You can add this as custom file in zwavejsmqtt to make the parameter show in ui
I use 14298 but config is same as 14299
I change below file to match 14299
place in file /usr/src/app/store/config/0x0063/ge_14299_zw3006.json of zwavejsmqtt folder. I use docker so not sure how this fits your install.
"manufacturer": "GE/Jasco",
"manufacturerId": "0x0063",
"label": "14299 / ZW3006",
"description": "In-Wall Dimmer Switch",
"devices": [
"productType": "0x4944",
"productId": "0x3039"
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"supportsZWavePlus": true,
"associations": {
// One entry for each association group
"1": {
"label": "Lifeline",
"maxNodes": 5,
"isLifeline": true
"2": {
"label": "Basic - Local Load",
"maxNodes": 5
"3": {
"label": "Basic - Double Tap", // required
"maxNodes": 5,
"isLifeline": true
"paramInformation": {
"3": {
"label": "Night Light",
"description": "Defines the behavior of the blue LED. Default is on when switch is off.",
"valueSize": 1,
"minValue": 0,
"maxValue": 2,
"defaultValue": 0,
"allowManualEntry": false,
"options": [
"label": "LED on when switch is OFF",
"value": 0
"label": "LED on when switch is ON",
"value": 1
"label": "LED always off",
"value": 2
"4": {
"label": "Invert Switch",
"description": "Invert the ON/OFF Switch State.",
"valueSize": 1,
"minValue": 0,
"maxValue": 1,
"defaultValue": 0,
"options": [
"label": "No",
"value": 0
"label": "Yes",
"value": 1
"7": {
"label": "Dim Rate Steps (Z-Wave Command)",
"description": "Number of steps or levels",
"valueSize": 1,
"minValue": 0,
"maxValue": 99,
"defaultValue": 1,
"unsigned": true
"8": {
"label": "Dim Rate Timing (Z-Wave)",
"description": "Timing of steps or levels",
"valueSize": 2,
"unit": "10ms",
"minValue": 1,
"maxValue": 255,
"defaultValue": 3,
"unsigned": true
"9": {
"label": "Dim Rate Steps (Manual)",
"valueSize": 1,
"minValue": 1,
"maxValue": 99,
"defaultValue": 1,
"unsigned": true
"10": {
"label": "Dim Rate Timing (Manual)",
"description": "Timing of steps",
"valueSize": 2,
"unit": "10ms",
"minValue": 1,
"maxValue": 255,
"defaultValue": 3,
"unsigned": true
"11": {
"label": "Dim Rate Steps (All-On/All-Off)",
"valueSize": 1,
"minValue": 1,
"maxValue": 99,
"defaultValue": 1,
"unsigned": true
"12": {
"label": "Dim Rate Timing (All-On/All-Off)",
"valueSize": 2,
"unit": "10ms",
"minValue": 1,
"maxValue": 255,
"defaultValue": 3,
"unsigned": true
"16": {
"label": "Switch Mode",
"description": "Turn your dimmer into an On/Off switch with switch mode",
"valueSize": 1,
"minValue": 0,
"maxValue": 1,
"defaultValue": 0,
"unsigned": true,
"options": [
"label": "Normal Operation",
"value": 0
"value": 1
"compat": {
"treatBasicSetAsEvent": true
