Generic Thermostate - Allow full range climate operations
Hi there,
I’m using the generic thermostat to implement multi-zone climate control but a restriction from the generic thermostat is that you can’t have the ‘same’ thermostat to be able to control heating/cooling/fan.
Currently you’d need ‘2’ to achieve that for a single zone. (one each for heating and cooling). Fan/Auto is not possible.
If you add the ability to select Off/Heating/Cooling/Fan/Auto that would give more more ability to do some cool stuff and not need to duplicate items.
Should be a trivial change.
You could either use the default ‘climate’ range or allow the user to enter their own list.
A post was merged into an existing topic: Generic Thermostat Improvements
2 votes have been moved.
