Would it be possible to integrate an additional entity for the Generic Hygrostat dehumidifier so that the plug socket is only switched off when the current power is low (adjustable value). This is intended to protect the compressor.
Kind regards
Kind regards
Third post for this today…
So I’m going to say it’s a duplicate…
Generic Hygrostat dehumidifier!.
https://community.home-assistant.io/t/generic-hygrostat-dehumidfier/674389.
Also adding power monitoring to the generic humidifier integration is not a valid request.
And what does this mean?
Fan on low?
Solar panels low output?
Mains lines are voltage regulated. It draws the current it needs. Do you mean line voltage low?
