Recently I had a GivEnergy battery fitted to the at the house. Of course I decided to make things difficult, so each component of my micro-power-plant is from a different manufacturer. Home Assistant to the rescue!
So while cutting down from 3 apps to one (HA), I was bashing my head against the RestAPI not working for GivEnergy in Home Assistant. Since I’m not known for giving up easily… I figured Node-Red may be able to help. I’d been meaning to figure it out. So after a crash course yesterday and mucking about with the API and figuring out MQTT sensor auto discovery in Home Assistant, here’s my first stab (I’ll update things that aren’t finished as I go and any suggestions welcome).
"id": "f6f2187d.f17ca8",
"type": "tab",
"label": "GivEnergy.cloud",
"disabled": false,
"info": ""
"id": "ccdb2874.ab7a18",
"type": "debug",
"z": "f6f2187d.f17ca8",
"name": "Battery Data Response",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 1090,
"y": 920,
"wires": []
"id": "b24cd458.b49cc",
"type": "comment",
"name": "Login to GivEnergy via cloud API",
"info": "ya know. cause\n\n# https://kb.givenergy.cloud/article.php?id=5",
"x": 130,
"y": 40,
"wires": []
"id": "7eee2f3.48c4c5",
"type": "inject",
"name": "Login",
"props": [
"p": "headers",
"v": "{\"Content-type\":\"application/x-www-form-urlencoded\"}",
"vt": "json"
"p": "payload.account",
"v": "<your_username>",
"vt": "str"
"p": "payload.password",
"v": "<yourpassword>",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payloadType": "str",
"x": 114,
"y": 130,
"wires": [
"b2f7a9b1.c2fc4"
"id": "b2f7a9b1.c2fc4",
"type": "http request",
"name": "GivEnergy Login",
"method": "POST",
"ret": "txt",
"paytoqs": "ignore",
"url": "https://www.givenergy.cloud/GivManage/api/login",
"tls": "",
"persist": true,
"proxy": "",
"authType": "",
"x": 324,
"y": 130,
"wires": [
"e6cfdae3.a14ab8"
"id": "cd7a7a2.d208888",
"type": "change",
"name": "Re-Authenticate",
"rules": [
"t": "set",
"p": "headers",
"pt": "msg",
"to": "{\"Content-type\":\"application/x-www-form-urlencoded\"}",
"tot": "str"
"t": "set",
"pt": "msg",
"to": "<username>",
"tot": "str"
"t": "set",
"pt": "msg",
"to": "<yourpassword>",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 320,
"y": 300,
"wires": [
"b2f7a9b1.c2fc4"
"id": "fefa9bf5.c6d208",
"type": "inject",
"name": "Trigger",
"props": [
"p": "topic",
"vt": "str"
"p": "payload.dateText",
"v": "",
"vt": "date"
"repeat": "14400",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"x": 60,
"y": 460,
"wires": [
"a93f4949.f03848"
"id": "7ce8cafd.ede13c",
"name": "Get Battery Cell Data",
"method": "POST",
"ret": "txt",
"url": "https://www.givenergy.cloud/GivManage/api/pcs/batCell/getBatCellData",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 740,
"y": 920,
"wires": [
"529aa07.d9e686"
"id": "5a8de257.3c6584",
"type": "change",
"name": "Set serial number",
"rules": [
"t": "delete",
"p": "payload",
"pt": "msg"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"plantId\":\"<your plant ID>\",\"type\":\"0\",\"serialNum\":\"<serial number>\"}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 503,
"y": 924,
"wires": [
"7ce8cafd.ede13c"
"id": "a93f4949.f03848",
"type": "moment",
"name": "Today's date",
"topic": "",
"input": "payload.dateText",
"inputType": "msg",
"inTz": "Europe/London",
"adjAmount": 0,
"adjType": "days",
"adjDir": "add",
"format": "YYYY-MM-DD",
"locale": "en-US",
"output": "payload.dateText",
"outputType": "msg",
"outTz": "Europe/London",
"x": 110,
"y": 540,
"wires": [
"id": "56432a94.4ea86c",
"name": "Get Plant Devices",
"method": "POST",
"ret": "txt",
"url": "https://www.givenergy.cloud/GivManage/api/plant/getPlantDevices",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 770,
"y": 640,
"wires": [
"b71a4c8.bcc0fb"
"id": "932bcf16.3725c8",
"type": "change",
"name": "Set Plant ID",
"rules": [
"t": "delete",
"p": "payload",
"pt": "msg"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"plantId\":\"<your plant ID>\"}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 550,
"y": 640,
"wires": [
"56432a94.4ea86c"
"id": "b5d7ffa4.6c835",
"type": "switch",
"name": "Succeed?",
"property": "statusCode",
"propertyType": "msg",
"rules": [
"t": "neq",
"v": "200",
"vt": "str"
"t": "eq",
"v": "200",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 100,
"y": 320,
"wires": [
"cd7a7a2.d208888"
"fcc238de.e44408",
"3afda1e3.a46596",
"6c87547a.976e9c",
"a154ed8a.38f2b",
"d1b8ddf1.d9116",
"29affd13.37ed9a"
"id": "49a50baf.04d474",
"type": "inject",
"name": "Start me up",
"props": [
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 90,
"y": 200,
"wires": [
"id": "c9ca993f.de0ae8",
"type": "debug",
"name": "Devices Response",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1110,
"y": 600,
"wires": []
"id": "8f3cd597.e9d5b8",
"type": "debug",
"name": "Login Response",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 580,
"y": 140,
"wires": []
"id": "e6cfdae3.a14ab8",
"type": "change",
"name": "Set session variable",
"rules": [
"t": "set",
"p": "givEnergyHeaderCookie",
"pt": "flow",
"to": "headers.set-cookie",
"tot": "msg"
"t": "set",
"p": "givEnergyResCookies",
"pt": "flow",
"to": "responseCookies",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 324,
"y": 210,
"wires": [
"d4ee3c94.2ba5f"
"id": "2c8baa3a.093766",
"name": "Get plant summary",
"method": "POST",
"ret": "txt",
"url": "https://www.givenergy.cloud/GivManage/api/plant/getPlantSummary",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 854,
"y": 210,
"wires": [
"b5d7ffa4.6c835",
"d8dbd7be.3dee38",
"c1e5d7f6.93911"
"id": "f18ae8a.33fe598",
"type": "debug",
"name": "Plant summary",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1100,
"y": 220,
"wires": []
"id": "d4ee3c94.2ba5f",
"type": "change",
"name": "form-urlencoded header",
"rules": [
"t": "set",
"p": "headers",
"pt": "msg",
"tot": "json"
"t": "set",
"p": "cookies",
"pt": "msg",
"to": "givEnergyResCookies",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 594,
"y": 210,
"wires": [
"2c8baa3a.093766"
"id": "4eaa2e23.6318d8",
"type": "change",
"rules": [
"t": "set",
"p": "headers",
"pt": "msg",
"tot": "json"
"t": "set",
"p": "cookies",
"pt": "msg",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 270,
"y": 920,
"wires": [
"5a8de257.3c6584"
"id": "fcc238de.e44408",
"type": "change",
"rules": [
"t": "set",
"p": "headers",
"pt": "msg",
"tot": "json"
"t": "set",
"p": "cookies",
"pt": "msg",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 330,
"y": 640,
"wires": [
"932bcf16.3725c8"
"id": "b71a4c8.bcc0fb",
"type": "switch",
"name": "Succeed?",
"rules": [
"t": "neq",
"v": "200",
"vt": "str"
"t": "eq",
"v": "200",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 120,
"y": 760,
"wires": [
"cd7a7a2.d208888"
"4eaa2e23.6318d8",
"9fd68874.647aa"
"id": "d8dbd7be.3dee38",
"type": "mqtt out",
"name": "",
"topic": "givenergy/cloud/summary",
"qos": "",
"retain": "",
"broker": "d04b7308.3e7f58",
"x": 1090,
"y": 280,
"wires": []
"id": "9fd68874.647aa",
"type": "mqtt out",
"name": "",
"topic": "givenergy/cloud/devices",
"qos": "",
"retain": "",
"x": 1110,
"y": 740,
"wires": []
"id": "a732ae86.08fbf8",
"type": "mqtt out",
"name": "",
"topic": "givenergy/cloud/batteryData",
"qos": "",
"retain": "",
"x": 980,
"y": 1120,
"wires": []
"id": "c1fd0ef9.bf4fe",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "10",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 920,
"y": 1040,
"wires": [
"d4ee3c94.2ba5f"
"id": "5d20f7f5.2b9ee8",
"type": "mqtt out",
"name": "",
"topic": "homeassistant/sensor/GivEnergy_BatteryPower/G345/config",
"qos": "",
"retain": "",
"x": 1520,
"y": 420,
"wires": []
"id": "c42be291.797ee8",
"type": "mqtt out",
"name": "",
"topic": "givenergy/cloud/status",
"qos": "",
"retain": "",
"x": 1280,
"y": 140,
"wires": []
"id": "c1e5d7f6.93911",
"type": "switch",
"name": "Set topic state",
"rules": [
"t": "neq",
"v": "200",
"vt": "str"
"t": "eq",
"v": "200",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 860,
"y": 140,
"wires": [
"c983d358.776f2"
"715ebbd5.ec78b4"
"id": "715ebbd5.ec78b4",
"type": "change",
"name": "Online",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Online",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1030,
"y": 160,
"wires": [
"c42be291.797ee8"
"id": "c983d358.776f2",
"type": "change",
"name": "Offline",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Offline",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1030,
"y": 120,
"wires": [
"c42be291.797ee8"
"id": "27d432e2.478a96",
"type": "mqtt out",
"name": "",
"topic": "homeassistant/sensor/GivEnergy_BatterySOC/G345/config",
"qos": "",
"retain": "",
"x": 1520,
"y": 360,
"wires": []
"id": "3afda1e3.a46596",
"type": "change",
"name": "HA Disc Conf (battery soc)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"name\":\"Battery State of Charge (GE)\",\"stat_t\":\"givenergy/cloud/summary\",\"avty_t\":\"givenergy/cloud/status\",\"pl_avail\":\"Online\",\"pl_not_avail\":\"Offline\",\"json_attr_t\":\"givenergy/cloud/summary\",\"unit_of_meas\":\"%\",\"val_tpl\":\"{{value_json['soc']}}\",\"ic\":\"mdi:battery\",\"uniq_id\":\"G345-I-BattSoC-1\",\"device_class\":\"battery\",\"dev\":{\"ids\":[\"G345-I-BattSoC_1\"],\"mf\":\"GivEnergy\"}}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1120,
"y": 360,
"wires": [
"27d432e2.478a96"
"id": "6c87547a.976e9c",
"type": "change",
"name": "HA Disc Conf (battery power)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"name\":\"Battery power (GE)\",\"stat_t\":\"givenergy/cloud/summary\",\"avty_t\":\"givenergy/cloud/status\",\"pl_avail\":\"Online\",\"pl_not_avail\":\"Offline\",\"unit_of_meas\":\"kW\",\"val_tpl\":\"{{value_json['batPower']}}\",\"ic\":\"mdi:battery-charging\",\"uniq_id\":\"G345-I-BattPower-1\",\"device_class\":\"power\",\"dev\":{\"ids\":[\"G345-I-BattPower_1\"],\"mf\":\"GivEnergy\"}}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1120,
"y": 420,
"wires": [
"5d20f7f5.2b9ee8"
"id": "523082bb.23e574",
"type": "mqtt out",
"name": "",
"topic": "homeassistant/sensor/GivEnergy_LoadPower/G345/config",
"qos": "",
"retain": "",
"x": 1510,
"y": 480,
"wires": []
"id": "a154ed8a.38f2b",
"type": "change",
"name": "HA Disc Conf (load power)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"name\":\"Load power (GE)\",\"stat_t\":\"givenergy/cloud/summary\",\"avty_t\":\"givenergy/cloud/status\",\"pl_avail\":\"Online\",\"pl_not_avail\":\"Offline\",\"unit_of_meas\":\"kW\",\"val_tpl\":\"{{value_json['loadPowerkW']}}\",\"ic\":\"mdi:home-lightbulb\",\"uniq_id\":\"G345-I-LoadPower\",\"device_class\":\"power\",\"dev\":{\"ids\":[\"G345-I-LoadPower\"],\"mf\":\"GivEnergy\"}}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1120,
"y": 480,
"wires": [
"523082bb.23e574"
"id": "bc54e66e.9f5a2",
"type": "mqtt out",
"name": "",
"topic": "homeassistant/sensor/GivEnergy_PVPower/G345/config",
"qos": "",
"retain": "",
"x": 1510,
"y": 540,
"wires": []
"id": "d1b8ddf1.d9116",
"type": "change",
"name": "HA Disc Conf (PV power)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"name\":\"Solar PV power (GE)\",\"stat_t\":\"givenergy/cloud/summary\",\"avty_t\":\"givenergy/cloud/status\",\"pl_avail\":\"Online\",\"pl_not_avail\":\"Offline\",\"unit_of_meas\":\"kW\",\"val_tpl\":\"{{value_json['pvPower']}}\",\"ic\":\"mdi:solar-power\",\"uniq_id\":\"G345-I-PVPower\",\"device_class\":\"power\",\"dev\":{\"ids\":[\"G345-I-PVPower\"],\"mf\":\"GivEnergy\"}}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1110,
"y": 540,
"wires": [
"bc54e66e.9f5a2"
"id": "c2ae18c6.bf046",
"type": "mqtt out",
"name": "",
"topic": "homeassistant/sensor/GivEnergy_GridPower/G345/config",
"qos": "",
"retain": "",
"x": 1510,
"y": 600,
"wires": []
"id": "29affd13.37ed9a",
"type": "change",
"name": "HA Disc Conf (Grid power)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"name\":\"Grid power (GE)\",\"stat_t\":\"givenergy/cloud/summary\",\"avty_t\":\"givenergy/cloud/status\",\"pl_avail\":\"Online\",\"pl_not_avail\":\"Offline\",\"unit_of_meas\":\"kW\",\"val_tpl\":\"{{value_json['gridPowerKW']}}\",\"ic\":\"mdi:transmission-tower\",\"uniq_id\":\"G345-I-gridPower\",\"device_class\":\"power\",\"dev\":{\"ids\":[\"G345-I-gridPower\"],\"mf\":\"GivEnergy\"}}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1120,
"y": 600,
"wires": [
"c2ae18c6.bf046"
"id": "fb36df59.a1777",
"type": "change",
"name": "HA Disc Conf (Battery Data)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"name\":\"Battery Data (GE)\",\"stat_t\":\"givenergy/cloud/batteryData\",\"avty_t\":\"givenergy/cloud/status\",\"pl_avail\":\"Online\",\"pl_not_avail\":\"Offline\",\"json_attr_t\":\"givenergy/cloud/batteryData\",\"unit_of_meas\":\"%\",\"val_tpl\":\"{{value_json['modules']['moduleSoc']}}\",\"ic\":\"mdi:battery-heart-variant\",\"uniq_id\":\"G345-I-BatteryData_1\",\"device_class\":\"battery\",\"dev\":{\"ids\":[\"G345-I-BatteryData-1\"],\"mf\":\"GivEnergy\"}}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 700,
"y": 1220,
"wires": [
"7d29875a.bd347"
"id": "7d29875a.bd347",
"type": "mqtt out",
"name": "",
"topic": "homeassistant/sensor/GivEnergy_BattData/G345/config",
"qos": "",
"retain": "",
"x": 1090,
"y": 1220,
"wires": []
"id": "3b614ef6.735aca",
"type": "comment",
"name": "Serial number",
"info": "Add it as a flow variable.\nFigure out how to push it into MQTT topics & inject it into the payload",
"x": 1150,
"y": 700,
"wires": []
"id": "529aa07.d9e686",
"type": "switch",
"name": "Succeed?",
"rules": [
"t": "neq",
"v": "200",
"vt": "str"
"t": "eq",
"v": "200",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 140,
"y": 1080,
"wires": [
"cd7a7a2.d208888"
"c1fd0ef9.bf4fe",
"a732ae86.08fbf8",
"fb36df59.a1777"
"id": "3c99cf47.e89008",
"type": "comment",
"name": "Get battery - lifetime/annual data",
"info": "plant/getPlantEnergy",
"x": 160,
"y": 420,
"wires": []
"id": "d04b7308.3e7f58",
"type": "mqtt-broker",
"name": "your-mqtt",
"broker": "your-mqtt-server-like-mosquitto",
"port": "1883",
"clientid": "node-red1",
"usetls": false,
"compatmode": true,
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"willTopic": "",
"willQos": "0",
"willPayload": ""
Be sure to replace the placeholder data I put in with your own (username, password, plantID, inverter serial numbers, MQTT hosts). Then just head back into Home Assistant, and if you’ve got MQTT integration set up, it should show up. … in node red, you need to trigger the login once. I forgot to set that before I grabbed the code and I’m now too hungry (dinner time!) to fix it now.
On the to-do list:
- Set the serial number as a flow variable, use that to populate the auto discovery stuff for things like, serial numbers, firmware versions, etc.
- Finish the battery integration.
- Figure out how to get this ‘power wheel’ card working with the data from this battery (cloud api), zappi charger(via their API) and solaredge (modbus)
- Carry on talking to GivEnergy to get the local API.
- Start talking to MyEnergi (Zappi) to get a local API to their hub.
- Learn python so I can create custom components for these things.
