I have moved my config files from Hassbian to to Hass.io now. Most is up and working but Bluetooth tracker is not. But I did see that mention in another post here and a fix for that was expected soon.
The last issue I have is google travel time is not working.
Im at work now so I cant look at the logs, will do that later. But I got SSL connections error to google and error zone.home was not found.
The config was working with no errors on Hassbian.
Some one else have had success using Google travel time on Hass.io? or do docker/hass.Io have known issues connecting to google services?
File “/usr/lib/python3.5/site-packages/googlemaps/client.py”, line 229, in _request **final_requests_kwargs)`
File “/usr/lib/python3.5/site-packages/homeassistant/components/sensor/google_travel_time.py”, line 113, in run_setup destination, options) File “/usr/lib/python3.5/site-packages/homeassistant/components/sensor/google_travel_time.py”, line 148, in init self.update()
File “/usr/lib/python3.5/site-packages/requests/adapters.py”, line 438, in send timeout=timeout
File “/usr/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py”, line 630, in urlopen raise SSLError(e) requests.packages.urllib3.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
During handling of the above exception, another exception occurred: Traceback (most recent call last):
File “/usr/lib/python3.5/site-packages/requests/sessions.py”, line 531, in get return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3.5/site-packages/requests/sessions.py”, line 518, in request resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.5/site-packages/requests/sessions.py”, line 639, in send r = adapter.send(request, **kwargs)
File “/usr/lib/python3.5/site-packages/requests/adapters.py”, line 512, in send raise SSLError(e, request=request) requests.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
timeout=timeout
raise SSLError(e)
