Google Assistant/Home Stopped Working
Google Assistant stopped working all of a sudden today. All of my Home Assistant devices that I’ve exposed to Google Home now appears offline. I’ve set this up previously using the Google Home Integration: Google Assistant - Home Assistant
I have my own domain for HA via Cloudflare add-on. I can access my HA domain when I’m adding a devices via the Google Home app. However, after logging in, I get the error “Something went wrong. Try again”. I’ve tried this both on an iPhone and Android phone and get the same error. I’ve tried resetting my router, no luck. I’ve tried a suggested solution: Can no longer link Google Assistant - #19 by Omnipius but still no luck
Currently on: Home Assistant Core 2024.10.0
Are you using Cloudflare? I had similar issues and turning off Bot fight mode fixed it instantly.
https://community.home-assistant.io/t/solution-to-google-home-link-error-when-using-cloudflare-to-expose-ha
This fixed it! I was just about to redo the entire integration. Massive thanks!
wow, my hero. thanks!
started randomly after having this setup for years, weird!
this did it for me as well, thanks!
even setting up bypass rules didn’t do the trick & the event log was empty…
