Im trying to setup google assistant, but im stuck on step 1 believe it or not…
Install the gactions CLI (you’ll use this later) - you can download this anywhere, just remember where you put it for later (and don’t forget to run chmod +x gactions)
Where do i install gactions CLI? On my windows pc or the pi? If on the pi, how do i install it? And where/what/how do i run chmod +x gactions?
Create a new file named project.json (in the same directory you downloaded gactions to) and replace the [YOUR HOME ASSISTANT URL] below with the URL you use to access Home Assistant. Note: This must be an HTTPS URL to work.
And here, does this mean i need to have a duckdns url setup? with encryption?
Thanks… I changed it, and there aren’t any errors… But I’m trying to access my site with Https://mydomain.duckdns.org:8123, but it’s not working… If I use http it works fine… Any ideas?
I’m having another issue now… Everything is configured and working fine, but when I try and add it in the Google app, it shows up, and seems to work, but then it says loading and then claims a connection error. Ideas?
