I wanted to start sound in my recordings through frigate.
Read somewhere that you should update go2rtc has updated to 1.8.5 and now get a lot of errors in my log, read through the documentation that you should fill in according to
"streams:
# cloud password without username
camera1: tapo://[email protected]
# admin username and UPPERCASE MD5 cloud-password hash
camera2: tapo://admin:[email protected]
# admin username and UPPERCASE SHA256 cloud-password hash
camera3: tapo://admin:[email protected]" now .
This is how I have tried to fill in my config file.
Not sure if you figured it out. I have a Tapo C100 working in Frigate using:
go2rtc:
streams:
LivingRoom:
-rtsp://user:[email protected]:554/stream1
- āffmpeg:LivingRoom#audio=aacā
LivingRoom_sub:
- rtsp://user:[email protected]:554/stream2
sorry the indentation is off but canāt figure out how to expand the tiny window they give you to type in. Iām trying to get a new cam - same model - to work but it keeps telling me I have the wrong user and password. It was the same - as the other one - and I even changed it in case it had to be unique to the camera. Still doesnāt work but can view in VLC so probably not a camera issue
Hello everyone
I have a Ctronics camera that I would like to integrate.
I have installed the Go2RTC addon and also the RTSPtoWebRTC integration.
I entered my home assistant IP address with port 1984 into the integration.
Then I added the WEBRTC Camera card and entered the URL of my camera there.
When I open the map I have a delay of 10 to 15 seconds until the live image appears.
The GO2RTC logs look like this.
Hi all. I apologize if this has been answered many times already. Gets hard to find answers as these threads get larger!
I am using the go2rtc addon to bring an aqara cam in using the HK device integration of HA.
Separately I am running Frigate with some Amcrest cams as well as pulling in the aqara stream. In my Frigate config I am not currently running the Amcrest cams through go2rtc. Should I? What is the added benefit of setting it up this way?
But it still doesnāt work. When I open the map, I always have a delay of over 10 seconds until the image appears.
Until then it says loding at the top right.
What have I done wrong? Please help.
Well. Do you have start delay and not real time delay?
Start delay is a normal thing for some cameras.
For good cameras, with little key frame interval, it also less than second.
Yes, you are right, the delay only occurs at startup. The running stream is smooth and time synchronous. If I enter the rtsp address of my camera into the VLC player, it takes about 2 seconds and then the image appears. If the error was in the camera there would also have to be a delay when starting.
Do you have another idea?
I have integrated a small live image from the camera into my standard dashboard. When the bell rings, it switches to the camera dashboard with the large image of the camera.
For example, do I change From the energy board to the camera, the image is there immediately.
Is there a solution for this?
Good evening. Everything works fine for me Hikvision KV6113, thanks for the integration. Please tell me there is an LED on the front panel of the Hikvision KV6113, it lights up when the microphone is turned on if you use hik Connect. But if they communicate via a WEB RTC card with two-way audio communication, then the LED lights up and does not go out, that is, the microphone is constantly on, until a reboot. Tell me if there is a command to mute the microphone. Thank you.
In the web interface I added a camera via the webrtc-camera video and sound card:
type: custom:webrtc-camera
url: DoorBellCh2
mode: webrtc
media: video, audio
muted: true
background: true
style: āvideo {aspect-ratio: 16/9; object-fit: fill;}ā
And the camera via the webrtc-camera card video, sound and microphone:
url: DoorBellCh2
mode: webrtc
media: video, audio, microphone
muted: true
background: true
So, if you make multiple connections to a two-way audio camera, or while watching a two-way audio camera, play some audio file through the media player, the sound on that camera will become quiet and choppy, and if you speak into the microphone, the voice will become choppy. I tried changing different firmware on the camera, but it didnāt help. If you reboot the frigate go2rtc everything becomes normal and works for some time.
I also noticed that when this happens, the microphone on the camera and on the browser tab works for a long time, and the Android phone can generally transmit sound and voice even after closing and unloading the application.
Is it possible to somehow fix this or add some command to reload the stream very quickly. Help me please. Thank you.
I hope youāre all doing well. Iām currently exploring the Go2RTC Hardware Acceleration feature in Home Assistant and have some questions about it. Specifically, Iāve noticed that enabling hardware acceleration doesnāt seem to provide clear advantages with my general RTSP streams.
Could someone clarify whether the stream is actually rendered on the host after Hardware Acceleration is activated, or does it happen later at the client? Iām not entirely clear on how this process works and whether there are specific scenarios where Hardware Acceleration does offer noticeable benefits.
