Yes I do but each image listed with the full Linux path as that was the only one that let the config check pass (I can screenshot shortly or copy from states page soon )…
so here is part of the attributes of the sensor…
path: /home/homeassistant/.homeassistant/www/cam_captures/front/
filter: *
number_of_files: 90
bytes: 1959610
fileList: /home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571270525.jpg,/home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571272054.jpg,/home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571272068.jpg,/home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571275281.jpg,/home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571276199.jpg,/home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571277181.jpg,
So… that is what it appends to the URL in the gallery page https://MYURL/home/homeassistant/.homeassistant/www/cam_captures/front/front_yard_1571270525.jpg
do you think something is not right in my HA that I cannot use /config/www at all? I see other posts where people refer to folder_watcher/sensor type issues but they all seem to be using directories that are actually outside of their HA config folder.
I looked at any other situations where I use paths and it seems I always use the whole path starting with /home… command line sensors, snapshots etc all work fine.
