Sound great. Thank you
Just added this to my HA and it discovered my TV Backlights (H6199). i can turn them on and off, but i donāt see a color picker in the card. is there something i need to do to enable it? I also see a lot of these errors in the log:"
2022-01-10 10:09:20 WARNING (MainThread) [homeassistant.helpers.entity] Entity light.big_tv_lights (<class 'custom_components.govee.light.GoveeLightEntity'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-10 10:09:20 WARNING (MainThread) [homeassistant.helpers.entity] Entity light.ceiling_lights (<class 'custom_components.govee.light.GoveeLightEntity'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-10 10:12:00 WARNING (MainThread) [govee_api_laggat.govee_api_laggat] error getting state for device GoveeDevice(device='2E:4A:CB:31:30:30:6D:4E', model='H6056', device_name='Ceiling lights', controllable=True, retrievable=True, support_cmds=['turn', 'brightness', 'color', 'colorTem'], support_turn=True, support_brightness=True, support_color=True, support_color_tem=True, online=True, power_state=False, brightness=254, color=(118, 255, 0), color_temp=0, timestamp=1641827510.355009, source=<GoveeSource.API: 'api'>, error=None, lock_set_until=0, lock_get_until=0, learned_set_brightness_max=None, learned_get_brightness_max=100, before_set_brightness_turn_on=False, config_offline_is_off=False): API-Error 400: {"message":"Device Not Found","status":400}
2022-01-10 10:12:00 WARNING (MainThread) [custom_components.govee.light] update failed for 2E:4A:CB:31:30:30:6D:4E: API-Error 400: {"message":"Device Not Found","status":400}
2022-01-10 10:28:00 WARNING (MainThread) [govee_api_laggat.govee_api_laggat] error getting state for device GoveeDevice(device='2E:4A:CB:31:30:30:6D:4E', model='H6056', device_name='Ceiling lights', controllable=True, retrievable=True, support_cmds=['turn', 'brightness', 'color', 'colorTem'], support_turn=True, support_brightness=True, support_color=True, support_color_tem=True, online=True, power_state=False, brightness=254, color=(118, 255, 0), color_temp=0, timestamp=1641828470.216205, source=<GoveeSource.API: 'api'>, error=None, lock_set_until=0, lock_get_until=0, learned_set_brightness_max=None, learned_get_brightness_max=100, before_set_brightness_turn_on=False, config_offline_is_off=False): API-Error 400: {"message":"Device Not Found","status":400}
2022-01-10 10:28:00 WARNING (MainThread) [custom_components.govee.light] update failed for 2E:4A:CB:31:30:30:6D:4E: API-Error 400: {"message":"Device Not Found","status":400}
which may be what is causing the issue. Any hints for a complete noob?
Try removing and re-adding the integration. Also, make sure that your Immersion has a reliable WiFi connection.
Iāve removed the integration and readded the device several times. Still no luck in exposing the color change controls. Screenshots are the same as my original post
Any ideas what I can do?
Hi there,
I tried to install the integration via HACS. But i have no chance to enter the api-key. The only thing i can do, is to select a version.
After the installation and a restart, i have no button to configure it. Iām a little bit confusedā¦ can anybody give me a hint, about my mistake?
Youāll need to go to Config > Devices > Add Integration to set it up.
omg i hit my tableā¦ stupid questionā¦ sorry for that and thanks for your help
Iāve added the integration, it seems to connect to the API but it does not detect/discover either of my devices. Both appear in the Govee app. 1 is an H5179, the other is a H5051 (which has a head battery at the moment).
Do they have to be added manually some how or does the API key work but not report devices for a certain lag from creation?
The API doesnāt work with Thermohygeometers. I would recommend the BLE Monitor HACS integration, as it automatically finds devices.
You can also use the Govee Temp/Humidity HACS integration, but you do have to manually add the Bluetooth MAC address, which can be found using the Bluetooth MAC Finder app for Android.
Ah! thanks. I tried out those BLE options, but donāt have a bluetooth dongle yet - adding one tomorrow. Cheers!
Curious will it support them in the future or is this a limitation of the API that you canāt work around?
Iām pretty sure that this is an API limitation, but I could be wrong.
Has anyone integrated the rgbic strips? Namely: H619A2D1UK
I have currently rgb but will be replacing with hopefully this rgbic strip.
Yep! I have a bunch of RGBIC strips. Just make sure that the model you choose has WiFi, which the H619A does.
Brilliant. Thanks Iāve ordered that set
Hi, sure is a stupid question butā¦ why i canāt see the govee integration to add?
In the hacs screen i have added Govee. What iām not doing correctly?
Try rebooting/rebooting again
i did it a few times
I donāt know why, but just now is available in the integrations. Itās working.
Will choosing scenes/modes be possible to implement through this integration? Been slowly building up my immersion setup using goveeās āhighlightā feature and it would be great to be able to automate when starting a movie to activate the highlight feature.
Hey Tim,
I want to buy the H619A aswell, did you manage to get it working?
