Google assistant with Hassio
I have google assistant and hassio connected thorough “google home” app. I can command thorugh google some lights mapped in Hassio.
Now I have RMPro and some learned commands, which are not exposed to google assistant. I want to send some voice command for example:
“Turn on air conditioner” and want that google assistant send some type of comamnd to hassio, and hassio will send “RF command” to RMPro.
I dont want to use IFTTT, any one have an idea?
Thank you
I don’t know about RMPro but I guess it’s some kind of universal remote.
Put your RF commands in a template switch or a script if that is possible. Both can be synced to Google home and the be used in assistant routines.
The best solution is SmartIR.
(Also: please edit the thread / post to change ‘Hassio’ to ‘Home Assistant’ since Hassio hasn’t existed for a very long time now)
How can I integrate a script to run thorough a voice command. Don’t I have to register the command in google actions and then some how link it to the script?
Yes, you create an entity in HA (Switch or script), sync these entities to Google Home and then use it in a Google Assistant routine.
