i think i ran across your post while searching I seen that mentioned. I have that line, I only want a couple entities exposed.
Ive tried many things but this was my last attempt and where Im getting that error:
google_assistant:
project_id: -id was takin from the actions site where it says project id
client_id: -random generated with matching random generated in actions
access_token: - taking from actions page
api_key: - takin from action page
expose_by_default: false
entity_config:
cover.garage_door_opener:
aliases:
- Garage Door
script.fireplace:
thanks. I did try to add :8123 with no luck but I really dont see that being differnet. i will try to add what you suggested, forward 8123 and turn wifi off real quick. be right back, thanks for taking the time to help!
yes, else nothing will be displayed. It’s not 100% clear on the doc and I’ve submitted a PR for it (4936)
It doesn’t look like it’s your issue for now (would defo have been in the future tho) as you have a different error message, hence the suggestion to try again from scratch
yea no luck i tried all of thise and same thing. I get that messege at the very bottom for a second. and I just noticed i could see that quick flash/redirect. it says “return to app”
Well look at this, I see account is now linked!!! Only, my devices arnt in there and the app is still under link accounts like its not linked, unless it just stays in there…
if unsure, try to comment out the line expose_by_default: false
That’s how I realised I was not exposing anything at all, even though I had entities listed under entity_config
yea something not right. i think. even though I get that accounts linked screen I still get that message at the bottom after and I dont see any devices, or indication that it is actually linked. this is still see
