Integration: core/homeassistant/components/geo_location at master · home-assistant/core · GitHub
Current Implementation: A GeoLocation Event type entity has a lat/lon point. distance contains the distance to the point (from zone.home.
Requested implementation: A GeoLocation Event type entity can contain 1 or more lat/lon points, which connect to form a polygon. If within the polygon, distance contains the distance to the edge of the polygon (0 if within).
Applications:
- “Effected Area” for power outages, weather alerts, wildfires, etc.
- Richer Geo-JSON use cases, where
geometrycan describe polygons. - Logical: Automation trigger or condition based on event data.
Considerations:
- Front End: Map card should be modified to make it possible to display polygons
- Lines: 2 points; as well as any points that backtrack onto themselves, should be handled properly.
