I am having multiple issues with a newly installed GE 26933. I’ve hard reset the device multiple times and the problems remain the same. I have 8 other zwave devices, mostly GE switches and dimmers, that are happy.
- Each entity is duplicated. For example, I have 2x sensor…alarm_levels, 3x light…dimmer_levels, etc.
- The device isn’t sending callbacks/updates for any of the entities.
Commands to turn the lights on and off from HA work fine.
Only clues from openzwave are 10 of these messages in the logs:
Info, Node021, DisablePoll failed - value not on list
If I setup polling intervals, HA will update but of course this isn’t ideal and doesn’t fix the odd double entities issue.
The host is debian stretch with HA 0.49.1. Please let me know if you have any pointers or thoughts.
