Amazing. Tring this setup for a very long time without success and get it working first time with your Tuto. Thank you so much.
Hi Matt, sounds like the same issue i am having. Did you manage to get it working? I am able to access via https. When adding the test service in Google assistant I get redirected to my hassio, sign in, but then get the google “could not update” error.
Hi - I ended up recreating everything, even the API in Google, and it still didn’t work.
A problem I had in isolating the cause, was that, toward the end of my troubleshooting, two other problems joined the mix (certs expired, and my server weirdly stopped accepting external traffic, which a reboot fixed).
Once I fixed the certs and rebooted the server, then it started working - so I can’t say what was initially wrong with the HA config, sorry. Although I do believe that stripping out all Google Assistant config to the minimum is an important early step.
Those would be main causes of the assistant setup not working
Well they were the cause of everything breaking - but that was a week after my Google Assistant config stopped syncing…
Before that, I never found out what was wrong. By the time I made the corrective step, everything else had broken for bigger reasons. Absolute clusterf***
I dealt with this for a while before I thought about the “check your connection message” and saw hints on the GitHub issue about IP versions.
For anyone else having this problem:
My HA instance was behind Cloudflare and NGINX. Turning off proxying in Cloudflare but still using NGINX finally allowed it to work.
Thanks @Klikini, turning off Cloudflare proxying in addition to completing the final steps from mobile network instead of LAN did the trick for me.
Hi, i have just spent a couple of nights battling this issue.
TLDR - I used project name instead of project id for the Account Linking client id url.
I found that i had made a mistake following the instructions (https://www.home-assistant.io/integrations/google_assistant/#configuration)
The mistake was on 2.3 -
Client ID: https://oauth-redirect.googleusercontent.com/r/YOUR_PROJECT_ID
Instead of project id I had used the project name. FYI project id looks like words-2ab12, I got it from the url.
I realised my mistake when following the instructions again to create a new project.
Updating the old client id didn’t appear to work but I tested it immediately after fixing the mistake so that may have been the issue. However the new project did work.
I hope someone finds this useful.
I made a similar mistake as well - I’d only included the project ID rather than the google part of the URL that came before it, but all the other URLs were correct!
