I flashed power strip Gosund P1 with Tuya Convert. I am using ESPHome but as I do not find for this model have pin mapping, I decided to flash Tasmota for investigation.
I found relays, leds and even CF1 for current/voltage metering. But I am unable to find CF and SEL for power metering using standard procedure (this procedure do not describe finding power meter pins).
I do not also found pins for switches (not necessary unless I turn it on/off remotely)
Is there any procedure to find this CF, SEL pins or just blind testing all possibilities?
Is it worth to look for it on pins 9, 10? (I find it is ESP8285 unit.)
Is It possible that power metering chip was damaged during searching for that pins?
For some reason I am unable to get the P1 to show in my Home Assistant… I have another 23 devices working well in MQTT, I see in the supervisor logs that it has connected, I can listen to the topics and see the information flowing in, but it is not detected as a device…
I cannot list the device anywhere… Do I need to create manual sensors??
1610703391: New connection from 192.168.1.10 on port 1883.
1610703391: New client connected from 192.168.1.10 as DVES_XXXX (p2, c1, k30, u’pi’).
I will check that next, I have it loaded with tasmota, and it fully works, I am only missing the last step which is MQTT adding to to the device database…
EDIT: I fixed it. Updated to tasmota 9.2.0 and used the Tasmota (Beta) integration. All shows up.
