Google-Nest Offical Device Access Console Finally Released!
I’m not exactly sure how to do this in IIS as I use an Apache reverse proxy for my HA deployment, but I was having a somewhat similar issue trying to set this up. I kept getting the “aborted” error message in the UI regardless of whether or where my URLs were configured. I ended up having to follow the last post in this thread (Reverse Proxy with Apache) to configure my Apache server. The major changes seemed to be related to passing the external IP of the source to the HA instance in the form of a header. I’m sure there’s a comparable configuration in IIS you could play around with.
