I’ve added the mosquitto mqtt from hass.io as I understood from the docs that would be a better solution than the built-in.
I now see this warning in the logfile:
Data in your config entry is going to override your configuration.yaml: {'broker': 'core-mosquitto', 'discovery': True, 'password': 'XXXXXXXXXXXXXXXXXXXXXXX', 'port': 1883, 'protocol': '3.1.1', 'username': 'homeassistant'
I know it’s only a warning, but I really don’t understand it, I had a ‘discovery: true’ in the config file, and removing that didn’t change anything, so what is it complaining about? The IP address is my IP address for the Raspberry Pi with Hass.io, not an internal container IP (which I wouldn’t know anyhow).
I also see a warning about the life360 component not being tested yet, that I can understand, so I can just ignore that and hope it gets tested and / or integrated.
Yes I figured it out in the end but this was the solution for my set-up and not sure if its the universal answer… give it a try and see how it goes…
First off I added the Google Backup Add-on to my set up - Nice YouTube video here if you need help doing that. https://www.youtube.com/watch?v=WcErD5PvIYw&list=PLFLOgOwVGodVlT9CIv4qUocBtVVsA-M7o&index=7&t=3s
I did this because I needed to edit the core.config_entries and I wanted a good reliable method of backing up my HA files.
Then I removed the following section from /config/.storage/core.config_entries
I think this was the HA’s auto-discovered / created MQTT broker that was overriding the settings in my configuration.yaml. After a restart everything worked fine and I didn’t get the error anymore, hope this helps.
Hi.
I had the same warning, so I tried the same solution.
I removed that section and restarded HA.
Mosquitto starts and in its log I can see that clients are connecting to it.
Anyway on frontend I see all my MQTT entities unavailable.
In HA log I read: “ERROR (Thread-6) [homeassistant.components.mqtt] Unable to connect to the MQTT broker: Connection Refused: not authorised.”
If I restore the old /config/.storage/core.config_entries files, everything gets back as before.
I tried this because I’m having some “mqtt socket error on client xxx disconnecting” in Mosquitto log.
You’ve configured MQTT through both the UI (Configuration → Integrations) and YAML. You need to delete the UI integration and configure it all through YAML (or delete the YAML and configure it all through the UI).
