Gigaset has a internal software update which blow off the connectivity to the clients.
we called up the customer support to get that info last Monday.
So best thing is we gotta waitā¦
Thank youā¦
Are things working ok when using the official app?
Deze fout is ontstaan door een aangepaste integratie.
Logger: homeassistant.setup
Source: custom_components/gigasetelements/__init__.py:138
Integration: gigasetelements (documentation, issues)
First occurred: 09:11:56 (1 occurrences)
Last logged: 09:11:56
Error during setup of component gigasetelements
File "/usr/src/homeassistant/homeassistant/setup.py", line 288, in _async_setup_component
result = await task
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/gigasetelements/__init__.py", line 108, in setup
client = GigasetelementsClientAPI(
File "/config/custom_components/gigasetelements/__init__.py", line 138, in __init__
self._property_id = self._basestation_data.json()[0]["id"]
IndexError: list index out of range
Still having this issueā¦
Maybe Iām to stupidā¦but do I need the hub?
Note 2ā¦when I use the original gigaset elements app
That works flawlessā¦
My goal was to integrate the doorbell cam on HAā¦
Thank You
Good Morning,
I somehow got a up to 5 sec delay between the Gigaset Motion sensor and Hue lamb via HA; when it run the same setup via the Gigaset app, its as expected instantly; any tip what could I do to speed things up with HA?!
@Tadies The hub is required. Will add some code to have this logged / abort setup when not detected.
@Kuechenfenster This is a delay due to API call rate limiting on gigaset server side. If we poll more often you will be temporary blocked from pulling new info, nothing we can do here I am afraid.
guess i did miss that!
but didnāt found any post or howto
if the hub was neededā¦maybe i was wrongā¦
lets see if i can find that solved button againā¦
cause its gone again!
thank you Dynasticā¦
any way to get this locally addressed via a MQTT?
No I am afraid not
Good morning
Unfortunately, my installation is not working. I installed the extension via HACS, and the entry in the /config/configuration.yaml looks like this:
gigasetelements:
# Name for components
name: "Gigaset Sensoren"
# Username - your username to Gigaset Elements
username: xxxxx
# Password - your password to Gigaset Elements
password: xxxx
# Switches - create switches for armed_away, armed_home and armed_night
switches: False
# Code - Code to enable or disable the alarm in the frontend
code: 1234
# Code_arm_required - require code for armed_away, armed_home and armed_night
code_arm_required: False
The entities are provided, but they are not functioning. Except when Home Assistant is restarted, the current state is displayed correctly.
Perhaps someone has an idea on how to make my sensors work?
Can you provide the debug logs by adding below entry in your configuration.yaml?
logger:
default: info
logs:
custom_components.gigasetelements: debug
Hi dynasticorpheus,
so far I have used gigasetelements-cli under FHEM for the gigaset-elements system. Kow I use home assistant with your custom integration.
I used the privacy settings with
gigasetelements-cli -c gigasetelements-cli.conf -y on -j
gigasetelements-cli -c gigasetelements-cli.conf -y off -j
How can I switch this on under Home Assistant? I have not found it.
Hi @Sille
I still need to add this functionality so if you could log this as feature request on github I will try and add soon, initially in develop version.
hi,
is it possible to trigger the alarm with a hue sensor?
The integration creates a switch.gigaset_elements_panic_mode in case it detects a siren. The hue sensor is not supported by the integration itself but have a look at the manual alarm integration to combine both.
thanks, sorry Iām newbieā¦
I can see this Entities switch: gigaset_elements_panic_mode
but how can I add it under my automation, should be an action right?
but in the dropdown I couldnāt find it.
Are you using the service switch.turn_on ?
Oh I never thought it would be so simpleā¦ Cool, here we go
thanks.
