Getting the following traceback when trying to use the Join component from the 0.45.1 image:
2017-05-24 11:49:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component joaoapps_join
File "/usr/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 345, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 844, in _validate_conn
conn.connect()
File "/usr/lib/python3.5/site-packages/requests/packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/lib/python3.5/site-packages/requests/packages/urllib3/util/ssl_.py", line 325, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.5/ssl.py", line 377, in wrap_socket
_context=self)
File "/usr/lib/python3.5/ssl.py", line 752, in __init__
self.do_handshake()
File "/usr/lib/python3.5/ssl.py", line 988, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.5/ssl.py", line 633, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
I can curl the url (https://joinjoaomgcd.appspot.com/) and the cert is valid, assuming perhaps the CA bundle for the container might need to be updated.
