Needs HA Version later than 0.68.xx
Hey there,
Xiaomi has recently released an update for its v1 vacuum that enabled it for the zoned cleaning and goto function that was previously only available to the v2 vacuum.
In this post you will get to know how to:
- update to the latest firmware on your v1 to get access to the new functions
- extract your token quickly and easily and setup the component
- use the new commands (zoned cleaning and goto)
- figure out the coordinates for your map / floor layout
- use a script/switch to start your vacuum for specific rooms
- use Google Home + IFTTT to start cleaning any room you wish
Update your v1 to the latest firmware to enable new functions
DISCLAIMER: Updating your firmware results in the reset of your token
To update your firmware on your v1, you have to make sure that your region is set to Mainland China in your Mi Home App. Please also make sure you run a recent Mi Hime App version (5.x).
Go to Profile ā Settings ā Region to select it.
Don't worry if your vacuum does not show up anymore. You have to readd it now. You might have to restart the paring process on the robot by long-pressing on the power and home button at the same time. Once its synced again with your Mi Home app, you can install the firmware update:
Click on the robot ā Open the settings (top right corner, three dots) ā General settings ā check for firmware updates
extract your token and setup component
Setup component
Please also refer to the manual.
configuration.yaml:
vacuum:
- platform: xiaomi_miio
host: VACUUM_IP_ADRESSE
token: YOUR_TOKEN
Extract token
Android:
Download a modified Mi Home app from this russian website. (Direct Link v.5.1.29)
You need to readd the robot to the app. Restart the pairing process on the robot by long-pressing on the power and home button at the same time (v1) or by long-pressing the power button (v2).
Once itās added in the app again, you can find the token in the Networks info of your robot:
Click on the robot ā Open the settings (top right corner, three dots) ā General settings ā Network info
iOS:
I have no faster way of retrieving the token. Please refer to the component documentation to extract the token.
how the new commands work
The new commands that we can now use are called app_goto_target and app_zoned_clean. Both commands take coordinates and we have to call them via the āvacuum.send_commandā service.
app_goto_target
Takes one coordinate: [x,y]
Example:
"entity_id": "vacuum.DustyMcDustface",
"command": "app_goto_target",
"params": [25000, 25000]
app_zoned_clean
Takes a list of zones. A zone contains two coordinates (button left, top right) and a number indicating how often the zones should be cleaned: [[x1, y1, x2, y2, i], [x1, y1 , x2, y2, i], ...]
Example:
"command": "app_zoned_clean",
"params": [[25000, 25000, 23000, 23000, 3]]
Update: Since Version 103 there has been an update to the service call:
Instead of vacuum.XX you have to use xiaomi_miio.XX. Keep this change in mind for the further instructions.
In addition, there has been added a command for the cleaning zones:
xiaomi_miio.vacuum_clean_zone
The service call is used with the additional keys entity_id, zone and repeats. E.g.:
service: xiaomi_miio.vacuum_clean_zone
data_template:
entity_id: vacuum.xiaomi_vacuum
repeats: 1
zone: [[30914,26007,35514,28807], [20232,22496,26032,26496]]
map and coordinates
Unfortunately there is no easy way without rooting the device to directly access the map with its coordinates, so you have to do some manual labor. The way the map is created works like this: The starting point of the map (which should be right in front of the dockings station - where your robot starts off at) is [25500,25500] and the map is then build around this coordinates. All you have to do is figure out a grid and then read off the coordinates that you need:
Step 1: Make sure your docking station is at a fixed position (so your starting point will ALWAYS be the same).
Step 2: If not yet created, let your robot create a full map of your apartment/flat by starting the cleaning from the Mi Home App.
Step 3: Use the share button on the top right while accessing the map on the app and share the map to facebook (you can set it to private so that only you can see the post). Then, download the map to your PC.
Step 4: Use the app_goto_target command to send your robot to a new location.
Increasing the x coordinate will move the robot relative to the starting point to the right (decreasing to the left), increasing the y coordinate will move the robot relative to the starting point to the top (decreasing to the bottom)
Figure out a few points that your robot can reach (preferably a few that arenāt to close to the starting point). Then once you have reached those points, extract the map again and of course write down the coordinates of your robots location.
Step 5: Now you can either work with Photoshop or any other desired editing software, or you can go old-school and print the maps. Now calculate the distance between two of the coordinates by calculating the difference (e.g. if you have the coordinate [25500, 25500] and [20000, 20000], the distance would be 5500 on the x-axis and 5500 on the y-axis). I then chose steps of 500 for my coordinate grid. You then have to take measure and figure out the actual distance between the two points on your map (cm / pixels) and divide that number by the number of steps that you need (in our example 5500:500 = 11). Do that for both axis and continue the grid for the entire map, add some values for reference and you should end up with something like this (depending on how much effort you put into it ;)):
Step 6: If you have done everything correctly, you should now be able to read off your coordinates. For most parts you donāt have to be exact: The robot will not get stuck if your zone is bigger than the actual room or parts of your zone are outside the building. If you need a more precise zone, (e.g. if you want to exclude a carpet in a certain setup), you can use the
app_goto_target command again with smaller steps to find the exact coordinates that you need in that area.
Update: You can use the app VloleVac as an alternative to the Xiaomi Home App - here you can directly extract the coordinates of a zone that you have drawn. Beware, for some users the app does not work.
script/switch to clean certain areas
On your map, read off the coordinates that you need to define the zone/room you want to clean. You can also use multiple zones. A zone takes two coordinates, the first one is the bottom left corner, the other one the top right corner.
For every room/area that you want to use, you have to create a separate script that contains those coordinates. This is the easiest way, since we cannot use lists (which the coordinates are) in templates. We then can of course use templates to start the according script, e.g. through an input_select or switches for each individual room. This is of course up to you and what you prefer. The script (place this in scripts.yaml that starts the vacuum for a specific room then looks something like this:
vacuum_kitchen:
alias: "Vacuum the kitchen"
sequence:
- service: vacuum.send_command
entity_id: vacuum.DustyMcDustface
command: app_zoned_clean
params: [[26500, 20500, 29000, 23000, 1]]
Example Configuration with input_select
If you plan on using this for multiple rooms, and might be a little bit tidier if you use an input select for choosing a room from a list and then simply pressing a button to start the cleaning, e.g.:
Similarily to using this with IFTTT, we have to run another script that reads the input and then calls the respective script that has the coordinates for cleaning the desired room. First, we are going to create the input select in the configuration.yaml:
input_select
vacuum_room_select:
name: Choose a room to clean
options:
- Kitchen
- Living room
- more rooms
Then we add the script that reads the input and calls the respective script to scripts.yaml
vacuum_room:
alias: "Start cleaning"
sequence:
- service: script.turn_on
data_template:
entity_id: >
{% if is_state("input_select.vacuum_room_select", "Kitchen") %}
script.vacuum_kitchen
{% elif is_state("input_select.vacuum_room_select", "Living room") %}
script.vacuum_living_room
{% endif %}
Be aware that you must have created scripts for each room that contains the coordinates (as in the example above). Next, we can group the input_select and the script in groups.yaml:
vacuum:
name: Vacuum a room
entities:
- input_select.vacuum_room_select
- script.vacuum_room
Google Home + IFTTT
Note: Since there is a good integration with Google Assistant and Home Assistant through the Home Assistant Cloud, using IFTTT is not necessary in order to control your vacuum through voice commands. If you still want to set up IFTTT, continue as follows.
Make sure you IFTTT and Home Assistant are setup properly. Please refer the manual if you havenāt done so yet.
The goal here is to tell your Google Assistant to start cleaning a certain room that you have predefined with your voice. We have set up the scripts for each room already. It seems obvious that we could create a webhook and trigger for each of these scripts now, but that seems like a lot of work.
So what we are going to do instead is use a text ingredient that is passed to another script which processes that text ingredient and starts the respective script.
Vacuum room select script
vacuum_room_select:
sequence:
data_template:
entity_id: >
{% if (room== "kitchen") %}
{% elif (room== "living room") %}
{% endif %}
IFTT setup
Step 1: Create a new Google Assistant trigger and select āSay a phrase with text ingredientā
Step 2: Choose your phrases to start your vacuum, make sure that you put a ā$ā where you would like to say the room name, e.g. āclean the $ā
Step 3: Choose webhook as the action. Set it up as follows
URL: https://xxx.duckdns.org:8123/api/services/script/vacuum_room_select?api_password=xxxxx
Method: POST
Content Type: application/json
Body: {āroomā: ā{{TextField}}ā}
Thatās it. You are good to go.
Troubleshooting
I sometimes had troubles with the text ingredient. Especially when you use two words like āliving roomā, it sometimes only would take āroomā. If you are having troubles, you can always add more words to the condition in the script, e.g.
vacuum_select_script:
sequence:
data_template:
entity_id: >
{% elif (room== "living room" or "room") %}
{% endif %}
Also be aware that this method is case sensitive. So, if for example you are speaking German to your Google Assistant, it might process āKücheā sometimes as ākücheā or āKücheā
If you have suggestions/changes or ideas you would like to add, please let me know.
and we use the robot at different levels of the house.
