normally yes
make sure all links are correct, redirect, token , authorize
and for me on android, i always need to delete the HA shortcut app on my home screen
then i can link
yes thats all correct, beside if was not correct probably would not go to the HASS frontend page asking user/password. Nevertheless I rechecked, its all correct … ran out of idea
EDIT, I managed to put a different browser as default. Same issue, aggravated by the fact that I have 4 my test app, so not sure which to use (I used multiple times all of them).
I spoke with a Google tech guy, and he is clueless, go figure. Its definetely something server side, now I will need Google to upgrade something the the software, or maybe in the GH app, before my account will work again
indeed, i also have a ticket open, they are aware of issue, but takes long
ticket : Case ID [8-9178000024059]
about the “homes” that are corrupted if you share one, thats also known, i still have that issue, latest reply was from a google employee today, also an known issue
Having same issue here. When i try to “sync devices” from Google assistant, it says error to sync. After google around, it seems the Test simulation works for 30 days which is correct in my case when i trace the date i created the project / token in Google Console.
So i decided to Unlink and Relink. Yes it works as im able to run “sync devices” from Google Assistant. Then i notice when use Google Home to turn on/off switch, it always says 2 devices (or additional 1). Then realize the old devices (before unlink) is still listed in Google Home routine.
I hope Google will resolve this issue soonest as this it frustrating. Now im thinking next time before unlink, probably rename all devices and move out from room.
welcome to the world of “google ghost devices”
next time , in 30 days
first unlink, then do a “sync devices” … so all devices are really gone
then link again
