egmontr
(Egmont)
September 13, 2024, 7:18pm
1
I am getting the following error when setting the “below” value from an input_number.
alias: Heizung an
description: ""
- type: temperature
platform: device
device_id: 74a10c5e1d2c32d0aeed1384d0322cc2
entity_id: 6a9096938d526bd0356a5ff06604e3ca
domain: sensor
below: input_number.solltemperatur
for:
hours: 0
minutes: 0
seconds: 10
condition: []
- type: turn_on
device_id: a601df3b20b12879fdb98e4d6e6b3897
entity_id: b4559c0fc1d8a81c0db4a7ecba91cb0c
domain: switch
Also I tried
input_number.solltemperatur | float
Can anyone help me please?
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
September 13, 2024, 11:51pm
2
Howdy Egmont ,
That doesn’t work because device triggers do not accept templates, you didn’t have the correct template format there either.
My guess is that that input number does not exist. Did you create it?
Why and how to avoid device_ids in automations and scripts .
Look at that in the developer tools and see if it exixts and if it’s currenrtly a number.
egmontr
(Egmont)
September 14, 2024, 6:45am
3
Hi!
Yes, I did create the input_number.solltemperatur
before:
egmontr
(Egmont)
September 14, 2024, 7:20am
4
I read the very good advices in: Why and how to avoid device_ids in automations and scripts .
Following that I changed from device to entitie and now it should work.
One more question. How to do this:
above: input_number.solltemperatur + 1
Sir_Goodenough
September 14, 2024, 4:27pm
5
You will need to change the entity to a variable much like you would a blueprint !input and put that into a template.
Blueprints: Get your !input value into a template .
egmontr
(Egmont)
September 17, 2024, 9:20am
6
I made now a template and the template testing was okay, but in the real life the switch ist not triggered:
alias: HeizungSchalterAn
description: HeizungSchalterAn
value_template: |
"{{ states('sensor.thermostat_eingang_temperatur') | float <
states('input_number.solltemperatur') | float }}"
condition: []
- action: switch.turn_on
metadata: {}
data: {}
entity_id: switch.schalter_test
I know you said to change the entity in a variable, but I didn’t understand how ro do it.
egmontr
(Egmont)
September 17, 2024, 12:39pm
7
I have now managed to create and integrate a variable. Unfortunately, switches are still not addressed.
value_template: |
"{{ states('_thermostat_eingang_temperatur') | float(0) <
condition: []
metadata: {}
data: {}
variables:
_thermostat_eingang_temperatur: "{{ states('sensor.thermostat_eingang_temperatur') | float }}"
petro
(Petro)
September 17, 2024, 12:44pm
8
This isn’t correct. You’re using YAML multiline notation and quotes. You have to use 1 or the other, not both.
e.g.
value_template: "{{ states('_thermostat_eingang_temperatur') | float(0) < states('input_number.solltemperatur') | float }}"
or
value_template: |
Secondly, _thermostat_eingang_temperatur
is not a valid entity_id.
Lastly, variables are resolved after triggers, not before. Therefore you cannot use them in a template trigger.
With those changes in mind…
value_template: |
{{ states('sensor.thermostat_eingang_temperatur') | float(0) < states('input_number.solltemperatur') | float }}
condition: []
metadata: {}
data: {}
egmontr
(Egmont)
September 17, 2024, 1:09pm
9
Thanks for help. Now it works to switch on and off.
Here is the template for switching off:
value_template: >
{{ states('sensor.thermostat_eingang_temperatur') | float(0) >
(states('input_number.solltemperatur') | float(0) + 1 | float) }}
But what did @Sir_Goodenough mean with the variable instead of the entity in the template?
Sir_Goodenough
September 17, 2024, 4:41pm
10
If it’s working, it’s working. Don’t break it. Otherwise if you are interested in that for another project I did leave links you can read first to discuss this more.
What I’m proposing isn’t better, it’s just different.
