when you talk to google home , the response like “ok, turning on the kitchen light”
its only the response, the kitchen light is instance
is also random, sometimes the response was fast…
with google local edition, it was always fast for me
Hmmmm strange, maybe you are not exposing an entity? That there is no reason to link
I am
Home assistant shows what I’m exposing, which I limited to just scripts.
Both local and nabu show a log on page it saying linking account, it then comes back saying there was an issue.
Hmm, then I don’t know, mine is linked, not gonna try linking again
Anyone solved this issue?
Since update 0.90 I can’t link anymore.
Did you make sure simulation/test is enabled?
Also I had a diary note mine was supposed to timeout a few days ago but still going strong…
Yes, testing is still enabled.
Going back to a snapshot with version 0.89 fixed the issue…
got it to work?
Still does not work, working on version 0.89
I finally got it to sync the first time on 0.94.3 because I changed the fulfillment url. I missed the /api/google_assistant
when I was copying/pasting. I had to redeploy my draft and then I stopped getting the BACKEND_FAILURE on the action log.
https://[YOUR HOME ASSISTANT URL:PORT]/api/google_assistant
Hello, for me the issue was invalid certificate on my hass server. I used self-signed certificate and also tried certificate from my private CA but that would not work either. I had to create publicly trusted certificate (I used SSLforfree) with correct name which I use in the Google Assistant Link.
Obviously it could be other problem in your case but the symptoms are the same. Vita
After logging in to the hassio dashboard through google home it say linking and then I get the “couldn’t update setting, check your connection” error.
Using Hassio (now 0.97.2) in combination with duckdns add on to generate ssl certificate.
Tried:
- different phone
- different browser (chrome --> firefox)
- from Wifi and 4g
- setting up the whole google action/console 5 times
- wait a month
Not sure what else I can do.
Best to limit your devices (exposed) to just one , just for testing, expose for instance 1 light… See if it can link…
Then you know everything is setup like it should
Make sure the simulation is enabled on the Google Console side.
@pergola.fabio Thanks for the suggestion. I have tried exposing ‘-switch’ (I have only one switch) but this doesn’t resolve the problem.
Then I tried ‘expose_by_default: false’ which should lead to no exposure to google home if I understand correctly. This also does not help.
@DavidFW1960 I definetely enable simulation. I just updated the version under the simulation tab and it showed a popup screen ‘enabling testing’.
Tomorrow I will setup a whole new HA on a separate SD card and add duckdns and google_assistant first and see if that will help.
A bit later than intended, but I set up a whole new Hassio system. The first thing I did was setting up the duckdns addon on. Then moving to the google assistant, but unfortunatelly still getting the same error.
Now on Hassio version 0.99.3
Config looks like:
google_assistant:
project_id: XX
api_key: XX
Any ideas anyone?
Hey @Revaes,
Here is a step by step guide that worked for me:
And be sure that you have correct URL with /api/google_assistant in the Actions Console > Develop > Fullfilment URL.
Example ‘Add fulfilment URL’
https://xxxxx.duckdns.org:8123/api/google_assistant
This is what helped me.
P.S.: Some also say that changing default browser when connecting to HASS did the trick and also to remove exposed_by_default and exposed_domains from configuration.yaml.
Good luck.
I am on 0.100.2 - and while I have always been able to fix this issue in past (usually something simple I overlook) - this time I am well and truly stumped.
I have tried every suggestion that I have seen, save re-creating the whole Google API setup from scratch. Nothing works to get the assistant integrated again…
I authenticate against HASS,and just get the helpful “could not update the setting” error, with no google-related errors in the logs. I do see the token established against my Profile within HASS (if I use my own credentials).
I have fixed up this following issue of setup.I am another co related query to bring to your notice that I am unable to connect my Arlo Ultra with the google assistant in my Hp laptop.I have configured my settings and manuals and followed out all the systems as guided by arlo security camera review.Please suggest what to do to proceed.
