Google nest hub MAX camera
it it possible to use the nest hub max camera as a camera device in hassio ? I pre ordered that device :wink: would be cool to use the camera in Hassio
Or do I need that API that was closed down recently?
I’m wondering this too
And I as well :slight_smile:
Reviving the question?
The new Google Nest integration which (available from Home Assistant v0.118), though still work in progress, works fine for viewing the video stream from the Hub Max.
It is possible, but it doesn’t work. The problem seems to be the same as with google home.
So, let’s say if it works with your google home/nest integration it should work with haOS / smart device API integration.
Hi Is the Google next hub MAX camera still not supported? I’ve configured by others cameras ok.
