psyciknz
(Psyciknz)
1
I’m trying to get an automation that for a given sunset time, it tell me what time that will be (so I can give it to node-red).
So the automation I’ve tried is:
alias: update sunset minus one
platform: sun
event: sunset
offset: "-00:60:00"
service: input_datetime.set_value
data_template:
entity_id: input_number.sunset_minus_one_hour
value: "{{ trigger.to_state.state | int }}"
So sunset -60 minus (I hope) and I want the time value in to an input_datetime field.
But I can’t figure out what value: '{{ trigger.to_state.state | int }}
should be to post the value from the sun platform to the input_datetime field
tom_l
2
Try this:
platform: sun
event: sunset
offset: "-01:00:00"
data_template:
value: "{{ now().strftime('%H:%M:00') }}"
psyciknz
(Psyciknz)
3
ahh because this will trigger at the time of sunset, which is the current time. Ahh right.
So is there a way that I could get what time sunset will be tonight? and trigger it say at 8 in the morning.
tom_l
4
Create this sensor:
nextsunset:
friendly_name: 'Next Sunset'
entity_id: sun.sun
value_template: "{{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_local }}"
Or just use the template if you’re not going to use it elsewhere.
Note it will only work up until sunset. At that point it becomes tomorrows sunset.
There’s a custom component here that will keep the value:
Not a problem if you are triggering at 8am though.
Time trigger: Automation Trigger - Home Assistant
psyciknz
(Psyciknz)
5
No the sensor template gets me a time, thanks for that.
I’ll feed that into node-red for use in a time of day calculation.
Still trying to get my head around HA compared to openhab (doing a very slow migration)
tom_l
6
Ok but keep in mind what I said:
psyciknz
(Psyciknz)
7
Yep thanks. As soon as it updates it’s fed into node red so I can set a state of evening which triggers some lights.
It does have to be bang on, and I’ll remove the date porting and leave just the time.
