I’ve modified the Slate theme to be more green, and in the process I’ve modified the Calendar/Date-Picker and Entity drop-down menus on the History and Logbook tabs. I think I’ve got this in a final state, have commented what I’ve modified, and added variables to make it easier to follow. Please let me know if anything is broken or unusable and I’ll attempt to repair it.
Screenshots:
YAML:
green_slate:
#Color Variables
green-color: '#00b706'
red-color: '#b70000'
white-color: '#FFFFFF'
light-grey-color: '#777777'
medium-grey-color: '#292929'
dark-grey-color: '#222222'
darker-grey-color: '#141414'
black-color: '#000000'
# Main colors
primary-color: 'var(--green-color)'
accent-color: 'var(--green-color)'
dark-primary-color: 'var(--accent-color)'
light-primary-color: 'var(--accent-color)'
# Text colors
primary-text-color: 'var(--white-color)'
text-primary-color: 'var(--primary-text-color)'
secondary-text-color: 'var(--green-color)'
disabled-text-color: 'var(--light-grey-color)'
label-badge-border-color: 'var(--green-color)'
# Sidebar
sidebar-icon-color: 'var(--white-color)'
# Background colors
primary-background-color: 'var(--dark-grey-color)'
secondary-background-color: 'var(--dark-grey-color)'
divider-color: 'rgba(0, 0, 0, .12)'
table-row-background-color: 'var(--medium-grey-color)'
table-row-alternative-background-color: 'var(--medium-grey-color)'
# Nav Menu
paper-listbox-color: 'var(--light-grey-color)'
paper-listbox-background-color: 'var(--darker-grey-color)'
paper-grey-50: 'var(--primary-text-color)'
paper-grey-200: 'var(--dark-grey-color)'
# Paper card
paper-card-header-color: 'var(--accent-color)'
paper-card-background-color: 'var(--medium-grey-color)'
paper-dialog-background-color: 'var(--medium-grey-color)'
paper-item-icon-color: 'var(--primary-text-color)'
paper-item-icon-active-color: 'var(--green-color)'
paper-item-icon_-_color: 'var(--green-color)'
paper-item-selected_-_background-color: 'var(--medium-grey-color)'
paper-tabs-selection-bar-color: 'var(--green-color)'
# Labels
label-badge-red: 'var(--accent-color)'
label-badge-text-color: 'var(--primary-text-color)'
label-badge-background-color: 'var(--dark-grey-color)'
# Switches
paper-toggle-button-checked-button-color: 'var(--accent-color)'
paper-toggle-button-checked-bar-color: 'var(--accent-color)'
paper-toggle-button-checked-ink-color: 'var(--accent-color)'
paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
# Sliders
paper-slider-knob-color: 'var(--accent-color)'
paper-slider-knob-start-color: 'var(--accent-color)'
paper-slider-pin-color: 'var(--accent-color)'
paper-slider-active-color: 'var(--accent-color)'
paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
paper-slider-secondary-color: 'var(--secondary-background-color)'
paper-slider-disabled-active-color: 'var(--disabled-text-color)'
paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
# Google colors
google-red-500: 'var(--red-color)'
google-green-500: 'var(--green-color)'
# Add black border to icons
iron-icon-stroke-color: 'var(--black-color)'
#Changes to fix history/logbook menus
lumo-primary-text-color: 'var(--green-color)'
lumo-secondary-text-color: 'var(--green-color)'
lumo-primary-color: 'var(--green-color)'
lumo-primary-color-50pct: 'rgba(0, 183, 6, .5)'
lumo-primary-color-10pct: 'rgba(0, 183, 6, .1)'
#Calendar day numbers
lumo-body-text-color: 'var(--white-color)'
#Calendar/Date-Picker Background
lumo-base-color: 'var(--medium-grey-color)'
#Month/Year header
lumo-header-text-color: 'var(--lumo-body-text-color)'
#DayOfWeek Header
lumo-tertiary-text-color: 'var(--lumo-body-text-color)'
# Background of date in History/Logbook that you clcim to view date-picker
lumo-shade: 'var(medium-grey-color)'
lumo-shade-90pct: 'rgba(41, 41, 41, .9)'
lumo-shade-80pct: 'rgba(41, 41, 41, .8)'
lumo-shade-70pct: 'rgba(41, 41, 41, .7)'
lumo-shade-60pct: 'rgba(41, 41, 41, .6)'
lumo-shade-50pct: 'rgba(41, 41, 41, .5)'
lumo-shade-40pct: 'rgba(41, 41, 41, .4)'
lumo-shade-30pct: 'rgba(41, 41, 41, .3)'
lumo-shade-20pct: 'rgba(41, 41, 41, .2)'
lumo-shade-10pct: 'rgba(41, 41, 41, .1)'
lumo-shade-5pct: 'rgba(41, 41, 41, .05)'
#Removes Gradient in Calendar/Date-Picker and Drop-down lists
lumo-tint-5pct: 'var(--darker-grey-color)'
