I have home assistant working with the google assistant component and everything works fine, except that my covers, which are my garage doors, show up in google assistant as lights. I can tell google to open the garage door and it works but if I tell google to turn on all the lights it also opens my garage door. Is there anyway to get my garage doors put into google assistant as anything other than a light? Thanks
Not at this time.
You can specify either light or switch for Google Assistant in the customize section with google_assistant_type. Here is my config for my garage door:
cover.garage_door:
device_class: garage
homebridge_cover_type: garage_door
google_assistant: true
google_assistant_type: switch
Cool the switch thing worked. now my kids wonât accidentally open the garage doors!
Iâve currently got it working through Google Assistant via IFTTT and its Webhooks service, which calls my HA API directly when I ask Google Assistant to open or close the garage door. So far itâs been perfectly reliable. Happy to share my IFTTT config if youâre interested!
would love to see you IFTTT config.
In IFTTT you need to set up both Google Assistant and Webhooks. Then:
- New applet.
- If this - Google Assistant - Say a simple phrase.
- Enter three variations, ie âOpen the garage doorâ âOpen the garageâ âOpen garageâ, and what you want the Assistant to say in response, ie âOK, opening the garage doorâ, then hit Next.
- Then that - Webhooks - Make a web request.
- URL in the following format: https://[your publicly accessible HASS url]/api/services/cover/open?api_password=[your HA API key]
- Method: POST
- Content type: Application/JSON
- Body: {âentity_idâ:âcover.garage_doorâ}
Now say âhey googleâ and one of your phrases, and the door will open! Make another applet for close.
thank you very much for your help but itâs not working for me because of the webhooks I think.
Google Assistant accepts my command but nothing happens.
I put https://[my publicly accessible HASS url]/api/services/cover/open?api_password=[my HA password] then Method: POST then Content type: Application/JSON and Body: {âentity_idâ:âcover.garageâ}. my entity_id is cover.garage not cover.garage_door.
I will try to see if I can find the problem. It the IFTTT activity log I see error" Ingredients
CreatedAt (none)" dont know what that is .
Google Assistant doesnât support any devices that have a concept of open/close so youâre either stuck saying âturn on/offâ or you can set up shortcuts in the assistant app to map âopen the garage doorâ to âturn on the garage doorâ. Itâs kind of a pain but thatâs what I did.
Just create shortcuts in the google home app, it only takes a minute.
Mine is showing up as a light as well. The icon in Google Assistant is a bulb, and it opens when I say âLights onâ. My code is belowâŚ
I have restarted HASS, unlinked the account in the Google Home App.
cover:
- platform: mqtt
state_topic: âsmartthings/Garage Door/contactâ
command_topic: âsmartthings/Garage Door/doorâ
state_open: âopenâ
state_closed: âclosedâ
payload_open: âopenâ
payload_close: âclosedâ
retain: true
optimistic: true
I had to put the
In customize to get it working.
Yep, putting it in the customize.yaml did the trick.
Thanks Curt!
donât forget that you still need to have the âcoverâ domain exposed to Google
EG:
configuration.yaml
google_assistant:
project_id: projecthere
client_id: clienthere
access_token: tokenhere
api_key: apikeyhere
exposed_domains:
- switch
- light
- media_player
- cover
customize.yaml
cover.left_garage_door:
cover.right_garage_door:
You could spend an hour or so trying to figure this out
*//note there are nbsp; characters if you copy paste
Thank you I literally spent an hourâŚ
Hi Marthocoo
I had similar configuration to control my garage door through google assistant. It was working fine with my old Home Assistant install, however once I upgraded my HA (0.78), the API calls are failing. It gives me 401 unauthorized error.
Reading up on it, it looks like the legacy api_password method is not supported anymore. Have you experienced the same issue? If so, do you have a working solution?
Please share the steps to make it work again.
Thank you
this works for me in the following format: https://[your publicly accessible HASS url]api/services/cover/open_cover?api_password=[your HA API key]
Hi all,
Iâve followed your istruction setting up covers as lights using customize domain:
customize_domain:
cover:
google_assistant_type: light
I can see that HA has this new attribute looking at the cover proprierties:
current_position: 0 friendly_name: Tapparella Stanza da Letto supported_features: 11 google_assistant: true google_assistant_type: light
But in my GH app covers appears still as switches.
Can someone please support me?
It seems Google added native support for blinds and shades.
I guess it should be easy to change how the covers are being synchronized with Google Home to be shown properly.
Direct link to developer documentation
https://developers.google.com/actions/smarthome/guides/
Iâm sure itâs coming soonâ˘
