Quick reminder of what this thing is, for anyone landing here first:
GLaSSIST turns your desktop PC into a full voice satellite for Home Assistant. Not a companion app, not a remote - an actual satellite your HA instance talks to.
Connects over WebSocket or as a native ESPHome satellite - your PC shows up in HA like any other voice device
100+ bundled wake word models - Alexa, Jarvis, Scarlett, GLaDOS, Computer, and a lot more
Works with any conversation agent HA supports - Claude, GPT, Gemini, Ollama, or plain native Assist
Trigger by wake word, global hotkey, or system tray
Three.js overlay with real-time FFT audio visualization
Optional response text on screen
Optional media player volume ducking while youāre talking
Modern settings UI - no config file editing, ever
HTTP prompt API so HA automations can start the conversation instead of you
The occasion
GLaSSIST just passed 50 stars on GitHub and well over 1,700 downloads. A big chunk of the people showing up were on Linux, staring at a 900-line install script and hoping for the best. So thatās what got fixed.
3.5.0 - Linux Revolution
Linux went from ātechnically supportedā to a first-class citizen.
Flatpak
flatpak install --user GLaSSIST.flatpak
flatpak run io.github.SmolinskiP.GLaSSIST
One command, any distro - Ubuntu, Fedora, Arch, whatever you run. Everything is bundled:
GNOME 49 runtime with WebKitGTK, ffmpeg/libmpv, PortAudio, all Python dependencies. No install script roulette, no hunting for the right -dev package for your distro.
The bundle is attached to every release and built automatically in CI. Config lives in ~/.var/app/io.github.SmolinskiP.GLaSSIST/config/glasssist/.env, custom sounds go in the matching data/ directory.
On Flathub: not happening, at least not in this form - Flathub doesnāt accept tray-resident applications, and the tray is how GLaSSIST is meant to live. So grab the bundle from GitHub Releases. The built-in update check (see below) will tell you when thereās a new one.
Native desktop experience
Overlay behaves like it does on Windows - click-through so mouse events reach the windows underneath, skips the taskbar, stays on top, sits bottom-center. Pure GTK, works inside the sandbox, no
wmctrlorxdotoolneeded. -
System tray is back on Linux via AppIndicator/StatusNotifier - it used to be disabled entirely.
WebKitGTK rendering fix - the orb no longer freezes its last frame on screen after a session ends.
Wake word on Python 3.13 - automatic ONNX fallback when the TFLite runtime isnāt there. 3.5.2 followed up with a Flatpak-specific fix: openWakeWord wants to download its default models on first run, which is impossible in a read-only sandbox, so a fresh install crashed on startup. Those models now ship inside the package and wake word works immediately after install.
3.6.0 - Conversation memory & update checks
Follow-ups actually work now. GLaSSIST never sent Home Assistantās conversation_id back, so every command started a brand-new conversation with no history. Say āturn the desk light onā, then āturn it off againā - youād get āwhich device did you mean?ā instead of the obvious answer. Now the conversation ID round-trips properly.
New HA_CONVERSATION_TIMEOUT setting (slider in Settings) controls how long context is kept - default 300 s, 0 disables it. Only matters if youāre running an LLM conversation agent.
Built-in update checking. On startup GLaSSIST checks GitHub for a newer release and shows a brief cyan āUpdate availableā animation. Your current version and a one-click Update link now sit in a bar at the top of Settings. HA_UPDATE_CHECK=false turns it off if youād rather not.
3.6.1 - Input audio delay fix
The mic buffer wasnāt being flushed before recording started, so GLaSSIST replayed 1-2 seconds of stale audio - it picked up speech from before you triggered it, and cut off the end of what you actually said. Some people found they had to start talking before the wake word for it to work. It now records from the live edge.
Most noticeable on Linux, which is exactly why it took a Linux user to pin it down.
Known limitations on Linux
Global hotkey is X11 only - on Wayland, use wake word activation
x86_64 builds only for now
Linux users - please break it
This is where I need you. The Linux support is new, the Flatpak is newer, and I canāt test every distro / desktop / audio stack combination myself. Wayland vs X11, PipeWire vs PulseAudio, KDE vs GNOME vs XFCE, whatever weird USB microphone you have - if it misbehaves, I want to hear about it.
The last two releases both came directly from Linux users filing detailed reports, so this genuinely works.
Download: Release 𩹠GLaSSIST 3.6.1 ā Input audio delay fix Ā· SmolinskiP/GLaSSIST Ā· GitHub
Issues: Issues Ā· SmolinskiP/GLaSSIST Ā· GitHub
Debug logs help enormously - Settings ā Advanced ā Debug logging, then attach the output. 3.6.1 also added greppable ā±ļø TIMING lines so activation latency can be measured straight from a submitted log.
