a great add for flexibility (use-case = guest room) with thanks to @RoadkillUK
But now I’m stuck at the YAML step. At first I assumed (noob) that I could copy/paste the binary_sensor, sensor, and number sections of the OP’s YAML, change the names and IDs, and then set it to the appropriate pin. But I’m guessing my approach is wrong because I get “Invalid YAML syntax” and “Duplicate key” errors.
I’ve been looking online for documentation on how to add a second device (or would that be entity?) to an existing ESP, but can’t find anything useful. Any pointers? TIA…
Hi Mark, approach sounds right, I’ve done the same thing & it’s working nicely. Change all the names & the pin number. From the error, there might be one more place needs changed. Yes, send YAML.
Here’s my code … Good luck :slight_smile:
substitutions:
  devicename: bed-sensor
  upper_devicename: Bed Sensor
  ssid: SSID
esphome:
  on_boot:
    priority: 50
    then:
      - light.turn_off: bedlight
esp32:
  board: nodemcu-32s
wifi:
  networks:
    - ssid: $ssid
  ap:
    ssid: $upper_devicename
web_server:
  port: 80
logger:
api:
  encryption:
    key: !secret api_password
ota:
  password: !secret ota_password
captive_portal:
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812
    pin: GPIO25
    num_leds: 30
    on_turn_on:
    - delay: 5min
    - light.turn_off:
binary_sensor:
    name: Right ${upper_devicename}
    device_class: occupancy
    lambda: |-
      if (id(right_bed_sensor).state > id(right_trigger_level).state) {
        return true;
        id(right).set_icon("mdi:bed");
      } else {
        return false;
        id(right).set_icon("mdi:bed-empty");
    name: Left ${upper_devicename}
    lambda: |-
      if (id(left_bed_sensor).state > id(left_trigger_level).state) {
        return true;
        id(left).set_icon("mdi:bed");
      } else {
        return false;
        id(left).set_icon("mdi:bed-empty");
    name: Single ${upper_devicename}
    lambda: |-
      if (id(right).state ||
          id(left).state) {
        return true;
        id(single).set_icon("mdi:bed");
      } else {
        return false;
        id(single).set_icon("mdi:bed-empty");
    name: Both ${upper_devicename}
    lambda: |-
      if (id(right).state &&
          id(left).state) {
        return true;
        id(both).set_icon("mdi:bed");
      } else {
        return false;
        id(both).set_icon("mdi:bed-empty");
  - platform: adc
    pin: GPIO34
    attenuation: 11db
    name: Right ${upper_devicename} Voltage
    icon: mdi:bed
    update_interval: 0.5s
    filters:
      - sliding_window_moving_average:
          window_size: 5
          send_every: 1
      - or:
          - throttle: 180s
          - delta: 0.02
  - platform: adc
    pin: GPIO33
    attenuation: 11db
    name: Left ${upper_devicename} Voltage
    icon: mdi:bed
    filters:
          window_size: 5
          send_every: 1
      - or:
          - throttle: 180s
          - delta: 0.02
number:
    name: Right Bed Threshold
    optimistic: true
    restore_value: True
    min_value: 0
    max_value: 3.5
    step: 0.05
    icon: mdi:arrow-collapse-down
    unit_of_measurement: V
    name: Left Bed Threshold
    optimistic: true
    restore_value: True
    min_value: 0
    max_value: 3.5
    step: 0.05
Nothing there jumps out at me.
Mine’s a little simpler:
esphome:
  friendly_name: esp1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp1 Fallback Hotspot"
    password: "xxxxxxxxx"
captive_portal:
binary_sensor:
    name: "Master Bed Left Occupancy"
    lambda: |-
      if (id(master_bed_left_sensor).state < id(trigger_level).state) {
        return true;
      } else {
        return false;
    name: "Master Bed Right Occupancy"
    lambda: |-
      if (id(master_bed_right_sensor).state < id(trigger_level).state) {
        return true;
      } else {
        return false;
  - platform: adc
    pin: GPIO34
    attenuation: 11db
    name: "Master Bed Left Sensor"
    icon: mdi:bed
    filters:
          window_size: 10
          send_every: 1
      - or:
          - throttle: 180s
          - delta: 0.02
  - platform: adc
    pin: GPIO35
    attenuation: 11db
    name: "Master Bed Right Sensor"
    icon: mdi:bed
    filters:
          window_size: 10
          send_every: 1
      - or:
          - throttle: 180s
          - delta: 0.02
number:
    name: Master Bed Trigger Level
    optimistic: true
    restore_value: true
    min_value: 0
    max_value: 3.5
    step: 0.05
I just use the Single and Both sensors in conjunction with the alarm so that it will set if one of us is in bed and the other is out. Also I use the Both in bed sensor to run the Daily Reset script.
Thanks guys – I was able to get it to work by paralleling yours as samples. Thank you.
I still got some voltage fluctuations, and after several tests, I noticed that using a multi-USB charger, either from Aliexpress or Amazon, do actually generate these fluctuations:
Has anyone ever encountered this? Is there an electronic or software solution for using a multi-USB charger with an ESP32? Or should I change my multi-USB charger for a better one?
Thanks!
Yes I’ve had issues with noisy USB power supplies before (another ESPHome project). Throw the Ailiexpress one away and get a better one.
Got it. Even this one or this one give me the exact same result. Any relevant multiUSB wall charger brand/model?
Or is there any electronic workaround (resistor/capacitor…) to mitigate this issue?
Thanks!
for some reason, mine isnt working, sensor keeps saying 3.13V
seems to be sending data, just not the correct data, doesnt matter if on or off the bed, just seems to always show 3.13V
i assume something isnt quite right though, just unsure what that would be. its an ESP32
Check your wiring.
I was wondering that, maybe I cooked the resistor.
I have a usb port on my esp board. I can use that to power it yeh? I assumed yes as there’s still 5v and 3v3 at the pins.
Wiring seems fine, same with resistor. I power it with a usb, then soldered an earth out wire to the board. Put one end of the resistor to G34 and the other end to 3v3 along with a wire coming off that same length as my earth and they are what goes to my fsr.
Excuse the ugliest of it. But it’s is what I have.
I think I know what I did wrong, I did the power wire out to my fsr on the 3v3 and not the G34, I’ll revise and retest
Ha! Yep that will do it.
Success, 0.7-0.8V in bed, goes to 2.8v ish out.
Thank you!
What kind of terminals/pre made wires do I need so I can just plug and play wires instead of trying to solder them to the dev board pins
