I have managed to get Home assistant cloud service up and running. Pretty straight forward when I figured out how it is meant to work.
I have the Hass.io service added in my Google home app. This exposes around 60 entities. A mix of switches and scripts. So far so good.
I have created a number of rooms in Google home app and also connected the right entities from Hass.io to the rooms.
My configuration.yaml looks like this:
The problems starts when I want to start using voice commands to control all the swithches.
I was hoping to be able to say âOk google, turn on all lights in the Livning roomâ and that would trigger all the entities connected to the âLiving roomâ. But that does not work.
Most of the times it works if I trigger one entity eg âOk google, turn on window in the kitchenâ (where window is the name of the lamp entity and kitchen is the name of the room).
However it does not work 100% of the times.
I was also hoping to be able to say âOk google, turn of all lights in the Homeâ, This never works.
Most of the times I get the reply âThese lights does not seem to be configuredâ or âI do not know how to help with thatâ.
It is a bit frustrating. I have been using IFTTT to trigger scripts through google Assistant and that has been working better than this implementation.
So either I have configured it incorrectly, or it is not suppose to work according to my expectationsâŚ
M google assistant is âroom awareâ If I say Turn on the lights it will only turn on lights in that room - light is configured in same room as GH. If I say turn off all lights it turns off every light in the house.
Iâd say you have a configuration problem. My google assistant setup is in a seperate yaml file.
You config it manually or use cloud like Nabu Casa?
I have same problem with @Per-Henrik_Lind using Nabu Casa. I have 2 lights in bedroom, when I ask GA to turn off all lights in bedroom, I always get âI donât know which light you want to turn offâ unless I use exact light name
Ok thanks.
I am a bit usnure what the âentity_configâ do.
In the manual is says " Entity specific configuration for Google Assistant." which does not help me muchâŚ
And in your case the âlight.philipsâ is that refering to a name in Home assistant?
Thanks for your patient, will get it working eventually
yes, âlight.philipsâ is entity name in HA, and ânameâ and
âroomâ is how you want google assistant recognize it as when you using google assistant
I am trying to achieve the following. I want to say:
âOk Google, turn on the lights in the Vardagsrumâ which should turn on âutbyggnad__blomlampaâ and âutbyggnad__bokhyllaâ. The room name in Google assistant is âVardagsrumâ.
This still does not work.
It works kind of good. They released Google home on Swedish recently.
So that might be one reason for the issues, however I want to make sure my config is Ok so I can rule that out from the possible causes.
your lights are in âswitchâ instead of âlightâ, maybe it makes GG confuse? can you try to say, turn on all switch in âVardagsrumâ to test if it works
