sender
January 28, 2021, 10:39am
21
Yes I would do so…
BUT!!!
I have returned 3 of these due to the fact I have experienced like many other review on amazon (that did not flash) the following behavior. the entire device randomly switches off and on very quickly. Sometimes it runs days and sometimes hours. This does give a very short (1s) power outage on connected devices. This is bad for your devices as well very dangerous!
So if you still insist on the config I can provide, but I wanted to warm on beforehand!
QbaF
(Qba F)
January 28, 2021, 12:30pm
22
The newer ones do not have that issue. Or, at least, not for all of them.
Unfortunately still not the best WiFi strength.
c1381ie
(Marcel)
January 28, 2021, 12:50pm
24
Thank you for the information. I will first test it with my one bar.
Unfortunately I can’t even get one of the seats switched without the config.
So it would be really very helpful for me if you could post me the config of ESP home one at a time (also via PN if you like) so that I can continue.
A heartfelt thank you
sender
January 28, 2021, 1:05pm
25
“The newer ones”… bought them around 3 weeks to lastly 3 days ago… they had it all…
QbaF
(Qba F)
January 28, 2021, 1:15pm
26
I had 3 of them, only one, so far, with that issue. But due to Your experience, it looks like the production date is not so important, just “some has problem”.
QbaF
(Qba F)
January 28, 2021, 1:22pm
27
configuration plugstrip Gosund P1 (need to be cleaned)
nsoares
(Nuno)
March 29, 2021, 9:46pm
29
@QbaF great work! Thanks for sharing!
Is there a way to not have the main button always flashing blue ?
Thanks in advance!
QbaF
(Qba F)
March 30, 2021, 8:15am
30
Of course. There are a lot of ways. Two easiest ones could be:
switching it off (entity id: “${plug_name}_ledblue”)
remove this led from esphome yaml
Varac
(Varac)
December 23, 2021, 8:21pm
31
I also have a P1 and successfully flashed it with esphome.
It shows up in home-assistant (esphome integration), showing " esp8285 by espressif Firmware: 2021.12.2 (Dec 23 2021, 20:34:04)".
But I don’t see any buttons which I could toggle or current/ampere values. If I click on either “Automation” or “Scripts” I only get “There are no automations available for this device.”
How do I get further ? I’m pretty new to home-assistant so maybe I’m missing sth fundamental.
QbaF
(Qba F)
December 27, 2021, 10:41am
32
It depends exactly what ESPHome code You use.
Varac
(Varac)
January 1, 2022, 8:06pm
33
@QbaF I’m using this config:
# Taken from old PR: https://github.com/esphome-devices/esphome-devices/pull/78/files
# Current [wiki entry](https://www.esphome-devices.com/devices/Gosund-P1)
# doesn't work (no entities at all)
esphome:
platform: ESP8266
board: esp8285
wifi:
ssid: !secret wifi_casita_ssid
password: !secret wifi_casita_pass
ap:
ssid: "Gosund P1 Fallback Hotspot"
password: !secret wifi_fallback_pass
ota:
api:
reboot_timeout: 1min
logger:
#level: VERY_VERBOSE
#level: DEBUG
baud_rate: 0
logs:
adc: INFO
status_led:
pin:
number: GPIO02
inverted: True
uart:
rx_pin: GPIO03
tx_pin: GPIO01
baud_rate: 4800
switch:
- platform: gpio
name: PS-1 Socket 1
pin: GPIO14
- platform: gpio
name: PS-1 Socket 2
pin: GPIO12
- platform: gpio
name: PS-1 Socket 3
pin: GPIO13
- platform: gpio
pin:
number: GPIO05
inverted: True
- platform: cse7766
current:
voltage:
filters:
- calibrate_linear:
- 0.7 -> 0.0
- 97.5 -> 231.5
power:
filters:
- calibrate_linear:
- 0.0 -> 0
- 290 -> 690
- 490 -> 1170
- lambda: "return x < 2 ? 0 : x;"
update_interval: 20s
- platform: adc
pin: A0
update_interval: 1s
on_value_range:
- below: 0.33
then:
- switch.toggle: socket_3
- above: 0.33
below: 0.67
then:
- switch.toggle: socket_2
- above: 0.67
below: 0.88
then:
- switch.toggle: socket_1
binary_sensor:
- platform: gpio
pin: GPIO16
on_press:
then:
- switch.toggle: socket_usb
output:
- platform: esp8266_pwm
pin:
number: GPIO0
inverted: true
light:
- platform: monochromatic
output: state_led
QbaF
(Qba F)
January 2, 2022, 3:18pm
34
Strange. You should see 4 buttons (switches).
Could You show this device site in HA?
Guxtdu
(Gerald)
April 3, 2022, 3:05pm
35
Thx for the Template
but i cant see the Powermonitoring
Switches work’s well
any idea on this
thx
QbaF
(Qba F)
April 4, 2022, 7:55am
36
Show this device site in HA
david8
(David Christy)
September 26, 2022, 2:16pm
37
This is my first integration using ESPHome so I am using some Gosund P1 devices I have used before with Home Assistant using Tasmota. It has been a steep learning curve. I used the YAML from Gosund P1 | ESPHome-Devices and uploaded after flashing Tasmota mimimal. It connects and I can control the four outputs from HA. I am getting the wifi signal and the time up but no power information. It created the sensors in HA but they are not getting data. They did with the Tasmota implementation. Have I done something stupid and if so how do I work out what?
DAvid
QbaF
(Qba F)
September 26, 2022, 2:45pm
38
I have similar code, at least in the area of voltage, current and power. Is no one of these sensors getting data?
Typo, indentation?
david8
(David Christy)
September 26, 2022, 6:57pm
39
None of the power ones, but wifi and uptime are ok
I did cut and paste the code but possibly I have altered the indentation when changing the top items.
I will check now
D
david8
(David Christy)
September 26, 2022, 7:22pm
40
I can’t see an issue here with indents
Here is the code I am using
esphome:
platform: ESP8266
board: esp8285
esp8266_restore_from_flash: true
substitutions:
plug_name: p1_01
wifi:
ssid: xxx
password: xxx
#domain: !secret domain
#use_address: 192.168.6.6
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "${plug_name} Fallback Hotspot"
password: !secret Fallback_Hotspot
captive_portal:
Enable logging
logger:
#baud_rate: 0
#level: DEBUG
baud_rate: 0
logs:
adc: INFO
Enable Home Assistant API
api:
ota:
time:
platform: homeassistant
status_led:
pin:
number: GPIO02
inverted: True
uart:
rx_pin: GPIO03
#tx_pin: GPIO01
baud_rate: 4800
platform: wifi_signal
name: “${plug_name} - WiFi Signal”
update_interval: 60s
platform: uptime
name: “${plug_name} - Uptime”
icon: mdi:clock-outline
platform: cse7766
current:
name: “${plug_name} - Ampere”
unit_of_measurement: A
accuracy_decimals: 3
icon: mdi:flash-outline
voltage:
name: “${plug_name} - Volt”
unit_of_measurement: V
accuracy_decimals: 1
filters:
- lambda: return x * 2.34245;
power:
name: “${plug_name} - Watt”
unit_of_measurement: W
filters:
update_interval: 3s
platform: total_daily_energy
name: “${plug_name} - Dagverbruik”
power_id: “${plug_name}_Wattage”
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
icon: mdi:clock-alert
platform: adc
pin: GPIO17
internal: true
update_interval: 0.1s
filters:
lambda: |-
if(x >= 0.60 && x < 0.90){
id(buttonrelay1).publish_state(true);
} else if(x >= 0.30 && x < 0.60){
id(buttonrelay2).publish_state(true);
else if(x > 0.10 && x < 0.30){
id(buttonrelay3).publish_state(true);
} else {
id(buttonrelay1).publish_state(false);
id(buttonrelay2).publish_state(false);
id(buttonrelay3).publish_state(false);
return{};
binary_sensor:
platform: gpio
internal: true
pin:
number: GPIO16
mode: INPUT
inverted: true
#on_state:
on_press:
platform: template
internal: true
on_press:
filters:
platform: template
internal: true
on_press:
filters:
platform: template
internal: true
on_press:
filters:
text_sensor:
switch:
platform: gpio
pin: GPIO14
restore_mode: RESTORE_DEFAULT_ON
name: ‘${plug_name} - Switch1’
icon: mdi:power-socket-eu
platform: gpio
pin: GPIO12
name: ‘${plug_name} - Switch2’
platform: gpio
pin: GPIO13
name: ‘${plug_name} - Switch3’
platform: gpio
pin: GPIO05
name: ‘${plug_name} - Switch USB’
inverted: yes
platform: restart
name: “${plug_name} - ESP Restart”
platform: template
name: ‘${plug_name} - Switch off 60s (reset!)’
turn_on_action:
- switch.turn_off: relay3
- delay: 60s
- switch.turn_on: relay3
QbaF
(Qba F)
September 26, 2022, 7:29pm
41
Much better would be if You will replace that post with link to pastebin with code. I am not sure if I will be able to help You but for most others that will be easier to check.
