GLaDOS (Portal) voice pack for Roborock / Xiaomi vacuums
Few voices are more appropriate for a vacuum cleaner than the one of GLaDOS, the core that runs the Aperture Science testing center in the Portal games.
Download a voice pack I created for xiaomi or roborock vacuums here. It’s a combination of text-to-speech in GLaDOS’ voice and original samples.
I also created a few scripts that allow you to edit the text GLaDOS says and installed a tool called the oucher that can make her say stuff when bumping into something. Check out the full guide and video.
Cheers!
Having just installed Valetudo yesterday after a couple of years of having our roborock, this is exciting!
Thank you very much! I just played Portal with the kids so they were very excited to hear glados wondering throughout the house :laughing:
Just found out about Valetudo and its custom voices. And love your voicepack. Very funny to hear some fine GlaDOS comments when my house is vacuumed :smiley: Thanks!
Hello, I’m the roborock-oucher developer. Thanks for sharing this and for making a tutorial to install it, I really, really appreciate :slight_smile: maybe I can link your tutorial in the project GitHub page?
Thanks!
So, you’re the reason my vacuum won’t shut up? :wink:
LOL Nice work on that, btw.
Yeah, my wife hates me for this, actually :sweat_smile:
Yes, of course! Before I found your solution, I was wondering how to do hook into the events of the vacuum. Clever, watching the logs :slight_smile:
Well you need to be lucky actually; I’ve seen logs are hard to understand and I think not really everything is reported in them.
In this case I was very lucky: the bumper log entries had the “Bumper” word in them, and the only thing I had to do is to filter out some entries that log the “restore” of the bumper after it hits something.
But I’m not sure I would understand the other things it logs :sweat_smile:
Yes, of course!
Thank you very much :slight_smile:
how do i install this amazing voicepack?
SCP into the vacuum and replace the voice-files in /opt/rockrobo/resources/sounds/en.
Install from the UI doesn’t work for some reason, I’ve only been able to install the original english.pkg there.
@arner thank you for this voice pack! Sadly, the tinyulpoad.com link on Posts for the oucher sound files download doesn’t work anymore. Could you please upload them to a github release or something?
I’ve been trying so hard to get this to work, alas my tech knowledge doesn’t extend this far…
I’ve installed Valetudo on my S5, everythings working great but can’t figure out how to get this voice pack loaded onto it. Valetudo asks for a URL, Language & Hash - I’m using the link as https://github.com/arner/roborock-glados/releases/download/v1/custom-v1.zip along with EN (uppercase) for the language, and no idea how to find the hash.
Using the above, I just get “Error installing voice pack. Check the log for details.”
The log shows "
RoborockVoicePackManagementCapability: Failed to install Voicepack. Unknown error code 4"
I GOT IT! For those in 2042 whom come across this thread, you’ll need a few things;
Firstly you’ll need to flash Valetudo onto your roborock;
  1. On an android mobile or tablet, find and download Xvacuum
  2. On a PC goto https://dustbuilder.dontvacuum.me/ and select your model (mine was S5)[this basically builds the Valetudo install for you]
  3. Ensure to select the following
  • Let DustBuilder generate a SSH Keypair for you
  • Preinstall valetudo ver. 2022.03.1 (or whatever is the latest)
  • Build update package (for installation with python-miio/RRCC)
You’ll receive an email with the firmware.pkg (save it to your mobile/tablet)
You’ll also receive some ‘SSH keys’ / ‘Authentication Keys’. These are a file you’ll need back on the PC later.
  1. Watch this video to get Valetudo on your vacuum [EN] How to easily root the Roborock with only an Android device - YouTube
  2. Have a play around and have a break, you deserved it!
  3. Download WinSCP for PC and launch it
  4. Select the following;
  • File protocol SCP
  • Host name will be your robots IP address
  • Username is root
  • Password leave blank
  • Click on Advanced
  • Click on Authentication (under the SSH heading)
  • In the area that says ‘Private Key file’ find the SSH key file from earlier (ends in .ppk)
  • OK, Save, Login
You’ll have full access to the file directory to overwrite the origional language pack located in /opt/rockrobo/resources/sounds/en
Enjoy!
Hello there,
I am trying to get the firmware (aquired from dustbuilder) on my Roborock s50.
But somehow when i use
mirobo --ip 192.168.8.1 --token <my token> update-firmware --ip 192.168.8.18 D:\Downloads\robo\v11_002034.pkg
It gives me the following error:
Going to update from D:\Downloads\robo\v11_002034.pkg
INFO:miio.updater:Serving on 0.0.0.0:51787, timeout 10
INFO:miio.updater:Using local D:\Downloads\robo\v11_002034.pkg (md5: b0b83d62ccda4fee2e3c11e7869c748f)
Hosting file at http://192.168.8.18:51787/v11_002034.pkg
ERROR:miio.updater:No request was made..
ERROR:miio.miioprotocol:Got error when receiving: timed out
Error: No response from the device
Am I doing something wrong?
@Bishamon1987 I had the same issue with two robots. Make sure it is charged at least 20% and placed on the docking pad while you try to update. Also have the laptop close to the robot. It took me various tries until the request was finally made.
Not quite 2042 but im thankfull for your instruction ill probably try this tonight
Did you find out why this doesn’t work anymore?
Sorry to bump such an old thread. I’ve been going down the voice pack rabbit hole for my Q7 Max+, has anybody had any luck here?
I am running valetudo and have oucher working but I can’t figure out how to use this voice pack with my vacuum. I found my sound files but they are not in /opt/rockrobo/ etc , they are under /mnt/resources/ somewhere and are read-only ogg files. Is there a way I can upload it through the app?
I stumbled onto this one as well and there is actually a quite easy fix for it, however I didn’t give it a try using the app, as I don’t understand how it works :smiley:
When logging into the robot remotely via ssh, you’ve already found that the files in /mnt/resources are read only. This is where you can dig just a little deeper:
[root@rockrobo ~]# mount
/dev/nandh on /mnt/resources/audio_bit type squashfs (ro,relatime)
/dev/nandj on /mnt/resources/audio_custom type squashfs (ro,relatime)
/dev/nandi on /mnt/resources/audio_default type squashfs (ro,relatime)
You should find the audio files are mounted in as read-only from the various /dev/nand*s.
While you cannot remount with rw, what you can do is unmount… :wink:
As I just wanted the GLaDOS sounds, I copied the content of the /mnt/resources/audio_default directory into /mnt/data/custom_sounds, then I grabbed a copy of the glados sounds, converted them into ogg files and overwrote the files that are already in the audio_default/sounds/ folder.
Finally I modified the /mnt/reserve/_root.sh so it waits until an existing file from /dev/nandi becomes available, then unmounts that device and mounts my folder from /mnt/data in its place, it currently looks like this, I added the last 5 lines in the if statement:
#!/bin/bash
if [[ -f /mnt/data/valetudo ]]; then
        mkdir -p /mnt/data/miio/
        if grep -q -e "cfg_by=tuya" -e "cfg_by=rriot" /mnt/data/miio/wifi.conf; then
                sed -i "s/cfg_by=tuya/cfg_by=miot/g" /mnt/data/miio/wifi.conf
                sed -i "s/cfg_by=rriot/cfg_by=miot/g" /mnt/data/miio/wifi.conf
                echo region=de >> /mnt/data/miio/wifi.conf
                echo 0 > /mnt/data/miio/device.uid
                echo "de" > /mnt/data/miio/device.country
        fi
        # Delete useless cleanup logs on each boot to enable Valetudo to update itself
        rm -r /mnt/data/rockrobo/rrlog/*REL
        VALETUDO_CONFIG_PATH=/mnt/data/valetudo_config.json /mnt/data/valetudo >> /dev/null 2>&1 &
        while [[ ! -f /mnt/resources/audio_default/power_on.ogg ]]; do sleep 1; done
        sleep 1
        umount /dev/nandi
        sleep 1
        mount /mnt/data/custom_sounds/audio_default /mnt/resources/audio_default
fi
This should get you going… :slight_smile:
