I’m unable to get the test app to link to the account. I get all the screens redirecting, but end up with the snackbar saying “Could not update the setting. Please check your connection”
I have a 18 character client_id and 74 character access_token. Everything is set up in actions on google and I have clicked on test app.
Hi
i even not clear in docs how to follow thing i think better if some one expert make video for setup.
please help make one video from begin to end .
thanks
Sorry, no solution, just addnig a “+1” to your thread.
I get the same issue - I can see [test] my app name listed when I go to add a new device, but when Home attempts to link my app I get the error “Could not update the setting. Please check your connection.”
I am running Home Assistant behind a reverse proxy, and I’ve temporarily disabled Basic Auth on the reverse proxy until I get Assistant working correctly.
Yeah I have no special config, Port 443 is forwarding correctly and I access HA via https://[myurl]
I can go to https://[myurl]/api/google_assistant/auth as I set up in actions on google. I get the ‘“message”: “missing redirect_uri field”’ error but I assume Google Assistant adds the correct url parameters etc.
Not really sure what to do. I’ve tried setting up an app twice now. The project_id is correct, there are only letters and numbers in both my client_id and access_token so I cannot see what could be the issue…
I agree, but the guide is pretty self-explanatory. I think the main problem is the Google Home app being a pain. I get this message sometimes with other devices, but it usually shows up after I reload the page
Had the same issue, it just started working eventually. Regarding the post about receiving missing redirect_uri field when visiting the URL from a browser, that’s normal.
How about a detailed setup on how to make this work. How to we add this on Hass.io. In my case I already have a Google Home device, so there is no need for the Rpi one. but the setup its very confusing since you need to add the command:
This is probably the 5th time I’ve attempted to get it to work. I’m trying everything I can thing of. I have shortened the client_id and client_secret way below 20 and 80 characters, I have just used alphabetical codes, I have looked at the url it goes to and that looks ok. I have even tried disabling the api_password and that made no difference…
I got it to work! I’m not sure if it was to do with the amount of components at once, or that my project.json was malformed, but I managed to get the app to link on the google home app
You may be in the wrong topic. This is for setting up Google Home devices to find and control Home Assistant devices. (An alternative to using emulated_hue.) This is not in regard to the add-on for making a Pi into Google Assistant.
I found I had to disable the Wifi on my phone to get the final steps to work, seems my local host mappings mapping may have confused things.
I did get the same connection error even after I made this change but found that it had worked and my HA devices were actually discovered after going back to the devices page. From then on, having Wifi enabled on my phone was OK.
I had the same issue and had to retry 3 times before getting it to work. In the end it worked with 4G, while on wifi it didn’t work.
Also saving the room setup always showed me an error, however after quitting the setup, the room had been successfully saved…
I’ve repeated all the setup steps at this point, and waited multiple hours without success.
In my (Google) Home app on my android deviceI see [test app] my app name.
When I click it, the https call comes to my edge proxy. I see the request get answered with a 301, and a body of “{“message”: “redirect success”}” However the (Google) Home then says “Couldn’t update the setting. Check your connection” and no further http/https traffic.
Since the problem seems to be in the Home app, I’m not quite sure how to troubleshoot it.
My hostname / https uri resolves inside and outside my network. I can browse it directly. If copy and paste the Location header from the 301 link in a browser, it looks functional.
In the request, the client_id is passed and is correct.
In the response, the access_token is returned and correct.
The state is identical in the request and response.
The only thing that looks possibly suspicious to me is that the token_type=bearer but the access_token is just a random string.
