There is still no solution for the Dutch stations? Directlease has blocked my for months
Not yet, I could proxy the requests through another server, there is a massive list here full of proxies:
https://proxylist.geonode.com/api/proxy-list?limit=500&page=1&sort_by=lastChecked&sort_type=desc
Would be concerned about privacy taking this approach. I need to see if anything else uses the directlease data.
2024.6.0b2 has just been released which should fix gasbuddy
Seems like the update fixed the setup error! Thank you for making that update so quickly. I am running into another issue with the integration however. So the area is currently defined as a 10 mile radius from my home however no entities are being generated at all. I know there are multiple gas stations within that radius so I’m unsure why the entities aren’t being generated.
Do these gas stations appear on the GasBuddy app? I’ve created a quick setup and picked a random city in the states and I’m seeing a number of entities created:
If you PM me some coordinates near where you are I can try with your config.
Is there support for New Zealand?
Not yet, although I have identified gaspy as a potential data source for NZ.
Support for New Zealand now added.
Sorry, for which integration is this? is this with ha-fuelprices?
Yes it is.
Sorry, but what source do I select when setting this up?
Data Collection Source?
If you leave it blank, it should automatically select based on what areas you have defined.
Damn, im still getting errors when attempting to configure this.
Logger: homeassistant.config_entries
Source: config_entries.py:594
First occurred: 22:37:59 (3 occurrences)
Last logged: 23:21:23
Error setting up entry Fuel Prices for fuel_prices
File "/config/custom_components/fuel_prices/__init__.py", line 67, in async_setup_entry
File "/usr/local/lib/python3.12/site-packages/pyfuelprices/__init__.py", line 37, in update
await asyncio.gather(*coros)
File "/usr/local/lib/python3.12/site-packages/pyfuelprices/__init__.py", line 31, in update_src
await s.update(areas=a, force=f)
File "/usr/local/lib/python3.12/site-packages/pyfuelprices/sources/austria/spritpreisrechner.py", line 117, in update
response_raw = json.loads(await self._send_request(url))
File "/usr/local/lib/python3.12/site-packages/pyfuelprices/sources/austria/spritpreisrechner.py", line 40, in _send_request
async with self._client_session.get(
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1197, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 428, in _request
raise RuntimeError("Session is closed")
RuntimeError: Session is closed
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/fuel_prices/__init__.py", line 73, in async_setup_entry
custom_components.fuel_prices.CannotConnect
What version are you using? The source of those errors seem to relate to code on different lines than what is reported.
Also, spritpreisrechner is a source for Austria so seems something is wrong with your configuration if you are expecting New Zealand.
Thats weird, I just freshly cloned the repository after you posted that its working for new zealand.
Maybe my long and lat are incorrect? But i’m pretty sure im using latest version unless i’ve done something wrong.
I did not specify a source as you suggested.
The zone it is using is my HA zone, so it cant be wrong. Im so confused haha.
Please ensure you are using the releases via HACS and not cloning the repository as the releases contain correct version keys.
Ok damn ok sorry, got it.
I’ve added it via HACS, now seems to be working, however, does this create any entites?
Still nothing is showing on my Map
This should create entities representing fuel stations providing they are found within defined areas and available via data sources.
If this is trying to pull Austria for you rather than New Zealand, you might want to delete the config entry and setup again but manually select “PetrolSpy” as the data source for NZ (available sources are here GitHub - pantherale0/pyfuelprices: An expandable Python fuel prices library).
Its worth noting that if the lat/long is incorrect, it still won’t return expected results. You can use a tool like https://www.latlong.net/ or OpenStreetMaps to get the lat/long. The home area will have a set radius of 5 miles by default, if no stations are within this area you might need to expand this radius or choose another centre point.
