I have requested this already, but don’t think it’s in development yet… Don’t think much code needs to be changed, it’s basically the same as a switch
PR is coming!
support for blinds/covers => open/close
Are you able to open/close blinds in google routine after exposing them as blinds?
I have updated to 0.91, and my covers are now exposed in the google home app (but with a weird gear icon on top of the blinds icon?) But if I ask google to “open all blinds”, she replies “sorry, there was an error with the all blinds” and nothing happens
Has anyone got this working?
This is my covers from configuration.yaml:
cover:
covers:
all_blinds:
friendly_name: "All blinds"
position_template: 50
open_cover:
service: script.all_blinds_up
close_cover:
service: script.all_blinds_down
stop_cover:
service: script.all_blinds_pause
Solved : I removed the line "position_template: 50 " from the above, and it works well now!
(leaving this here in case anyone else has the same issue!)
Or just used the timed cover from here:
With the new changes in custom component locations, I needed to change the template cover to timedcover and relocate it to:
custom_components/timedcover/cover.py
commands like “set cover to %50” does work here with google assistant now. formerly it was working only with siri.
The configuration is this:
cover:
- platform: timedcover
covers:
study_right_cover:
friendly_name: 'Right Cover'
open_cover:
service: switch.turn_on
entity_id: switch.study_cover_right
close_cover:
service: switch.turn_off
stop_cover:
entity_id: switch.study_cover_stop
opening_time: 45
closing_time: 45
Seems my cover are not working anymore, since I have stateless covers, already created issue on GitHub
… Your covers have a state? Like open/ close in Ha?
Yes, they are either “open” or “closed” in HA. They are controlled by a broadlink RMPro issuing IR commands learnt from the blind’s remote.
Ah ok, then it should work, mine are not, I send tcp command, so HA doesn’t know the state
I had my garage door working for well, along time but recently I stopped getting confirmation that the door was opening or closing. then it stopped working completely. Google Assistant now says the device is incompatible with command or something to that effect and in the home app looks like the attached picture
How can I get this working again? I had a mapped routine so that I could say open my garage door and Google would actually do the command turn on my garage door
yes, the cover domain, is not working correctly if you have stateless covers
this is been fixed, and will be merged in a new HA release
also the garage door will be a new trait in newer release HA
Ok lol I had a thought as I was writing the above question. I had as a work around when Google used to treat the door as switch, a routine that basically translated open my garage door to the command Turn On my garage door. Since Google now supports the open command I had to simply remove the routine and it worked when I said open the garage door…I downgraded to each of the previous builds of HA to trouble shoot… There’s 45 minutes I’m never getting back lol
good it worked
Google assistant is now telling me that I have not set a code for the Garage lol Anyone got around this? I think classifying as a switch instead will do the trick but I kinda like how google classified it as a garage door with the icon and all
isnt that a setting? if i go to HA cloud google config (nabu casa) , its default disabled, maybe you enabled that?
This integration requires a Google Assistant-enabled device like the Google Home or Android phone.
Please enter a pin to interact with security devices. Security devices are doors, garage doors and locks. You will be asked to say/enter this pin when interacting with such devices via Google Assistant.
My covers still exposed as covers still work, if it helps
covers is fine, its trait garage :
Yup just figured it out that I need to set secure_devices_pin in google assistant configuration Crisis avoided hahaha Thanks everyone!
Can you open/close/set position at the Google blinds icons? I just can control it by voice or routines.
Haven’t tested, I only use Google Home for listening music and control HA devices by voice… let me check in a couple of minutes
