2022-11-16 15:00:18.646 WARNING (MainThread) [homeassistant.components.heos] 192.168.2.161 is not logged in to a HEOS account and will be unable to retrieve HEOS favorites: Use the 'heos.sign_in' service to sign-in to a HEOS account
2022-11-16 15:00:19.611 WARNING (MainThread) [meross_iot.manager] Found a new device computer (mss210, HW 6.0.0, FW 6.2.3, class: mss210:6.0.0:6.2.3) that has become online while we were offline.
2022-11-16 15:00:21.423 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Canon TR4500 series' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2022-11-16 15:00:25.891 WARNING (MainThread) [homeassistant.setup] Setup of gigasetelements is taking over 10 seconds.
2022-11-16 15:01:10.214 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: gigasetelements
2022-11-16 15:02:10.516 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: gigasetelements
2022-11-16 15:03:10.832 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: gigasetelements
2022-11-16 15:04:11.067 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: gigasetelements
2022-11-16 15:05:11.239 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: gigasetelements
2022-11-16 15:05:15.892 ERROR (MainThread) [homeassistant.setup] Setup of gigasetelements is taking longer than 300 seconds. Startup will proceed without waiting any longer
2022-11-16 15:05:27.422 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2022-11-16 15:17:44.765 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.alarm_control_panel: Unable to set up component.
2022-11-16 15:17:44.775 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.binary_sensor: Unable to set up component.
2022-11-16 15:17:44.786 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.climate: Unable to set up component.
2022-11-16 15:17:44.795 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.sensor: Unable to set up component.
2022-11-16 15:17:44.807 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.switch: Unable to set up component.
2022-11-16 15:20:41.156 WARNING (MainThread) [homeassistant.components.samsungtv] Unable to set volume level on 192.168.2.181: UpnpActionResponseError('Error during async_call(), status: 500, upnp error: 501 (Action Failed)')
2022-11-16 15:20:44.208 WARNING (MainThread) [homeassistant.components.samsungtv] Unable to set volume level on 192.168.2.181: UpnpActionResponseError('Error during async_call(), status: 500, upnp error: 501 (Action Failed)')
2022-11-16 15:20:45.665 WARNING (MainThread) [homeassistant.components.samsungtv] Unable to set volume level on 192.168.2.181: UpnpActionResponseError('Error during async_call(), status: 500, upnp error: 501 (Action Failed)')
2022-11-16 15:20:48.448 WARNING (MainThread) [homeassistant.components.samsungtv] Unable to set volume level on 192.168.2.181: UpnpActionResponseError('Error during async_call(), status: 500, upnp error: 501 (Action Failed)')
2022-11-16 15:24:35.053 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request Server disconnected
Logger: homeassistant.setup
Source: setup.py:237
First occurred: 15:30:02 (1 occurrences)
Last logged: 15:30:02
second part
Source: setup.py:339
First occurred: 15:42:31 (5 occurrences)
Last logged: 15:42:31
This might be out of scope of the intented use case of the integration but I only own a Gigaset C430A Go DECT phone, for which I can see the events (outgoing, incoming, lost calls) in Gigaset Elements - Web Application.
However, when trying to set up the integration, I get the following error:
This error originated from a custom integration.
Source: custom_components/gigasetelements/__init__.py:134
Integration: gigasetelements (documentation, issues)
First occurred: 1:44:15 PM (1 occurrences)
Last logged: 1:44:15 PM
Error during setup of component gigasetelements
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/home/homeassistant/.homeassistant/custom_components/gigasetelements/__init__.py", line 105, in setup
client = GigasetelementsClientAPI(
File "/home/homeassistant/.homeassistant/custom_components/gigasetelements/__init__.py", line 134, in __init__
self._property_id = self._basestation_data.json()[0]["id"]
IndexError: list index out of range
Do you think it’s something you could help with? Thanks in advance!
Hi @dynasticorpheus I‘m struggling integrating gigaset elements on my home assistant. I have downloaded the integration and see it in the hacs area with the docu. I have the files in file editor under custom components and copied the provided scheme into my configuartion.yaml folder with my login details. When i check under dev tools i get an error message, that the integration is not found. I feel like i‘m missing a step or might have a syntax error? Its my first custom integration, so im a bit lost with what the basic steps are and what to think of.
Here the logs:
2023-04-22 12:29:28.015 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.alarm_control_panel: Unable to set up component.
2023-04-22 12:29:28.022 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.binary_sensor: Unable to set up component.
2023-04-22 12:29:28.031 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.climate: Unable to set up component.
2023-04-22 12:29:28.039 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.sensor: Unable to set up component.
2023-04-22 12:29:28.047 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform gigasetelements.switch: Unable to set up component (I opened a Github issue).
Home Assistant 2023.4.6
Supervisor 2023.04.0
Operating System 10.0
Frontend 20230411.1 - latest
is this still alive???
because i can’t get it working at all…
the files are there tho…
and added the cofig in yaml…
but getting always errors too as above…
thank you
You are also using HASS OS? @liflitz confirmed things started working again after installing latest version but was not sure why it was not working for a while.
Im running latest Ha and keep it always updated…
Runs on newest Pi 4 8gb and ssd on usb 3.1
I do see the files in components etc proper place…
Added also the correct stuff in config…
Then errors appear after reboot…
Gimmie a few… to post the errors…i do known it’s
Python related…
Anyway the entities will not appear…
Im asking this because i want to show the canera
Of the doorbell on Ha…
Thank You!
Log:
Source: custom_components/gigasetelements/__init__.py:138
Integration: gigasetelements ([documentation](https://github.com/dynasticorpheus/gigasetelements-ha/blob/9d772615189f7f40996b43569e55b57c7aae704f/README.md), [issues](https://github.com/dynasticorpheus/gigasetelements-ha/issues))
First occurred: 17:26:13 (1 occurrences)
Last logged: 17:26:13
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/setup.py", line 286, in _async_setup_component result = await task ^^^^^^^^^^ File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/custom_components/gigasetelements/__init__.py", line 108, in setup client = GigasetelementsClientAPI( ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/custom_components/gigasetelements/__init__.py", line 138, in __init__ self._property_id = self._basestation_data.json()[0]["id"] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^ IndexError: list index out of range
