Well I thought I followed the instructions, maybe not. I get this error when trying to add the integration.
It just gets stuck on trying to add the integration for the first time:
Logger: homeassistant.util.package
Source: util/package.py:123
First occurred: 18:28:46 (2 occurrences)
Last logged: 18:30:33
Unable to install package reverse-geocode==1.4.1: error: subprocess-exited-with-error × Preparing metadata (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [34 lines of output] Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module> main() File "/usr/local/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main json_out['return_val'] = hook(**hook_input['kwargs']) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel whl_basename = backend.build_wheel(metadata_directory, config_settings) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-qbiklxe1/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 1020, in wrapper return func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-qbiklxe1/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 1073, in build_wheel with _project(config_settings) as project: File "/usr/local/lib/python3.12/contextlib.py", line 137, in __enter__ return next(self.gen) ^^^^^^^^^^^^^^ File "/tmp/pip-build-env-qbiklxe1/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 947, in _project yield Project(source_dir, build_dir, meson_args, editable_verbose) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-qbiklxe1/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 662, in __init__ self._meson = _get_meson_command(pyproject_config.get('meson')) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-qbiklxe1/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 982, in _get_meson_command meson_version = subprocess.run(cmd + ['--version'], check=False, text=True, capture_output=True).stdout ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/subprocess.py", line 548, in run with Popen(*popenargs, **kwargs) as process: ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/subprocess.py", line 1026, in __init__ self._execute_child(args, executable, preexec_fn, close_fds, File "/usr/local/lib/python3.12/subprocess.py", line 1953, in _execute_child raise child_exception_type(errno_num, err_msg, err_filename) PermissionError: [Errno 13] Permission denied: 'meson' [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: metadata-generation-failed × Encountered error while generating package metadata. ╰─> See above for output. note: This is an issue with the package mentioned above, not pip. hint: See above for details.
Unable to install package reverse-geocode==1.4.1: error: subprocess-exited-with-error × Preparing metadata (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [34 lines of output] Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module> main() File "/usr/local/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main json_out['return_val'] = hook(**hook_input['kwargs']) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel whl_basename = backend.build_wheel(metadata_directory, config_settings) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-np3ush57/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 1020, in wrapper return func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-np3ush57/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 1073, in build_wheel with _project(config_settings) as project: File "/usr/local/lib/python3.12/contextlib.py", line 137, in __enter__ return next(self.gen) ^^^^^^^^^^^^^^ File "/tmp/pip-build-env-np3ush57/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 947, in _project yield Project(source_dir, build_dir, meson_args, editable_verbose) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-np3ush57/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 662, in __init__ self._meson = _get_meson_command(pyproject_config.get('meson')) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/tmp/pip-build-env-np3ush57/overlay/lib/python3.12/site-packages/mesonpy/__init__.py", line 982, in _get_meson_command meson_version = subprocess.run(cmd + ['--version'], check=False, text=True, capture_output=True).stdout ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/subprocess.py", line 548, in run with Popen(*popenargs, **kwargs) as process: ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/subprocess.py", line 1026, in __init__ self._execute_child(args, executable, preexec_fn, close_fds, File "/usr/local/lib/python3.12/subprocess.py", line 1953, in _execute_child raise child_exception_type(errno_num, err_msg, err_filename) PermissionError: [Errno 13] Permission denied: 'meson' [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: metadata-generation-failed × Encountered error while generating package metadata. ╰─> See above for output. note: This is an issue with the package mentioned above, not pip. hint: See above for details.
After I hard refresh the page and try to install it again, I get this:
Logger: homeassistant.config_entries
Source: config_entries.py:2757
First occurred: 18:31:00 (1 occurrences)
Last logged: 18:31:00
Error occurred loading flow for integration fuel_prices: No module named 'pyfuelprices'
