So i followed this guide for getting Voice commands for the Vac.
I have completely gotten the vac to clean zones through HA commands. It also seems like the command is getting to HA via IFTTT, but it doesnt run anything.
Errors i am getting:
[homeassistant.components.http.auth] You need to use a bearer token to access /api/services/script/vacuum_room_select from X.X.X.X
[homeassistant.components.http.view] Serving /api/services/script/vacuum_room_select to X.X.X.X (auth: True)
Script it is calling:
vacuum_room_select:
sequence:
- service: script.turn_on
data_template:
entity_id: >
{% if (room== "kitchen") %}
script.vacuum_kitchen
{% elif (room== "living room") %}
script.vacuum_living_room
{% elif (room== "pantry") %}
script.vacuum_pantry
{% elif (room== "dining room") %}
script.vacuum_dining_room
{% elif (room== "spare bedroom") %}
script.vacuum_spare_bedroom
{% elif (room== "spare bathroom") %}
script.vacuum_spare_bathroom
{% elif (room== "computer room") %}
script.vacuum_computer_room
{% elif (room== "front bathroom") %}
script.vacuum_front_bathroom
{% elif (room== "entry hall") %}
script.vacuum_entry_hall
{% endif %}
vacuum_kitchen:
alias: "Vacuum the Kitchen"
sequence:
- service: vacuum.send_command
entity_id: vacuum.rosy
command: app_zoned_clean
params: [[22500, 30000, 28500, 33750, 2]]
IFTTT Setup
IFTTT Log:
Unable to make web request. Your server returned a 400
