Fun with custom:button-card
I looked at it… must have been late. i see it now. Thank you…
custom_fields:
  temp: >
      return `<ha-icon
        icon="mdi:thermometer"
        Style="width 22px; height: 22px; color: yellow;">
        </ha-icon><span>${states['sensor.main_floor_thermometer_temperature_2'].state}°C`]]]
nice yu9 it it working, though Style should really be style…
also the state can use the built-in helpers function lokalize, so you int need to add the unit anymore
look it up, its a real powerful option of button-card
helpers.localize(entity)
if you use the entity, or, eg
return helpers.localize(states[afstand],undefined,0);
if you want to set the rounding.
not you dont need to add .state anymore when using the helpers, it just requires the ‘state’ entity_id
so in your case
would become
${helpers.localize(states['sensor.main_floor_thermometer_temperature_2'])
I’ve gotten rid of all units on all cards like that, just let the system take care of that.
the Processor button with all the custom_fields uses:
custom_fields:
  temp: >
    [[[ return `<ha-icon icon=mdi:thermometer
                <span style='width:15px; color: var(--state-color);'> </ha-icon>
                ${helpers.localize(entity)}</span>`; ]]]
  cpu: >
    [[[ return `<ha-icon icon=mdi:server style='width:12px;'> </ha-icon>
                Cpu: <span style='color: var(--cpu-color);'>
                ${helpers.localize(states['sensor.processor_use'])}</span>`; ]]]
  ram: >
    [[[ return `<ha-icon icon=mdi:memory style='width:12px;'></ha-icon>
                Ram: <span style='color:var(--ram-color);'>
                ${helpers.localize(states['sensor.memory_use_percent'])}</span>`; ]]]
  disk: >
    [[[ return `<ha-icon icon=mdi:harddisk style='width:12px;'></ha-icon>
                Disk: <span style='color:var(--disk-color);'>
                ${helpers.localize(states['sensor.disk_use_percent_home'])}</span>`; ]]]
in my setup :wink:
Just find out what’s the original value of the property (with code inspector), and then assign that value if your condition isn’t met. You can also try values like ‘unset’, ‘initial’, ‘inherit’.
- color: "[[[ return variables.use_state ? variables.icon_color : 'unset'; ]]]"
Can anyone guide me on setting colors for light & dark mode? I’m missing a step or 2
Example of the problem
One set of lights:
type: custom:vertical-stack-in-card
cards:
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: markdown
        content: |
          ### Master Bedroom
        card_mod:
          style: |
            ha-card {
              height: 100%;
              width: 250%
  - type: horizontal-stack
    cards:
      - type: custom:button-card
        entity: switch.security_booth_lights_l1
        icon: mdi:lightbulb-group
        show_name: false
        show_icon: true
        color_type: card
        aspect_ratio: 1/1
        styles:
          grid:
            - grid-template-areas: "\"i\" \"n\" \"s\""
            - grid-template-columns: 1fr
            - grid-template-rows: 1fr min-content min-content
          img_cell:
            - align-self: center
            - text-align: start
          name:
            - justify-self: center
            - font-weight: normal
          state:
            - justify-self: start
        state:
          - value: "off"
            styles:
              card:
                - color: SlateGrey
                - background-color: var(--switch-button-off-color) !important;
          - value: "on"
            styles:
              card:
                - color: White
                - background-color: var(--switch-button-on-color) !important;
        color_type: blank-card
        entity: switch.security_booth_lights_l2
        icon: mdi:television-classic
        show_name: false
        show_icon: true
        color: auto
        color_type: card
        aspect_ratio: 1/1
        styles:
          grid:
          img_cell:
            - text-align: start
          name:
          state:
        state:
          - value: "off"
            styles:
              card:
                - color: SlateGrey
          - value: "on"
            styles:
              card:
                - color: White
        entity: switch.security_booth_lights_l3
        icon: mdi:air-conditioner
        show_name: false
        show_icon: true
        color: auto
        color_type: card
        aspect_ratio: 1/1
        styles:
          grid:
          img_cell:
            - text-align: start
          name:
          state:
        state:
          - value: "off"
            styles:
              card:
                - color: SlateGrey
          - value: "on"
            styles:
              card:
                - color: White
view_layout:
  position: sidebar
card_mod:
  style: |
    ha-card {
     background: transparent !important;
     margin-top: 0px;
     #margin-left: 15px;
     #max-width: 450px;
EDIT:
Found a solution here
UPDATE:
It works but isn’t consistent for button card. Modifying the Metro theme but the background-color reference I created for off is (finally) behaving itself, on isn’t registering consistently at all. Using element inspector sometimes the color doesn’t change to the reference selected for on without reloading the page. If I color the card directly in yaml, the on color stays loaded in off mode for light or dark.
Relevant part of theme yaml
light:
  lovelace-background: var(--background-image)
  background-image: "center / cover no-repeat fixed url('/local/Metro_day.svg')"
  switch-button-off-color: "rgba(255,255,255,.55)"
  switch-button-on-color: "rgba(255,193,7,.75)"
dark:
  background-image: "center / cover no-repeat fixed url('/local/Metro_night.svg')"
  switch-button-off-color: "rgba(0,0,0,.55)"
I got an interesting question that maybe someone is able to answer. Is there a way to template a custom_field (with or without card mod) so it shows two different values (of two sensors) in an alternating way?
Meaning it looks like it falshes every second or so at at each flash it shows the other value.
I am trying to make a climate card that when the AC is running shows the current temperature and the set temperature flashes in place until it’s done cooling/heating.
I have been unable to use template sensors or animations (in card mod as they don’t support templated content).
Any ideas?
@mynolix1986, you might find this interesting. I didn’t do alternating values, but I did arrange multiple values around the button to show the states of my HVAC.
hi at all!
i’m using custom button-card in an horizontal stack??
how to reduce the gap between cards? thanks a lot
See Horizontal stack - change font size - #3 by Mariusthvdb
—stack-card-gap
thanks a lot!
please, i don’t understand how to add my last custom field to my button card at right bottom.
I think that the problem is the grid…
As in the image, i need to move the "circular input button’ at the right bottom.
Screenshot 2024-12-14 alle 19.01.18
Could you help me?
this is my code
color_type: icon
lock:
  enabled: true
  unlock: double_tap
  duration: 2
entity: sensor.alarm_battery
icon: mdi:car-battery
tap_action:
  action: none
hold_action: none
show_label: true
show_state: false
label: |
    if (states['input_boolean.alarm_battery'].state == 'on')
      return '<b>ON</b>';
      return 'OFF';
custom_fields:
  btn2:
    card:
      type: custom:mushroom-chips-card
      chips:
        - type: template
          entity: input_boolean.alarm_battery
          tap_action:
            action: toggle
          icon: mdi:power
          card_mod:
            style: |
              ha-card {
                --chip-background: grey;
                padding: 1px !important;
                border-radius: 100px !important;
                color:white;
styles:
  custom_fields:
    btn2:
      - align-self: start
state:
  - label: ALARM
    styles:
      grid:
        - grid-template-areas: "\"n\" \"l\" \"btn2\" \"btn2\""
        - grid-template-columns: 1fr min-content
        - grid-template-rows: min-content min-content min-content min-content
        - align-items: start
        - will-change: transform
      card:
        - padding: 20px 8px 22px 12px
        - height: 190px
      img_cell:
        - justify-content: start
        - position: absolute
        - width: 150px
        - height: 150px
        - left: 0
        - bottom: 0
        - margin: 0 0 -40px -40px
        - background: orange
        - border-radius: 500px
        - opacity: "0.5"
      name:
        - font-size: 13px
        - font-weight: 500
      label:
        - align-self: start
        - margin-top: 10px
        - font-size: 11px
        - font-weight: 500
      icon:
        - position: relative
        - width: 80px
        - color: "#ffffff"
        - opacity: "0.7"
    value: "off"
card_mod:
  style: |
    #lock {
       width: 18px !important;
just set this button to <display: absolut> and then add <top: 12px> and <left: -12px> play arround with the px to set the button where you want
Hi, I’m trying to pass variables to button_card_templates: but something is wrong
  orange_button:
    styles:
      name:
        - font-size: 11px
        - word-break: break-word
        - white-space: unset
    variables:
      var_confronto: ''
      var_stato: ''
    card_mod:
      style: |
        div#img-cell > ha-state-icon {
        {% if is_state('[[[ return variables.var_confronto ]]]', 'off') %}
        color: orange !important;
        color: grey !important;
        {%- endif %}
and in dashboard
cards:
        cards:
            show_name: true
            show_icon: true
            tap_action:
              action: toggle
            entity: script.riscaldamento_basso
            hold_action:
              action: none
            icon: valutta:Riscaldamento GIU
            theme: slate
            template: orange_button
            variables:
              var_confronto: input_boolean.riscaldamento
              var_stato: 'off'
“if is_state” have something wrong doesn’t change
please help me!
youre mixing the JS (= javascript, native templating to the button-card) with Jinja (native to card-mod), and that wont work
why not use all of the config in the button-card itself, and stop using card-mod.
setting an icon-color in button-card is very simple
also you dont need
in the template. this will be merged with the config, and since you set the variables there, all will be taken from those values
Thank you!!!
show_name: true
show_icon: true
tap_action:
  action: call-service
  service: script.riscaldamento_basso
entity: input_boolean.riscaldamento
hold_action:
  action: none
theme: slate
state:
  - value: "off"
    color: orange
  - value: "on"
    color: grey
So better!!!
I created simple button card to notify me about washing machine status. Tricky part is that it overlaps circle icon on top of bacground image (screenshot of washing machine icon) to create washing animation:
type: conditional
conditions:
  - entity: input_text.washing_status
    state: Washing Started
card:
  icon: mdi:circle-slice-4
  name: Washing Cycle in Progress
  styles:
    icon:
      - color: var(--cyan2)
      - animation: 2s infinite ease-in-out rotating
    card:
      - background-image: url('/local/washing-machine.png')
      - background-size: 53px
      - background-position: center 5px
      - background-repeat: no-repeat
  tap_action:
    action: none
Screenshot 2024-12-22 at 11.56.03
It works perfectly as stand alone card. Vut for my target dashboard I’d like to put it on top of picture element card and for this I need to have trasparrent bvackground of the card. But if I apply some card mod CSS style, it also remove washing machine picture, leaving only rotating icon.
card_mod:
  style: |
    ha-card {
      background: none !important;
Is the any way to remove card solid color bacground leaving the background picture?
Hope this is the correct thread hope someone can explain whatever simple thing I am missing. This YAML is for showing wind speed and direction, the background icon changes dynamically based on wind speed- That works fine, I have a custom sensor that turns the wind direction from degrees to cardinal direction, that works fine. If the wind speed is 0 mph the background is a static image and does not display any MPH or direction data- That works fine BUT… If the MPG is above 0 I want the MPH and wind direction to appear and it does but the PROBLEM is they are overlapped on top of each other and I can not seem to find a way to seperate them!! That is what I need help with. Here is the YAML for the Dasboard button.
`type: custom:button-card
entity: sensor.denmans_mountain_wind_speed
show_icon: false
show_name: false
show_state: false
styles:
  card:
    - height: 150px
    - width: 150px
    - background-size: contain
    - background-image: >
          return `url(${states['sensor.wind_speed_icon'].state})`;
    - display: grid
    - grid-template-rows: auto 1fr auto
    - align-items: center
  custom_fields:
    wind_speed:
      - font-size: 18px
      - font-weight: bold
      - color: var(--primary-text-color)
    wind_direction:
      - font-size: 16px
      - color: var(--secondary-text-color)
custom_fields:
  wind_speed: >
      return `${states['sensor.denmans_mountain_wind_speed'].state} mph`;
  wind_direction: >
      return `${states['sensor.denmans_mountain_wind_cardinal_direction'].state}`;
Any help is appreciated.
Hello!
Please, could someone explain to me why - only using custom_fields in my button card - very often if i refresh the page the card disappear??? If I remove the custom fields all is working well…
This is supposed to be dynamically updating the icon based on temp change but it isn’t. it displays the current temp from my local weather station then it should be pulling data from a sensor that pulls hourly temp data based on that if the next hours temp is higher or lower it should change the icon if the temp is the same it displays a"same" icon all I can get it to do is display the same icon. I have checke dto ensure the path is current for the icons and all the sensors are working and pulling data but can’t get this to work any and all help is welcomed! here is the card YAML
entity: sensor.denmans_mountain_temperature
show_icon: false
show_name: false
show_state: true
styles:
  card:
    - height: 150px
    - width: 150px
    - background-image: |
          const trend = states['sensor.temperature_trend'].state;
          if (trend === 'warmer') {
            return "url('/local/temperature/thermometer-warmer.svg')";
          } else if (trend === 'colder') {
            return "url('/local/temperature/thermometer-colder.svg')";
          } else {
            return "url('/local/temperature/thermometer.svg')";
here are the template sensors
    # Sensor for the next hour's temperature
    - name: "Next Hour Temperature"
      unique_id: "next_hour_temperature"
      state: >
        {% set forecast = state_attr('sensor.pirate_weather_hourly', 'data') %}
        {% if forecast and forecast[0] %}
          {{ forecast[0].temperature }}
          "N/A"
      unit_of_measurement: "°F"
    # Sensor for the daily high temperature
    - name: "Daily High Temperature"
      unique_id: "daily_high_temperature"
      state: >
        {% set forecast = state_attr('sensor.pirate_weather_daily', 'data') %}
        {% if forecast %}
          {{ forecast | map(attribute='temperature') | max }}
          "N/A"
    # Sensor for the daily low temperature
    - name: "Daily Low Temperature"
      unique_id: "daily_low_temperature"
      state: >
        {% if forecast %}
          {{ forecast | map(attribute='templow') | min }}
          "N/A"
    # Temperature Trend Sensor
    - name: "Temperature Trend"
      unique_id: "temperature_trend"
      state: >
        {% set current_temp = states('sensor.denmans_mountain_temperature') | float(0) | round(1) %}
        {% set next_hour_temp = states('sensor.next_hour_temperature') | float(0) | round(1) %}
        {% if next_hour_temp > current_temp %}
          "warmer"
        {% elif next_hour_temp < current_temp %}
          "colder"
          "same"
here is the automation to update the trend sensor
description: Update temperature trend every 30 minutes
triggers:
  - minutes: /30
    trigger: time_pattern
actions:
  - data:
      entity_id:
        - sensor.temperature_trend
    action: homeassistant.update_entity
mode: single ```
Custom_field not correctly working after HA 2025.0
entity: switch.oven_inschakelen
hold_action:
  action: none
icon: mdi:toaster-oven
color_type: card
show_state: true
show_entity_picture: true
custom_fields:
  percentage:
    card:
      entity: sensor.oven_programma_voortgang
      tap_action:
        action: none
      show_name: false
      show_state: true
      show_icon: false
      show_entity_picture: false
      color_type: card
      color: rgba(225,225,225,0.8)
styles:
  card:
    - width: 155px
    - height: 155px
    - margin: 0px
  name:
    - display: block
    - left: 8px
    - bottom: 21px
    - font-weight: bold
    - font-size: 16px
    - font-family: Sans-serif
  img_cell:
    - margin: 0px
    - padding: 0px
  state:
    - display: block
    - bottom: 5px
    - left: 12px
    - font-size: 14px
    - text-transform: capitalize
  icon:
    - width: 100px
    - margin: 0px 0px 5px 0px
  custom_fields:
    percentage:
      - width: 50px
      - display: block
      - top: 8px
      - right: 8px
      - font-size: 14px
state:
  - value: "on"
    color: rgba(241,233,233,0.6)
    entity_picture: /local/pictures/entities/device/household/oven_icon_136.png?v=1
  - value: "off"
    color: rgba(65,65,63,0.8)
    styles:
      card:
        - filter: opacity(50%)
      icon:
        - filter: grayscale(100%)
  - value: unavailable
    entity_picture: /local/pictures/entities/error_icon_136.png?v=1
    styles:
      card:
      img_cell:
        - margin: 0px
        - padding: 0px
      icon:
        - width: 70px
        - margin: 0px 0px 10px 0px
  - value: unknown
    entity_picture: /local/pictures/entities/question_icon_136.png?v=1
    styles:
      card:
      img_cell:
        - margin: 0px
        - padding: 0px
      icon:
        - width: 70px
the color does not apply anymore, and also font styles do nothing anymore :frowning:
Anyone has the same?
custom field
It was and should be white and the font shoud be 14px. but its Ha original font size now.
It seems that the fonts/text are not applying anymore because of a element
ha-card.button-card-main.
Is there a way to override this?
I’m trying to create a condition in a button card template that retrieves the name of the card itself.
I am defining the name in the dashboard for the template and am trying to access it to compare it to an Input select. I have tried this.name and config.name to no avail.
I’m trying to avoid having to define the card name in variables.
Does anyone have an idea?
