I ordered another esp on amazon tomorrow it should arrive and Iâll try again, if it doesnât work then Iâd like to understand why⊠stay tuned
Thank you for your sharing! Iâm currently working on my own fingerprint sensor project and still have a few questions. How can I trigger different things with different fingers? Itâs not entirely clear to me how to differentiate this in HA. A small example would definitely help me.
How can I set a minimum confidence so that fingerscans will only be accepted if the scan is better than 50? Does that make sense or does it have no impact on the safety of false positives?
The ESPHome docs have an example with the confidence and different things for each finger id. I would start from there and learn how ESPHome actions and triggers work
Iâm not using a confidence threshold myself
Just received my fingerprint reader in the mail today, looking forward to setting this up!
Hello, I have rebuilt the fingerprint sensor and it works quite well so far. I only have one small problem. Coupled with the sensor is an esp relay, which opens my garage door when the status goes to âwaitâ. Unfortunately, the relay switches sporadically without anyone touching the sensor, sometimes in the middle of the night. Could it be an error in the yaml configuration?
esphome:
friendly_name: fingerprint
esp8266:
board: nodemcuv2
# Enable logging
logger:
ota:
password: "80fa74e686b7d383a0aab1e785db6318"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Fingerprint Fallback Hotspot"
password: "GX6Dj0GlKkJZ"
captive_portal:
uart:
rx_pin: D1
tx_pin: D0
baud_rate: 57600
fingerprint_grow:
sensing_pin: D2
password: 0x00000000
on_finger_scan_matched:
- logger.log: "scan matched"
- text_sensor.template.publish:
state: "Autorisierter Fingerabdruck"
- delay: 3000ms
state: "Warten"
- fingerprint_grow.aura_led_control:
state: BREATHING
speed: 200
color: BLUE
count: 1
on_finger_scan_unmatched:
- logger.log: "scan unmatched"
state: "Unautorisierter Fingerabdruck"
state: FLASHING
speed: 25
color: RED
count: 2
on_enrollment_scan:
state: "Fingerabdruck erfasst"
state: FLASHING
speed: 25
color: BLUE
count: 2
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
on_enrollment_failed:
state: "Erfassung des Fingerabdrucks fehlgeschlagen"
state: FLASHING
speed: 25
color: RED
count: 4
api:
encryption:
key: "8hRDQQIOxwgssyZzLYfdeULLFtl40s+Qmdld68sNXSQ="
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
- fingerprint_grow.enroll:
finger_id: !lambda 'return finger_id;'
num_scans: !lambda 'return num_scans;'
- service: cancel_enroll
then:
- fingerprint_grow.cancel_enroll:
- service: delete
variables:
finger_id: int
then:
- fingerprint_grow.delete:
- service: delete_all
then:
- fingerprint_grow.delete_all:
# Optionaler Vorlagentextsensor fĂŒr visuelles Feedback
text_sensor:
binary_sensor:
- platform: fingerprint_grow
name: "Fingerabdruck erfassen"
- platform: gpio
pin:
number: D4 # Replace with the GPIO pin connected to the sensor
mode: INPUT_PULLUP # Change this if your sensor requires a different mode
filters:
- delayed_on: 20ms # Replace X with the desired delay in milliseconds
fingerprint_count:
last_finger_id:
name: "Letzte Fingerabdruck ID"
last_confidence:
name: "ZuverlÀssigkeit des letzten Fingerabdrucks"
status:
capacity:
security_level:
esphome:
friendly_name: Garage Relais
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "qdTicwlOkzsjby1dvOEZTD3M3VbQQv3wAV9W+ciMsdc="
ota:
password: "ad433b7d877c9d258e1c7c36806c227c"
wifi:
ap:
ssid: "Garage-Relais Fallback Hotspot"
password: "SQSB6ecpsUYY"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: GPIO2
mode: INPUT_PULLUP
name: "Garagentor Reed Kontakt 1"
device_class: garage_door
filters:
- delayed_on_off: 500ms
switch:
- platform: gpio
pin: GPIO0
inverted: true
restore_mode: ALWAYS_OFF
on_turn_on:
- delay: 2s
- switch.turn_off: garage_switch
# The following can be omitted
- platform: restart
- platform: wifi_signal
update_interval: 600s
# human readable uptime sensor output to the text sensor above
- platform: uptime
name: Uptime in Days
update_interval: 60s
on_raw_value:
then:
state: !lambda |-
int seconds = round(id(uptime_sensor_days).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? String(days) + "d " : "") +
(hours ? String(hours) + "h " : "") +
(minutes ? String(minutes) + "m " : "") +
(String(seconds) + "s")
).c_str();
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
bssid:
# human readable update text sensor from sensor:uptime
name: Uptime Human Readable
icon: mdi:clock-start
Maybe someone has a similar behavior
How do you trigger the switch with id garage_switch
? Do you do that from Home Assistant?
The switch is triggered via an automation in homeassistant
alias: Garage öffnen
description: ""
- platform: state
entity_id:
- sensor.fingerprint_fingerabdruck_status
to: Warten
condition: []
- type: turn_on
device_id: 36078f83bd0da445dfb84772864a5e89
entity_id: faa69e5f93cbef178fa953d31b1d7db4
domain: switch
mode: single
Is there a reason you do it in Home Assistant? Because if you add the following to the ESP it will also be triggered and you can remove the automation from HA.
- switch.turn_on: garage_switch
Doing it like that means that it will still work even when wifi is not available or your Home Assistant is down.
Thanks for the hint, but when I enter it like this, an error message comes up, it does not recognize the switch, even if I try it with the ID from the automation, it is recognized as if the switch does not exist, but it works via the automation.
Strange because in the switch itself you also got this piece of code which works fine I guess?
But anyways, for the random triggering of your switch, itâs either coming from Home Assistant, or the relay itself is doing it. Is it wired correctly?
Ok, after a long search Iâve got it right. I have read that ESPHome nodes are separate entities, and they cannot directly reference components from other nodes. I have now done it via the service call
- homeassistant.service:
service: switch.turn_on
entity_id: switch.garage_switch
Thanks again parrel
Oh, I thought the fingerprint scanner and the garage relay were on the same ESP, my bad! In that case, itâs fine to do it in Home Assistant itself, but that also works!
Hey,
How do you make a service for led control on the fingerscanner
- service: led_control
variables:
status: string
speed_id: int
color_id: string
count_id: int
then:- fingerprint_grow.aura_led_control:
state: !lambda âreturn status;â
speed: !lambda âreturn speed_id;â
color: !lambda âreturn color_id;â
count: !lambda âreturn count_id;â
The error for this code is
/config/esphome/scan.yaml:59:14: error: cannot convert âstd::__cxx11::stringâ {aka âstd::__cxx11::basic_stringâ} to âuint8_tâ {aka âunsigned charâ} in return
/config/esphome/scan.yaml: In lambda function:
/config/esphome/scan.yaml:61:14: error: cannot convert âstd::__cxx11::stringâ {aka âstd::__cxx11::basic_stringâ} to âuint8_tâ {aka âunsigned charâ} in return
I found this message in my esphome log, has anyone encountered such a problem, please provide a solution:
[16:57:44][W][component:214]: Component fingerprint_grow took a long time for an operation (0.98 s).
[16:57:44][W][component:215]: Components should block for at most 20-30ms.
and the fingerprint sensor is often unavailable,
Yes mine keeps disconnecting for about a minute or so. Then reconnects tried to reprogram code to see if that helps but still same. It was fine on ESPhome 2023.10.
i am using Firmware: 2023.11.6 (Dec 9 2023, 16:52:18),I donât know what the cause is, but itâs annoying, I am using esp32s. Thank you for the information, but have you encountered a message like that?
For ESP32:
- Red and white: 3V
- Black: GND
- Yellow: GPIO16
- Green: GPIO17
- Blue: GPIO05
this shema not work for me, i change to :
rx_pin: GPIO19
tx_pin: GPIO21
sensing_pin: GPIO4
