Writing just to say you @parrel thank you. I have created my very first ESPhome project with your info. In my case was for disarm the alarmo entity. Now waiting for a DIN rail case to finish the enclosure.
Just in case is useful for anyone:
1.- Iāve added āaura_led_controlā also in services section, for āenrollā, just looking for turn on light when the enroll starts.
api:
password: !secret api_password
encryption:
key: "*******************"
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
- text_sensor.template.publish:
state: "Registra tu huella"
- fingerprint_grow.aura_led_control:
state: ALWAYS_ON
speed: 0
color: BLUE
count: 0
- fingerprint_grow.enroll:
finger_id: !lambda 'return finger_id;'
num_scans: !lambda 'return num_scans;'
2.- Also added one more text_sensor to separate fingerprint_state and enrolling_state.
fingerprint_state is updated when match or unmatch, and enrolling_state when enrollment done, scan or fail.
fingerprint_grow:
sensing_pin: GPIO21
on_finger_scan_matched:
state: "Autorizado"
state: BREATHING
speed: 100
color: GREEN
count: 2
- delay: 3s
state: "Escanea tu huella"
on_finger_scan_unmatched:
state: "No reconocida"
state: FLASHING
speed: 25
color: RED
count: 4
- delay: 3s
on_enrollment_scan:
state: BREATHING
speed: 50
color: PURPLE
count: 1
state: ALWAYS_ON
speed: 0
color: BLUE
count: 0
state: "Registrando huella"
on_enrollment_done:
state: BREATHING
speed: 200
color: YELLOW
count: 2
state: FLASHING
speed: 25
color: WHITE
count: 4
state: "Huella registrada"
- delay: 5s
state: "Off"
on_enrollment_failed:
state: FLASHING
speed: 25
color: RED
count: 4
state: "Fallo al registrar huella"
- delay: 5s
state: "Off"
thanks man for the nice Guide. But I have several questions. I#ve set up an Wemos D1 mini and its working as it should I think. The main problem I have that is that I have 8 people an 2 doors which i wont to control via the scanner and i have no idea which trigger is needed in the automations for this different scenarios. is it the āfingerprint last IDā sensor? And the second question is, when i Called the Service to enroll new Fingerprints I cant find a solution for an Visual indikator for the enrol Action.neither it shows āPlace your Fingerā or the scanner lights up. Where do i configure this stuff?
In : Developer Tools ,Services , esphome.finger_print_enroll , set id no. and number of scan
alias: Open door with finger id 6
description: ''
mode: single
- platform: state
entity_id: sensor.fingerprint_last_finger_id #difrent sensor name for the 2 doors (2 readers)
to: '6' # replace with your id
condition: []
action: # add actions
- device_id: ''
domain: ''
entity_id: ''
Hello all
Does anyone know why i cant make this work on a D1 mini v4.0.0 (usb-c) it does work fine on a nodemcu ,im sure that i use the right gpios but i cant make
it work ?? anyone else have a problem whit the ānewā D1 mini ?
solved : it was the password for the sensor that was the problem
i deleted the password line and it worked, then i added it agin
whit ānew_ā in front ,and then agin whit out the ānew_ā then
it worked fine ???
Yeah, thats the thing i know. I Mean, is it Possible to create an input Helper where i Can input a Slot Number and Assign it to a Name?
I stumbled across this project - great work everyone - maybe somebody already asked for it and I missed it scrolling through ā¦
Would it be an option to add a function āif the fingerprint doesnāt match, just ring the bellā? - I would use it for my apartment door and trigger my Nuki to open the door.
But I only have a single ācavity wall boxā where I could build it in (replace the switch for the bell with the sensor) - so the idea was to combine the sensor and the bell - so if someone touches the sensor and it doesnāt match a print - it should ring the bell (itās a ring bell so it can be set up in automations ā¦).
Thanks in advance!
Yes itās possible, you can use on_finger_scan_unmatched: to automate something if the finger does not match. You will also need to connect the door bell to a relay, which you can then control using the ESP
@epictechlab - if you want, you can create a template sensor in HA that references the last finger ID.
Helpers ā Template Sensor
{% if is_state('sensor.garage_fingerprint_last_finger_id', '1') %}
Tom
{% elif is_state('sensor.garage_fingerprint_last_finger_id', '2') %}
Dick
{% elif is_state('sensor.garage_fingerprint_last_finger_id', '3') %}
Harry
{% elif is_state('sensor.garage_fingerprint_last_finger_id', '4') %}
Violet
{% elif is_state('sensor.garage_fingerprint_last_finger_id', '5') %}
Rose
{% else %}
Unknown
{% endif %}
or in configuration.yaml
template:
# Fingerprint Sensor
- sensor:
- name: "Garage Door Last User"
state: >
Tom
Dick
Harry
Violet
Rose
{% else %}
Unknown
{% endif %}
I want to try to buy another 25mm button and modify it with the sensor so I have push function for ringing.
Otherwise it would suck if it cannot match your finger and you accidentally ring the bell when someone is sleeping.
Maybe someone else tried this already?
You could disable the door bell altogether at night�
True but still not optimal
So I am now integrating a the sensor into a button. Currently waiting for the smaller 22mm version of the fingerprint.
Hi, but how did you solve it, I wouldnāt want to have the same problem because I have the same components. could you tell me how you did it??? A thousand thanks
Try different pins for TX and RX? Which pins are you using and which board?
iām going out of my mind, because it doesnāt work. the configuration is correct. the logs show that eroll starts but the sensor doesnāt switch on. i have two of them but nothing, tried both. is it me or do the sensors suck?
Iām use the platform: ESP8266 board: d1_mini
the fingerprint is a GROW R503
what do you think it could be ? i donāt see the light coming on at all, shouldnāt it come on already by connecting to 3.3 and gnd ? can anyone help me ? this is the third sensor iāve tried, could it be that they are all not working ?
this is my configuration:
uart:
tx_pin: D0
rx_pin: D1
baud_rate: 57600
fingerprint_grow:
sensing_pin: D2
state: BREATHING
speed: 200
color: BLUE
count: 1
state: "Authorized finger"
state: FLASHING
speed: 25
color: RED
count: 2
state: "Unauthorized finger"
on_enrollment_scan:
state: FLASHING
speed: 25
color: BLUE
count: 2
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
state: "Finger scanned"
on_enrollment_done:
state: BREATHING
speed: 100
color: BLUE
count: 2
state: "Enrolled fingerprint"
state: FLASHING
speed: 25
color: RED
count: 4
state: "Failed to enroll fingerprint"
text_sensor:
platform: template
name: āGarage Fingerprint Stateā
platform: fingerprint_grow
fingerprint_count:
name: āGarage Fingerprint Countā
last_finger_id:
name: āGarage Fingerprint Last Finger IDā
last_confidence:
name: āGarage Fingerprint Last Confidenceā
status:
name: āGarage Fingerprint Statusā
capacity:
name: āGarage Fingerprint Capacityā
security_level:
name: āGarage Fingerprint Security Levelā
services:
service: enroll
variables:
finger_id: int
num_scans: int
then:
finger_id: !lambda āreturn finger_id;ā
num_scans: !lambda āreturn num_scans;ā
service: enroll_next # Idea by Ralf Klüber (thanks!)
variables:
num_scans: int
then:
finger_id: !lambda āreturn id(fingerprint_count).state;ā
service: cancel_enroll
then:
- fingerprint_grow.cancel_enroll:
service: delete
variables:
finger_id: int
then:
fingerprint_grow.delete:
service: delete_all
then:
- fingerprint_grow.delete_all:
this a log:
00:20:13][C][logger:361]: Logger:
[00:20:13][C][logger:362]: Level: DEBUG
[00:20:13][C][logger:363]: Log Baud Rate: 115200
[00:20:13][C][logger:365]: Hardware UART: UART0
[00:20:13][C][uart.arduino_esp8266:102]: UART Bus:
[00:20:13][C][uart.arduino_esp8266:103]: TX Pin: GPIO16
[00:20:13][C][uart.arduino_esp8266:104]: RX Pin: GPIO5
[00:20:13][C][uart.arduino_esp8266:106]: RX Buffer Size: 256
[00:20:13][C][uart.arduino_esp8266:108]: Baud Rate: 57600 baud
[00:20:13][C][uart.arduino_esp8266:109]: Data Bits: 8
[00:20:13][C][uart.arduino_esp8266:110]: Parity: NONE
[00:20:13][C][uart.arduino_esp8266:111]: Stop bits: 1
[00:20:13][C][uart.arduino_esp8266:115]: Using software serial
[00:20:13][C][template.text_sensor:020]: Template Sensor āGarage Fingerprint Stateā
[00:20:13][C][fingerprint_grow:427]: GROW_FINGERPRINT_READER:
[00:20:13][C][fingerprint_grow:428]: Update Interval: 0.5s
[00:20:13][C][fingerprint_grow:429]: Fingerprint Count āGarage Fingerprint Countā
[00:20:13][C][fingerprint_grow:429]: State Class: āā
[00:20:13][C][fingerprint_grow:429]: Unit of Measurement: āā
[00:20:13][C][fingerprint_grow:429]: Accuracy Decimals: 0
[00:20:13][C][fingerprint_grow:429]: Icon: āmdi:fingerprintā
[00:20:13][C][fingerprint_grow:430]: Status āGarage Fingerprint Statusā
[00:20:13][C][fingerprint_grow:430]: State Class: āā
[00:20:13][C][fingerprint_grow:430]: Unit of Measurement: āā
[00:20:13][C][fingerprint_grow:430]: Accuracy Decimals: 0
[00:20:13][C][fingerprint_grow:431]: Capacity āGarage Fingerprint Capacityā
[00:20:13][C][fingerprint_grow:431]: State Class: āā
[00:20:13][C][fingerprint_grow:431]: Unit of Measurement: āā
[00:20:13][C][fingerprint_grow:431]: Accuracy Decimals: 0
[00:20:13][C][fingerprint_grow:431]: Icon: āmdi:databaseā
[00:20:13][C][fingerprint_grow:432]: Security Level āGarage Fingerprint Security Levelā
[00:20:13][C][fingerprint_grow:432]: State Class: āā
[00:20:13][C][fingerprint_grow:432]: Unit of Measurement: āā
[00:20:13][C][fingerprint_grow:432]: Accuracy Decimals: 0
[00:20:13][C][fingerprint_grow:432]: Icon: āmdi:securityā
[00:20:13][C][fingerprint_grow:433]: Last Finger ID āGarage Fingerprint Last Finger IDā
[00:20:13][C][fingerprint_grow:433]: State Class: āā
[00:20:13][C][fingerprint_grow:433]: Unit of Measurement: āā
[00:20:13][C][fingerprint_grow:433]: Accuracy Decimals: 0
[00:20:13][C][fingerprint_grow:433]: Icon: āmdi:accountā
[00:20:13][C][fingerprint_grow:434]: Last Confidence āGarage Fingerprint Last Confidenceā
[00:20:13][C][fingerprint_grow:434]: State Class: āā
[00:20:13][C][fingerprint_grow:434]: Unit of Measurement: āā
[00:20:13][C][fingerprint_grow:434]: Accuracy Decimals: 0
[00:20:13][C][fingerprint_grow:434]: Icon: āmdi:account-checkā
[00:20:13][C][captive_portal:088]: Captive Portal:
[00:20:13][C][mdns:115]: mDNS:
[00:20:13][C][mdns:116]: Hostname: fingerprint
[00:20:13][C][ota:097]: Over-The-Air Updates:
[00:20:13][C][ota:098]: Address: fingerprint.local:8266
[00:20:13][C][ota:101]: Using Password.
[00:20:13][C][api:138]: API Server:
[00:20:13][C][api:139]: Address: fingerprint.local:6053
[00:20:13][C][api:141]: Using noise encryption: YES
Do you have a picture of your wiring from the board to the sensor?
consider that the wire you see is gray and connected to the red and white for 3.3V the black to G. I put the rest, yellow on D0, brown (formerly green) on D1 and blue on D2 (sensing pin)
into log:
[10:29:50][C][logger:361]: Logger:
[10:29:50][C][logger:362]: Level: DEBUG
[10:29:50][C][logger:363]: Log Baud Rate: 115200
[10:29:50][C][logger:365]: Hardware UART: UART0
[10:29:50][C][uart.arduino_esp8266:102]: UART Bus:
[10:29:50][C][uart.arduino_esp8266:103]: TX Pin: GPIO16
[10:29:50][C][uart.arduino_esp8266:104]: RX Pin: GPIO5
[10:29:50][C][uart.arduino_esp8266:106]: RX Buffer Size: 256
[10:29:50][C][uart.arduino_esp8266:108]: Baud Rate: 57600 baud
[10:29:50][C][uart.arduino_esp8266:109]: Data Bits: 8
[10:29:50][C][uart.arduino_esp8266:110]: Parity: NONE
[10:29:50][C][uart.arduino_esp8266:111]: Stop bits: 1
[10:29:50][C][uart.arduino_esp8266:115]: Using software serial
[10:29:50][C][template.text_sensor:020]: Template Sensor āFingerprint Stateā
[10:29:50][C][fingerprint_grow:427]: GROW_FINGERPRINT_READER:
[10:29:50][C][fingerprint_grow:428]: Update Interval: 0.5s
[10:29:50][C][fingerprint_grow:429]: Fingerprint Count āFingerprint Countā
[10:29:50][C][fingerprint_grow:429]: State Class: āā
[10:29:50][C][fingerprint_grow:429]: Unit of Measurement: āā
[10:29:50][C][fingerprint_grow:429]: Accuracy Decimals: 0
[10:29:50][C][fingerprint_grow:429]: Icon: āmdi:fingerprintā
[10:29:50][C][fingerprint_grow:430]: Status āFingerprint Statusā
[10:29:50][C][fingerprint_grow:430]: State Class: āā
[10:29:50][C][fingerprint_grow:430]: Unit of Measurement: āā
[10:29:50][C][fingerprint_grow:430]: Accuracy Decimals: 0
[10:29:50][C][fingerprint_grow:431]: Capacity āFingerprint Capacityā
[10:29:50][C][fingerprint_grow:431]: State Class: āā
[10:29:50][C][fingerprint_grow:431]: Unit of Measurement: āā
[10:29:50][C][fingerprint_grow:431]: Accuracy Decimals: 0
[10:29:50][C][fingerprint_grow:431]: Icon: āmdi:databaseā
[10:29:50][C][fingerprint_grow:432]: Security Level āFingerprint Security Levelā
[10:29:50][C][fingerprint_grow:432]: State Class: āā
[10:29:50][C][fingerprint_grow:432]: Unit of Measurement: āā
[10:29:50][C][fingerprint_grow:432]: Accuracy Decimals: 0
[10:29:50][C][fingerprint_grow:432]: Icon: āmdi:securityā
[10:29:50][C][fingerprint_grow:433]: Last Finger ID āFingerprint Last Finger IDā
[10:29:50][C][fingerprint_grow:433]: State Class: āā
[10:29:50][C][fingerprint_grow:433]: Unit of Measurement: āā
[10:29:50][C][fingerprint_grow:433]: Accuracy Decimals: 0
[10:29:50][C][fingerprint_grow:433]: Icon: āmdi:accountā
[10:29:50][C][fingerprint_grow:434]: Last Confidence āFingerprint Last Confidenceā
[10:29:50][C][fingerprint_grow:434]: State Class: āā
[10:29:50][C][fingerprint_grow:434]: Unit of Measurement: āā
[10:29:50][C][fingerprint_grow:434]: Accuracy Decimals: 0
[10:29:50][C][fingerprint_grow:434]: Icon: āmdi:account-checkā
[10:29:51][C][captive_portal:088]: Captive Portal:
[10:29:51][C][mdns:115]: mDNS:
[10:29:51][C][mdns:116]: Hostname: fingerprint
[10:29:51][C][ota:097]: Over-The-Air Updates:
[10:29:51][C][ota:098]: Address: fingerprint.local:8266
[10:29:51][C][ota:101]: Using Password.
[10:29:51][C][api:138]: API Server:
[10:29:51][C][api:139]: Address: fingerprint.local:6053
[10:29:51][C][api:141]: Using noise encryption: YES
[10:32:14][I][fingerprint_grow:066]: Starting enrollment in slot 10
[10:32:21][D][fingerprint_grow:307]: Setting Aura LED ->> no led on!
[10:32:22][E][fingerprint_grow:421]: No response received from reader
[10:32:22][D][text_sensor:064]: āFingerprint Stateā: Sending state āFailed to enroll fingerprintā
[10:32:22][I][fingerprint_grow:089]: Finished enrollment
[10:32:22][W][component:214]: Component api took a long time for an operation (1.05 s).
[10:32:22][W][component:215]: Components should block for at most 20-30ms.
You switched the RX and TX pins. Yellow should be on D1
yes I just tried but the reader does not respond.
yet they confirm to me that it has been tested and is working.
uart:
tx_pin: D0 ā on esp at D1
rx_pin: D1 ā on the esp at D0
baud_rate: 57600
fingerprint_grow:
sensing_pin: D2
can you think of what it could be? i am now sending the photo of the esp because it also has tx and rx pins
