Hello everyone,
I have been trying but I do not seem to be able to get KNX group addresses to be attached to an entity.
I am trying to create a script that will turn all the lights in the house on and then off individually to see if they are working through the KNX.
However I cant seem to get a list of the address not attach the addresses to the entities in any way other then manual, which I would rather avoid as I work in several instalations.
So I assume that somehow the HA has this addresses stored somewhere, considering I am giving it to the knx.
So if the HA has access to this files is there anyway I can also access them through an automation? It feels like there should be a way for me to access this information
If you could help me that would be great, thank you for your attention
The problem is that I wanted to do them individually, so I can test if each of them is working properly. And because I work with different instalation I wanted to do something that could utilize only the information that the Home Assistant has and that dosent require me to manually configure it
You will have to configure either an entity via the yaml or the KNX integration after you imported your ETS project file, the latter makes it much easier tho.
But HA has no way of knowing what is in your KNX installation without you telling what is in there. No Autodiscover or anything like that.
If its only for testing you can use the knx.send in the Developer tools
From what I have seen they do not which is rather unfortunate. I have considered that option but I fear that those would be too little for a full range of tests (for example you can turn a light on and off but there none to adjust brightness or rgbw). I will try doing it without the group address and see if that will be enough.
Would be really good if you could access the address through templates though
