Grafana/InfluxDb some entities does not show up
Hi, I’ve got InfluxDB/Grafana up and running (with this guide : https://snillevilla.se/snygg-statistik-i-home-assistant-med-grafana-och-influxdb/ ).
However, in Grafana some of my entities are not showing up. I have a few 433 MHz temperature sensors, and they are defined as “sensor.171_temperature”, “sensor.171_temperature” etc. For some reason they are not showing up in grafana and I have no clue why.
My Hue-temperature sensor showed up without any issues (it’s called “sensor.hue_temperature”) in the query >> select measurement (its name in the drop down is “°C”)
Any ideas?
I have the same issue. Anybody that has a solution?
No one with an answer to this? Pretty annoying that not all sensors showing up…
I still have issues with not all sensors showing. Any news on this?
I was wrong, Answer is here:
